Problem with setting up AES
chanhontung
Dear All Experts
I run in to troble with external stand alone VC  try to call in with encryption on.
I have set up tandberg mxp 1700 register the H.323  and SIP to my VCSC and  VCSE
When I try to make a H323/SIP call from mxp 1700 to the external VC it work just fine
But when I try try to make a call from the external stand alone VC to mxp 1700.
It just disconnect by itself.
I looked it in to the lock . It just rejected by the vcse by the following log:
tvcs: Event="
Call Rejected
" Service="
H323
" Src-ip="
101.78.153.150
" Src-port="
11039
" Src-alias-type="
H323
" Src-alias="
MXP206
" Src-alias-type="
E164
" Src-alias="
852206
" Dst-alias-type="
H323
" Dst-alias="
mxp208@nete2mg.com
" Call-serial-number="
d14cee2e-ac58-11e1-84e0-0010f31ae488
" Tag="
d14cef0a-ac58-11e1-8f10-0010f31ae488
" Protocol="
TCP
" Response-code="
Undefined reason
" Level="
" UTCTime="
2012-06-02 02:15:30,854
everythin work out find with both system without enabel the encryption
my vcse version is x6.1
Any experts can me out on this?
17 Replies 17
THX! Also one more question.
now I am focusing to work on Traverl zone and local zone only
Is other zone have a anything to do with my case.
Since the SIP call withount encryption is working fine.
Default Subzone and Default Zone will involve traversal call/registration in default configuration.
However current release version doesn’t have any configuration that will control enable/disable encryption over SIP call while using TLS as transport protocol.
So as long as TLS is in used for your call, your zone configuration should be fine.
Please note that there are few firewalls does support TLS inspection today (Cisco ASA, Checkpoint, etc.). If you are using such firewall, I’d suggest to disable it for isolating firewall issue. (please note very unfortunately some of firewall may require create rule manually to disable TLS inspection even it have check box to disable the TLS inspection…).
Thanks Tomonori
I am using Cisco ASA5510 firewall. It should be suitable for our case.
I will try to disable thel TLS inspection
THX for your help
