Kunitaka Matsumura
本記事では Cisco Catalyst 9800 ワイヤレスコントローラ ( C9800 ) で取得することが多い、show tech-support と show tech-support wireless コマンドに含まれているコマンドの一覧を紹介しています。
show tech-support の取得が制限されている場合や、取得を予定しているコマンドがこれらに含まれているのかを確認する際などにご参照下さい。
なお、出力結果については以下の環境で動作を確認したものとなります
Hardware : C9800-40
Software : 17.3.3
show tech-support に含まれるコマンド一覧
show clock
show version
show runningconfig
show redundancy history
show redundancy states
show redundancy switchover history
show stacks
show interfaces
show interfaces history
show controllers
show user
show datacorruption
show file systems
show file descriptors
show bootflash: all
show harddisk: all
show webui: all
show bootflash2: all
show harddisk2: all
show stbybootflash: all
show stbyharddisk: all
show memory statistics
show process memory sorted
show process memory platform sorted
show process cpu sorted
show process cpu platform sorted
show process cpu extended history
show process cpu history
show controllers t1
show controllers e1
show ipc nodes
show ipc ports
show ipc queue
show ipc status
show cdp neighbor
show cdp neighbor detail
show subscriber statistics
show ip subscriber statistics errors
show ip subscriber statistics dangling
show pppoe statistics
show pppoe summary
show ppp statistics
show ppp subscriber statistics
show ppp summary
show l2tp counters component errors
show l2tp counters session fsm event icrq
show l2tp counters session fsm event ocrq
show l2tp counters session fsm event manual
show l2tp counters session fsm state current icrq
show l2tp counters session fsm state current manual
show l2tp counters session fsm state current ocrq
show l2tp counters session fsm state transition icrq
show l2tp counters session fsm state transition ocrq
show l2tp counters session fsm state transition manual
show vpdn statistics call fsm
show vpdn statistics mgr fsm
show vpdn session stats pending
show dapr routemanager summary
show dapr routemanager borderrouter summary
show dapr routemanager borderrouter neighbors
show dapr routemanager linkgroups
show dapr routemanager routetable
show dapr borderrouter summary
show dapr borderrouter interfaces
show dapr borderrouter neighbors
show ip nbar version
show ip nbar controlplane
show crypto ssl stats
show crypto ssl stats tunnel
show crypto tlstunnel stats
show crypto tlstunnel sessions
show raw reclaimed
show crypto key mypubkey rsa
show crypto call admission statistics
show crypto gkm
show crypto gkm rekey sa
show crypto gkm rekey sa detail
show crypto gkm gm
show crypto gkm gm acl
show crypto gkm gm pubkey
show crypto gkm gm rekey detail
show crypto gkm gm replay
show crypto gkm ipsec sa
show crypto gkm ks
show crypto gkm ks acl
show crypto gkm ks coop
show crypto gkm ks coop version
show crypto gkm ks identifier detail
show crypto gkm ks policy
show crypto gkm ks rekey
show crypto gkm ks replay
show crypto gkm diagnose events
show crypto gkm diagnose errors
show crypto gkm ks member total
show crypto gkm ks member total detail
show crypto gkm ks member summary
show license udi
show license udi standby
show license status
show license status standby
show inventory
show region
show dmvpn detail
show wsma techsupport
show wsma summary
show wsma profiles
show wsma services
show wsma history
show platform integrity sign nonce 177
show platform sudi certificate sign nonce 7149
show crypto ace slot 14 stats
show crypto ace redundancy
show crypto ace mace
show crypto eli all
show crypto ace collection
show crypto engine accelerator statistic
show crypto eli all
show platform hardware chassis active qfp datapath utilization
show platform hardware chassis active qfp statistics drop
show platform hardware cryptodevice status
show platform hardware cryptodevice statistics
show platform hardware cryptodevice registers backpressure
show platform hardware cryptodevice registers fpaqueueavailable
show platform hardware cryptodevice registers packetcount
show platform hardware qfp active infrastructure bqs queue output default interfacestring internal0/0/crypto:0 hierarchy
show buffers
show buffers usage
show platform
show platform resources
show platform software status controlprocessor brief
show romvar switch all
show platform software techsupport
show version installed
show version running
show platform hardware chassis active qfp infrastructure punt config cause
show platform hardware chassis active qfp infrastructure punt internalinterface
show platform hardware chassis active qfp infrastructure uidb internal0/0/rp:0 input config
show platform hardware chassis active qfp infrastructure uidb internal0/0/recycle:0 input config
show platform hardware chassis active qfp infrastructure uidb internal0/0/crypto:0 input config
show platform hardware chassis active qfp infrastructure uidb internal0/0/rp:0 output config
show platform hardware chassis active qfp infrastructure uidb internal0/0/recycle:0 output config
show platform hardware chassis active qfp infrastructure uidb internal0/0/crypto:0 output config
show platform hardware chassis active qfp infrastructure punt statistics interface 1
show platform hardware chassis active qfp infrastructure punt statistics interface 2
show platform hardware chassis active qfp infrastructure punt statistics interface 3
show platform hardware chassis active qfp infrastructure punt statistics interface 4
show platform hardware chassis active qfp infrastructure punt statistics type percause
show platform hardware chassis active qfp infrastructure punt statistics type globaldrop
