Gateway 2821 fails to forward call to callmanager5
xiaoliangyue
Topology:
[Intercom] -> fxo--[gw 2821] -> [cucm5] -- [phone 41851]
The configuration:
dial-peer voice 41851 voip
destination-pattern 41851
session target ipv4:172.26.240.10
dtmf-relay h245-signal
codec g711ulaw
voice-port 0/0/0
cptone CA
timeouts call-disconnect 5
timeouts wait-release 5
connection plar 41851
station-id name Intercom4
station-id number 00004
caller-id enable
I suspect that some configurations are missing. please help.
Please refer to the attachment for output of debug vpm signal and deb voice dialpeer.
Jon
20 Replies 20
Michael, you're amazing! Vg224 did have routing problem. resovlving the routing issue, now vg224 can reach phone 41851, and I got 2-way audio now.
At the beginning, the h323 gateway was configured on a router with IP 172.26.240.244. However this box was used for other purpose, I got another router 2821, which has IP 172.26.240.243. This change happened just since last test.
Now the call goes thru. More than that, I was hoping that the caller id (station-id name IntercomTest) configured on voice-port 0/1/0 could be passed to the called party (phone 41851).
voice-port 0/1/0
no battery-reversal
cptone CA
caller-id enable
This is actually the real purpose why I deploy the H.323 gw. Now on phone 41851, caller id shows 41896 with caller name XXXX. which is not I expect :(
Jon
Good to hear that you're almost there Jon!
It sounds like the caller-id information being received on 41851 is the information about the VG224 phone which is originating the call.
Check out the following document that explains the relevant commands:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a00800a9a49.shtml#req
Specifically, note that:
1. When the 'caller-id enable' command is used, this enables the transmission of caller-id on an FXO port. In our case, we don't want to have the caller-id information from the VG224 phone transmitted. So lets use the command 'no caller-id enable' instead.
2. The 'station-id number' and 'station-id name' commands only apply if no caller id is received on an FXO voice port. In our previous test we were indeed receiving caller-id because of the presence of the 'caller-id enable' command. So now that we have disabled inbound caller-id, lets add a 'station-id number' command to the voice-port.
The anticipation here here is that by disabling caller-id on the port through the 'no caller-id enable' command, the two 'station-id' commands would then take effect, and what is configured via those commands is what will be transmitted to the destination phone. Lets try this and see what happens.
voice-port 0/1/0
station-id number 12345
no caller-id enable
Michael.
Michael,
I agree with your analysis. I disabled the caller id on port 0/1/0, and made a test call. the weird thing is, the h323 gw still gets caller id and name:
001874: *Feb 27 16:52:39.671 UTC: [0/1/0] get_fxo_caller_id calling num=41833 calling name=Jon Test calling time=02/26 19:01
and the caller id and name show up on the phone 41851.
The values the gw has now are actually what it remembered from last caller id it got. station-id name/number are not used at all.
Jon
Hi Jon,
It may be necessary to shut/no shut the voice port to have the changes take effect.
If not, then it would seem that any caller-id information received from the VG224 phone overrides the station-id configs. Can you configure the VG224 phone to not send any caller-id information.
In the planned topology, the FXO port was connected to the Intercom system. Would the intercom system be sending caller-id information like the VG224 phone is doing? If not, then the station-id info would be sent.
Michael.
Hi, Michael,
I think the h323 is using cache. shut/no shut doesn't remove it. I finally rebooted the router. It works just like it is supposed to.
Thank you so much!!!
Jon
That's good news Jon. Thanks for the update, and the opportunity to assist :-)
Michael.
