Unpredictable LDAP Sync Behavior in CMS During Automation
Smile1
CMS (cisco meeting server) v. 3.11 Exhibits Unpredictable LDAP sync behavior during scripted powershell operations
When configuring CMS and integrating LDAP, I noticed there is no automatic synchronization to update user account information. To handle this, I wrote a PowerShell script to perform the sync. However, I'm running into a strange issue: even if I specify a single LDAP source ID, the script synchronizes 4 random LDAP sources out of the 8 available. It completely ignores the ID I provide.
Even more oddly, if I give the script all 8 LDAP source IDs, it does loop through all of them—but for each ID, it performs the exact same action as it does when only one ID is provided (syncing the same 4 random sources).
What could be causing this behavior?
Smile1
Here is the script:
$uri = "https://cms.my.domain:8443/api/v1/ldapSyncs"
$apiUser        = 'admin'
$apiPass        = 'password'
$ldapSourceID   = ( "1"
    #"2",
    #"3",
    #"4",
    #"5",
    #"6",
    #"7"
    #"8"
$tenantID       = ""
$pair   = "$apiUser`:$apiPass"
$sec = ConvertTo-SecureString $apiPass -AsPlainText -Force
$info = New-Object System.Management.Automation.PSCredential($apiUser, $sec)
$encoded = [Convert]::ToBase64String([System.Text.Encoding]::UTF8.GetBytes($pair))
[Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls12
foreach ($id in $ldapSourceID) {
    $syncPayload = @{
        tenant = @{ id = $tenantID}
        ldapSource = @(@{ id = $id })
        removeWhenFinished = $false
    $syncPayloadJson = $syncPayload | ConvertTo-Json -Depth 3
    $response = Invoke-WebRequest -Uri $uri -Credential $info -Method Post -Body $syncPayloadJson -UseBasicParsing:$true
    Write-Host "TRIGERIUKAS source $id"
$job = ($response.Content | ConvertFrom-Json)
$jobID = $job.id
do {
    Write-Host "Nu....."
    Start-Sleep -Seconds 5
    $statusResp = Invoke-WebRequest -Uri "$uri/$jobId" -Credential $info -UseBasicParsing
    #Write-Host "TEST: [$($statusResp.Content)]"
    $statusXml = [xml]$statusResp.Content
    $status = $statusXml.ldapSyncs.ldapSync[0].state
    $count = [int]$statusXml.ldapSyncs.ldapSync[0].numUsersImported
    $sourcesCompleted = [int]$statusXml.ldapSyncs.ldapSync[0].numLdapSourcesComplete
    if($usersImported -gt 0) { $lastCount = $usersImported }
    #Write-Host "Current sync status: $status, users imported: $count, sources complete: $sourcesComplete"
} while ($status -eq "inProgress")
Write-Host "Status of sync: $status, users imported/updated: $lastCount, sources used/completed: $sourcesComplete"
