04-03-2013 04:17 PM - edited 03-18-2019 12:52 AM
Im installing TMS 14.1 on Windows Server 2008 and at a moment of the installation i receive the bellow error and the installation is stopped.
"Unhandled Exception
Error number: 0x80131501
Description: It was not possible to convert some or all identities references.
Setup will now terminate"
Solved! Go to Solution.
05-02-2013 07:44 AM
Hi All,
Thank you very much for your help. The language pack is not solved my problem :-( I reinstalled the 13.2.2 and tmspe 1.0, it works..
I will install the new english server and try to move my TMS.
Balazs
04-28-2013 11:21 PM
HI,
It's better to have a new server with english OS and then restore backup, It will be lot more easier and safe.
Sumeet Rakesh
