Audio Console control/configuration using Macros
lawrencecj
Hello - I trying to see if it is possible to configure the audio console on a WebEx Codec Pro using Macros.
The customer has a CODEC Pro with 4 Microphones and 2 speakers "Zones" in a kinda large extremely packed acoustically challenged room. Phase 2 of the project is bringing in an external DSP and full-on audio engineering setup, but this is needed to get them by for now.
Microphones Inputs 1 and 2 - Presenter Left and Right
Microphone Inputs 3 -4 - Head Table
Speaker Zone 1 (Line Out 1) - Front of Room (Program Audio)
Speaker Zone 2 (Line Out 3) - Reinforcement Audio
Right now the Audio Console on the Pro is configured to provide reinforcement audio when in an active call using Speaker Zone 2 - This works fine with no issues
The requirement now to dynamically use a macro that will configure Speaker Zone 1 AND 2 to provide Room Audio Reinforcement when the CODEC is not in an active call.
Basically, add Speaker Zone 1 (Line 1) to the Reinforcement Output Group - When not in an active call then remove Line 1 and add it back to the default Loudspeaker group when in an active call.
0 Replies 0
