taknakam
本ドキュメントは 、過去3ヶ月の Secure Network Analytics (SNA) に関する TAC Service Request (SR) において、発生件数の多かった不具合について上位のもの(最大5件程度)をご紹介します。発生件数については公開しておりませんのでご了承ください。
2025年4月分
不具合 ID タイトル
CSCwo60663 FC Engine: SGT Names are not consistently matching with the correct SGT IDs
CSCwo05014  Rebooting Manager appliance corrupts Smart Licensing data
CSCwn12561  Flow Collector crashes due to improper processing of NAT Information Elements exported in Netflow
2025年3月分
不具合 ID タイトル
CSCwo40046 FC Engine: Exporter counters internal to the engine can get out of sync during the exporter discover
CSCwo26872  Improve fc-core event priority queue: counting and logging
CSCwo26871  Add priority to Alarm events in fc-core
CSCwo26870  Reduce excessive flow collector -> Manager TCP connection frequency
CSCwf07136  CIMC upgrade fails if CIMC IP filter is set.
CSCwo38566  Flow Sensor dpdk interface packet capture fails with 'Missing setup' error.
CSCwn61394  Unable to change the sysadmin password on SNA appliances after password expiry
CSCwi37950  Update Manager is unable to upload the swu (firmware/patch update file)
2025年2月分
不具合 ID タイトル
CSCwk39199 networking services fail when static routes are configured
CSCwn40653  Desktop Client shows a blank screen for patched 7.5.1 appliances
CSCwn36248  False positive "Unlicensed Feature" alarm - Displayed in Swing Client, sent by Response Management
