siyhan
本ドキュメントでは Catalyst 9200/Catalyst 9200L/Catalyst 9200cx における CISCO-ENTITY-FRU-CONTROL-MIB のサポート状況について説明します。
CISCO-ENTITY-FRU-CONTROL-MIB に含まれる以下のトラップは Catalyst 9200/Catalyst 9200L/Catalyst 9200cx ではサポートされていません。
cefcModuleStatusChange
cefcPowerStatusChange
cefcUnrecognizedFRU
cefcFanTrayStatusChange
cefcPowerSupplyOutputChange
cefcVmModuleStatusChangeNotif
以下トラップは FAN 抜き差し時のみサポートしていなく、FAN 抜き差し時に該当トラップが出力されないことは期待動作です。
cefcFRUInserted
cefcFRURemoved
実機での例は以下となります。
電源モジュールの抜き差し
*Feb 11 21:18:18.488: Using Special Trap Queue for this notification
*Feb 11 21:18:18.488: SNMP: Queuing packet to 192.168.1.1
*Feb 11 21:18:18.488: SNMP: V2 Trap, reqid 48, errstat 0, erridx 0
sysUpTime.0 = 205221
snmpTrapOID.0 = cefcFRURemoved
entPhysicalEntry.4.2016 = 2007
*Feb 11 21:18:18.686: %PLATFORM_FEP-6-FRU_PS_OIR: Switch 2: FRU power supply B removed
*Feb 11 21:18:18.739: SNMP: Packet sent viaUDP to 192.168.1.1 (192.168.1.1)
*Feb 11 21:18:43.737: %PLATFORM_FEP-6-FRU_PS_OIR: Switch 2: FRU power supply B inserted
*Feb 11 21:18:43.745: Using Special Trap Queue for this notification
*Feb 11 21:18:43.745: SNMP: Queuing packet to 192.168.1.1
*Feb 11 21:18:43.745: SNMP: V2 Trap, reqid 49, errstat 0, erridx 0
sysUpTime.0 = 207746
snmpTrapOID.0 = cefcFRUInserted
entPhysicalEntry.4.2017 = 2007
entPhysicalEntry.2.2017 = Switch 2 - Power Supply B
entPhysicalEntry.7.2017 = Switch 2 - Power Supply B
*Feb 11 21:18:43.819: Using Special Trap Queue for this notification
*Feb 11 21:18:43.819: SNMP: Queuing packet to 192.168.1.1
*Feb 11 21:18:43.819: SNMP: V2 Trap, reqid 50, errstat 0, erridx 0
sysUpTime.0 = 207754
*Feb 11 21:18:43.995: SNMP: Packet sent viaUDP to 192.168.1.1 (192.168.1.1)
*Feb 11 21:18:44.246: SNMP: Packet sent viaUDP to 192.168.1.1 (192.168.1.1)
*Feb 11 21:18:46.270: SNMP: Queuing packet to 192.168.1.1
*Feb 11 21:18:46.271: SNMP: V2 Trap, reqid 51, errstat 0, erridx 0
sysUpTime.0 = 207999
snmpTrapOID.0 = ciscoEnvMonMIBNotifications.9
ciscoEnvMonSupplyStatusEntry.2.2017 = Switch 2 - Power Supply B
ciscoEnvMonSupplyStatusEntry.3.2017 = 4
*Feb 11 21:18:46.523: SNMP: Packet sent via UDP to 192.168.1.1
FAN モジュールの抜き差し
*Feb 11 20:52:17.333: %PLATFORM_THERMAL-1-FRU_FAN_FAILURE: Switch 2: System fan 1 failed
*Feb 11 20:52:17.341: SNMP: Queuing packet to 192.168.1.1
*Feb 11 20:52:17.341: SNMP: V2 Trap, reqid 25, errstat 0, erridx 0
sysUpTime.0 = 49106
snmpTrapOID.0 = ciscoEnvMonMIBNotifications.8
ciscoEnvMonFanStatusEntry.2.2014 = Switch 2 - FAN - T1 1
ciscoEnvMonFanStatusEntry.3.2014 = 3
*Feb 11 20:52:17.591: SNMP: Packet sent via UDP to 192.168.1.1
*Feb 11 20:52:49.298: %PLATFORM_THERMAL-6-FRU_FAN_RECOVERY: Switch 2: System fan 1 recovered to normal status
*Feb 11 20:52:49.305: SNMP: Queuing packet to 192.168.1.1
*Feb 11 20:52:49.305: SNMP: V2 Trap, reqid 26, errstat 0, erridx 0
sysUpTime.0 = 52302
ciscoEnvMonFanStatusEntry.3.2014 = 1
*Feb 11 20:52:49.556: SNMP: Packet sent via UDP to 192.168.1.1
SFP の抜き差し
*Feb 11 20:56:12.396: %PLATFORM_PM-6-MODULE_REMOVED: SFP module with interface name Te2/1/1 removed
*Feb 11 20:56:12.400: Using Special Trap Queue for this notification
*Feb 11 20:56:12.400: SNMP: Queuing packet to 192.168.1.1
*Feb 11 20:56:12.400: SNMP: V2 Trap, reqid 29, errstat 0, erridx 0
sysUpTime.0 = 72612
entPhysicalEntry.4.2091 = 2087
*Feb 11 20:56:12.651: SNMP: Packet sent viaUDP to 192.168.1.1 (192.168.1.1)
*Feb 11 20:59:00.714: %PLATFORM_PM-6-MODULE_INSERTED: SFP module inserted with interface name Te2/1/1
*Feb 11 20:59:00.747: Using Special Trap Queue for this notification
*Feb 11 20:59:00.748: SNMP: Queuing packet to 192.168.1.1
*Feb 11 20:59:00.748: SNMP: V2 Trap, reqid 30, errstat 0, erridx 0
sysUpTime.0 = 89447
entPhysicalEntry.4.2103 = 2087
*Feb 11 20:59:00.999: SNMP: Packet sent viaUDP to 192.168.1.1 (192.168.1.1)
NM モジュールの抜き差し
*Mar 18 08:07:51.575: %PLATFORM_PM-6-FRULINK_REMOVED: 4x10G uplink module removed from switch 1 slot 1
*Mar 18 08:07:51.592: Using Special Trap Queue for this notification
*Mar 18 08:07:51.593: SNMP: Queuing packet to 192.168.1.1
*Mar 18 08:07:51.593: SNMP: V2 Trap, reqid 4, errstat 0, erridx 0
sysUpTime.0 = 209661670
entPhysicalEntry.4.1091 = 1061
*Mar 18 08:09:59.300: %PLATFORM_PM-6-FRULINK_INSERTED: 4x10G uplink module inserted in the switch 1 slot 1
*Mar 18 08:09:59.330: Using Special Trap Queue for this notification
*Mar 18 08:09:59.330: SNMP: Queuing packet to 192.168.1.1
*Mar 18 08:09:59.331: SNMP: V2 Trap, reqid 5, errstat 0, erridx 0
sysUpTime.0 = 209674443
entPhysicalEntry.4.1096 = 1061
*Mar 18 08:09:59.344: Using Special Trap Queue for this notification
*Mar 18 08:09:59.344: SNMP: Queuing packet to 192.168.1.1
*Mar 18 08:09:59.344: SNMP: V2 Trap, reqid 6, errstat 0, erridx 0
sysUpTime.0 = 209674444
entPhysicalEntry.2.1096 = 4x10G Uplink Module
entPhysicalEntry.7.1096 = Switch 1 FRU Uplink Module 1
関連情報:
CSCwi81576
