How to make the Web View button work in a Macro Editor with Room Bar
b-dantoni
Good afternoon,
We are trying to create a button that helps us display a URL both on the touch screen and on the television. The script is as follows:
const config = {
  button: {
    name: 'Web View'// The main button name on the UI and its Panel Page Tile
    icon: 'Tv',       // Specify which prebuilt icon you want. eg. Concierge | Tv
    title: 'Tap To Open',
    showInCall: true,
    closeContentWithPanel: false // Automatically close any open content when the panel closes
  content: [
      title: 'Web View - PNT ',
      url: 'https://pnt.agenas.it/home',
      navUrl: 'https://pnt.agenas.it/home',
      mode: 'Modal',
      controls: 'duplicate'
  username: 'webviewIntegration'// Name of the local integration account which used for the websocket connect
  panelId: 'websocket' // Modify if you have multiple copies of this marcro on a single device
The button works correctly, meaning it allows me to view the web page, but the sync between the touch and what is displayed on the TV does not work.
Additionally, if I want to scroll the page on the touch screen, it does not let me do it.
b-dantoni
This is all the Macro Configuration:
 * Macro Author:        William Mills
 *                      Technical Solutions Specialist
 *                      wimills@cisco.com
 *                      Cisco Systems
 * Version: 1-0-0
 * Released: 11/15/23
 * This is an example Webex Device macro which lets you control a
 * WebView Web App on your Webex Device from an in room touch controller.
 * Demo WebApps:
 * - Tetris:
 *   The classic tetris controlled using a UI Extension Navigation Widget
 * - YouTube:
 *   Embedded YouTube player with UI Extension playback controls
 * - Vimoe:
 *   Embedded Vimeo player with UI Extension playback controls
 * - Whiteboard:
 *   Simply whiteboard Web App which mirrors drawings on the Room Navigator
 *   and the Webex Devices main display
 * Full Readme, source code and license agreement available on Github:
import xapi from 'xapi';
 * Configure the settings below
const config = {
  button: {
    showInCall: true,
  content: [
      mode: 'Modal',
 * Main functions and event subscriptions
let openingWebview = false;
let integrationViews = [];
xapi.Config.WebEngine.Mode.get()
  .then(mode => init(mode))
  .catch(error => console.warn('WebEngine not available:'JSON.stringify(error)))
async function init(webengineMode) {
  const username = config.username;
  if (webengineMode === 'Off') {
    console.log('WebEngine Currently [Off] setting to [On]')
    xapi.Config.WebEngine.Mode.set('On');
  const touchController = await checkForControllers();
  if (!touchController) {
    return;
  xapi.Config.WebEngine.Features.AllowDeviceCertificate.set('True')
  const integrationAccount = await xapi.Command.UserManagement.User.Get({ Username: username })
    .catch(error => console.log('Error finding user:', error.message))
  if (integrationAccount) {
    // Delete account if its already exists (clear any previous config)
    deleteAccount();
  createPanel();
  xapi.Event.UserInterface.Extensions.Widget.Action.on(processWidget);
  xapi.Event.UserInterface.Extensions.Event.PageClosed.on(event => {
    if (!event.PageId.startsWith(config.panelId)) return;
    if (openingWebview) return;
    xapi.Status.SystemUnit.State.NumberOfActiveCalls.get()
      .then(value => {
        if (value == 1return;
        console.log('Panel Closed - cleaning up')
        closeWebview();
        createPanel();
        deleteAccount();
  xapi.Event.UserInterface.Extensions.Event.PageOpened.on(event => {
    console.log('Panel Opened')
    //createPanel();
  xapi.Status.UserInterface.WebView.on(processWebViews);
  xapi.Status.Audio.Volume.on(value => {
    console.log('Volume', value)
    if (integrationViews.length == 0return;
    xapi.Status.UserInterface.Extensions.Widget.get()
      .then(widgets => {
        widgets.forEach(widget => {
          if (widget.WidgetId != config.panelId + '-volumeSlider'return;
          xapi.Command.UserInterface.Extensions.Widget.SetValue(
            { Value: value, WidgetId: value });
        console.log(widgets)
function createAccount(password) {
  console.log(`Creating new user [${config.username}] with password [${password}]`)
  return xapi.Command.UserManagement.User.Add({
    Active'True',
    Passphrase: password,
    PassphraseChangeRequired'False',
