https://custom-collab.cisco.com/uieditor/ not working!
BristolBen
Community Member
Hi community,
I am trying to use the ui editor online tool to create custom UI for a Navigator panel, but the link:
Seems to no longer work, the link does not resolve.
I have also found this:
https://github.com/cisco-ce/uieditor-standalone/tree/main/%40cesw
But this does not help me either as it does not load any assets offline so is not a useful tool.
I do not currently have access to a Cisco codec to work on, so really could do with either a web or offline tool to use to create my custom pages and buttons.  Can anyone point me in the right direct?
Regards, Ben
You can download a version of the UI Editor at UI Extensions Editor CE9.13.0
It was made for an older version of the endpoint software but should enable you to do what you want.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne
Thanks Wayne, that is exactly what I am after.
Regards, Ben
Josh McKinley
Community Member
Is the offline editor discontinued?  I noticed the latest version does not support web widgets.  Is there anyway to configure the web widgets prior to deployment?
