Is it possible to run telnet commands from an API macro on Cisco touch 10?
ninjamaster5280
I'm trying to control lighting in a room by using the macro feature and commands. In order to do this, I need to be able to run telnet commands.  Is it possible to run telnet commands directly from api macro calls?  If so, how would I do this?  I noticed that the documentation contains http calls, but currently cannot find a telnet feature.
If not, is it possible to include telnet client external library for javascript that would work, such as
var request = new XMLHttpRequest();
No, the endpoint itself cannot make outbound telnet connections.
As a workaround, you can have some other system monitoring the xFeedback of the endpoint looking for your button presses on the Touch10, then triggering a telnet (or whatever other functionality you may require for other things).  You can do this with something simple and cheap like a Raspberry Pi if you don't have other infrastructure available in your environment to do this from.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