    Role: ['Integrator''User'],
    ShellLogin'True',
    Username: config.username
    .then(result => console.log('Create user result:', result.status))
    .catch(error => console.warn('Error creating user:'JSON.stringify(error)))
function deleteAccount() {
  console.log(`Deleting user [${config.username}]`)
  return xapi.Command.UserManagement.User.Delete({ Username: config.username })
    .then(result => {
      console.log(`[${config.username}] delete status:`, result.status);
    .catch(error => {
      console.log('Error caught')
      if (!error.message.endsWith('does not exist')) {
        console.warning(`Error deleting user [${config.username}]:`JSON.stringify(error));
      } else {
        console.log(error.message);
function createPassword(length) {
  const chars = "0123456789abcdefghijklmnopqrstuvwxyz!@#$%^&*()ABCDEFGHIJKLMNOPQRSTUVWXYZ";
  let password = '';
  for (let i = 0; i < length; i++) {
    let randomNumber = Math.floor(Math.random() * chars.length);
    password += chars.substring(randomNumber, randomNumber + 1);
  return password;
async function generateHash() {
  const ipAddress = await xapi.Status.Network[1].IPv4.Address.get();
  const password = createPassword(255);
  await createAccount(password)
  return btoa(JSON.stringify({ username: username, password: password, ipAddress: ipAddress }))
async function openWebview(content) {
  closeWebview();
  console.log(`Opening [${content.title}] on [OSD]`);
  openingWebview = true
  const hash = await generateHash();
  xapi.Command.UserInterface.WebView.Display({
    Mode: content.mode,
    Title: content.title,
    Target'OSD',
    Url: content.url + "#" + hash
    .then(result => { console.log('Webview opened on [OSD] 'JSON.stringify(result)) })
    .catch(e => console.log('Error: ' + e.message))
  if (content.controls != 'duplicate' && content.controls != 'webview') {
    console.log("not duplicate or webview, setting timer", content.controls)
    setTimeout(() => {
    }, 500)
    return;
  console.log(`Opening [${content.title}] on [Controller]`);
  let url = (content.controls === 'duplicate') ? content.url : content.navUrl;
    Mode: content.mode,
    Target'Controller',
    Url: url + "#" + hash
    .then(result => {
      console.log('Webview opened on [Controller] 'JSON.stringify(result))
      setTimeout(() => {
      }, 500)
// Close the Webview
async function closeWebview() {
  xapi.Command.UserInterface.WebView.Clear({ Target'OSD' });
  xapi.Command.UserInterface.WebView.Clear({ Target'Controller' });
// Process Widget Clicks
async function processWidget(e) {
  console.log(e)
  if (!e.WidgetId.startsWith(config.panelId)) return
  const [panelId, command, option] = e.WidgetId.split('-');
  switch (command) {
    case 'selection':
      if (e.Type != 'clicked'return
      openWebview(config.content[option]);
      const controls = config.content[option].controls;
      if (controls === 'duplicate' || controls === 'webview'return;
      createPanel(config.content[option].controls);
      break;
    case 'close':
      closeWebview();
      createPanel();
      break;
    case 'playcontrols':
      if (option == 'toggleMute') {
        xapi.Command.Audio.Volume.ToggleMute();
      } else if (option == 'volumeSlider') {
        if (e.Type != 'released'return
        const newVolume = mapBetween(parseInt(e.Value),0,100,0,255)
        console.log('Setting Volume to:', newVolume)
        xapi.Command.Audio.Volume.Set({ Level: newVolume });
      break;
async function processWebViews(event) {
  console.log('WebView Status Change: 'JSON.stringify(event))
  if (event.hasOwnProperty('Status') && event.hasOwnProperty('Type')) {
    if (event.Status !== 'Visible' || event.Type !== 'Integration'return;
    if (!openWebview) return;
    console.log(`Recording Integration WebView id [${event.id}]`)
    integrationViews.push(event)
  } else if (event.hasOwnProperty('Status')) {
    if (event.Status === 'NotVisible' || event.Status === 'Error') {
      const result = integrationViews.findIndex(webview => webview.id === event.id)
      if (result === -1return;
        .then(value => {
          console.log(`Integration WebView id [${event.id}] changed to [${event.Status}] - closing all Integration WebViews`)
          closeWebview();
          deleteAccount();
  } else if (event.hasOwnProperty('ghost')) {
    console.log(`Integration WebView id [${event.id}] ghosted - closing all Integration WebViews`)
    closeWebview();
function checkForControllers() {
  return xapi.Status.Peripherals.ConnectedDevice.get()
    .then(devices => {
      const controller = devices.filter(d => {
        return d.Status == 'Connected' &&
          d.Type == 'TouchPanel' &&
          d.Location == 'InsideRoom'
      if (controller.length == 0) {
        console.log(`No in controllers connected, this macro is designed to work with an in room touch controller`);
        return false
      } else {
        return true
    .catch(e => {
      console.log('No connected devices, this macro is designed to work with an in room touch controller')
      return false
function mapBetween(currentNum, minAllowed, maxAllowed, min, max) {
  return Math.round(
    ((maxAllowed - minAllowed) * (currentNum - min)) / (max - min) +
    minAllowed
async function createPanel(state) {
  const button = config.button;
  const content = config.content;
  const panelId = config.panelId
  let pageName = config.button.title;
  console.log(`Creating Panel [${panelId}]`);
  let rows = '';
  function widget(id, type, name, options) {
    return `<Widget><WidgetId>${panelId}-${id}</WidgetId>
            <Name>${name}</Name><Type>${type}</Type>
            <Options>${options}</Options></Widget>`
  function row(widgets = '') {
    return Array.isArray(widgets) ? `<Row>${widgets.join('')}</Row>` : `<Row>${widgets}</Row>`
  if (state) {
    pageName = 'Controls'
    rows = rows.concat(row(widget('close''Button''Close Content''size=2')))
    switch (state) {
      case 'blank':
        break;
      case 'accelerate':
        rows = rows.concat(row(widget('instructions''Text''Hold the button to accelarate up''size=4;align=center')))
        rows = rows.concat(row(widget('accelerate''Button''Hold the button to accelarate up''size=3')))
        break;
      case 'navigation':
        rows = rows.concat(row(widget('instructions''Text''Use the arrows to move and rotate the pieces''size=4;align=center')))
        rows = rows.concat(row(widget('navigation''DirectionalPad''''size=3')))
        break;
        rows = rows.concat(row(widget('title''Text''Playback Controls''size=4;fontSize=normal;align=center')))
        rows = rows.concat(row(widget('playTime''Text''Loading...''size=2;fontSize=normal;align=center')))
        rows = rows.concat(row(widget('playcontrols-slider''Slider''''size=4')))
        rows = rows.concat(row([
          widget('playcontrols-playpause''Button''''size=1;icon=play_pause'),
          widget('playcontrols-stop''Button''''size=1;icon=stop'),
          widget('playcontrols-fastback''Button''''size=1;icon=fast_bw'),
          widget('playcontrols-fastforward''Button''''size=1;icon=fast_fw')]))
          widget('playcontrols-toggleMute''Button''''size=1;icon=volume_muted'),
          widget('playcontrols-volumeSlider''Slider''''size=3')]))
        break;
  } else {
    if (content == undefined || content.length < 0) {
      console.log(`No content available to show for [${panelId}]`);
      rows = row(widget('no-content''Text''No Content Available''size=4;fontSize=normal;align=center'))
    } else {
      for (let i = 0; i < content.length; i++) {
        rows = rows.concat(row(widget(`selection-${i}`'Button', content[i].title, 'size=4')));
  let order = '';
  const orderNum = await panelOrder(config.panelId);
  if (orderNum != -1) order = `<Order>${orderNum}</Order>`
  const panel = `
    <Extensions><Panel>
      <Location>${button.showInCall ? 'HomeScreenAndCallControls' : 'HomeScreen'}</Location>
      <Type>${button.showInCall ? 'Statusbar' : 'Home'}</Type>
      <Icon>${button.icon}</Icon>
      <Color>${button.color}</Color>
      <Name>${button.name}</Name>
      ${order}
      <ActivityType>Custom</ActivityType>
      <Page>
        <Name>${pageName}</Name>
        ${rows}
        <PageId>${panelId}-page</PageId>
        <Options>hideRowNames=1</Options>
      </Page>
    </Panel></Extensions>`;
  return xapi.Command.UserInterface.Extensions.Panel.Save({ PanelId: panelId }, panel);
async function panelOrder(panelId) {
  const list = await xapi.Command.UserInterface.Extensions.List({ ActivityType'Custom' });
  if (!list.hasOwnProperty('Extensions')) return -1
  if (!list.Extensions.hasOwnProperty('Panel')) return -1
  if (list.Extensions.Panel.length == 0return -1
  for (let i = 0; i < list.Extensions.Panel.length; i++) {
    if (list.Extensions.Panel[i].PanelId == panelId) return list.Extensions.Panel[i].Order;
  return -1