show platform hardware chassis active qfp infrastructure punt statistics type puntdrop
show platform hardware chassis active qfp infrastructure punt statistics type injectdrop
show platform hardware chassis active qfp system state
show platform hardware chassis active qfp system transactions
show platform hardware chassis standby qfp system state
show platform hardware chassis standby qfp system transactions
show platform hardware chassis active qfp datapath infrastructure time basic
show platform hardware chassis active qfp infrastructure exmem statistics
show platform hardware chassis active qfp infrastructure exmem statistics user
show platform hardware chassis active qfp infrastructure exmem resource
show platform hardware chassis active qfp infrastructure exmem region
show platform hardware chassis active qfp infrastructure exmem table
show platform hardware chassis active qfp infrastructure bqs status
show platform hardware chassis standby qfp infrastructure bqs status
show platform hardware chassis active qfp infrastructure bqs sorter memory available
show platform hardware chassis standby qfp infrastructure bqs sorter memory available
show platform hardware chassis active qfp infrastructure bqs sorter memory free
show platform hardware chassis standby qfp infrastructure bqs sorter memory free
show platform hardware chassis standby qfp infrastructure bqs sorter memory utilization
show platform hardware chassis active qfp feature acl control
show platform hardware chassis active qfp feature acl tree
show platform hardware chassis active qfp feature tunnel state
show platform hardware chassis active qfp feature erspan state
show platform hardware chassis active qfp feature ess state
show platform hardware chassis active qfp feature ipfrag global
show hwprogrammable all
show bootlog chassis active R0
show bootlog chassis standby R0
show platform software diagnostic chassismanager chassis active r0 cpld
show platform software diagnostic chassismanager chassis active r0 status
show platform software diagnostic chassismanager chassis standby r0 cpld
show platform software diagnostic chassismanager chassis standby r0 status
show platform software mount chassis active r0 brief
show platform software ipc queuebased chassismanager chassis active r0 connection
show platform software ipc queuebased forwardingmanager chassis active r0 connection
show platform software ipc streambased chassismanager 0 connection
show platform software ipc streambased chassismanager 0 manager
show platform software ipc streambased forwardingmanager chassis active f0 connection
show platform software ipc streambased forwardingmanager chassis active f0 manager
show platform software ipc streambased forwardingmanager chassis active r0 connection
show platform software ipc streambased forwardingmanager chassis active r0 manager
show platform software ipc streambased hostmanager 0 connection
show platform software ipc streambased hostmanager 0 manager
show platform software ipc streambased hostmanager chassis active r0 connection
show platform software ipc streambased hostmanager chassis active r0 manager
show platform software ipc streambased shellmanager chassis active r0 connection
show platform software ipc streambased shellmanager chassis active r0 manager
show platform software mount 0
show platform soft objectmanager chassis active f0 statistic
show platform software peer chassismanager chassis active f0
show platform software peer chassismanager chassis active r0
show platform software peer forwardingmanager chassis active f0
show platform software peer forwardingmanager chassis active r0
show platform software peer shellmanager
show platform software peer shellmanager brief
show platform software process environment hostmanager 0
show platform software process environment hostmanager chassis active R0
show platform software process environment hostmanager chassis standby R0
show platform software process list 0
show platform software process list 0 summary
show platform software process list chassis active r0
show platform software process list chassis active r0 summary
show logging onboard slot R0 uptime latest
show logging onboard slot R0 temperature
show install summary
show facilityalarm status
show interfaces
show interfaces
show environment all
show logging
show pnp techsupport
show virtualservice
show ip traffic
show platform software mount r0
show platform software mount r1
show ip bgp summary
show ip nat statistics
show ip ports all
show process memory platform accounting
show platform hardware qfp active feature ipsec state
show crypto ikev2 stats
show history all
show arp summary
show adjacency summary
show ip route summary
show ipv6 route summary
show platform hardware qfp active datapath utilization
show platform hardware qfp active feature licbw oversubscription
show platform software ipsec policy statistics detail
show platform software ipsec fp active inventory
show tech-support wireless に含まれるコマンド一覧
show clock
show version
show runningconfig
show runningconfig all
show inventory
show platform
show license summary
show ntp associations
show redundancy
show ip http server status
show ip http server sessionmodule
show ip http server statistics
show ip ssh
show interfaces status
show ip interface brief
show vlan
show vlan group
show spanningtree summary
show vtp status
show logging
show platform software stackmgr chassis active R0 peertimeout
show platform software stackmgr chassis active R0 sdpcounters
show platform software stackmgr chassis standby R0 peertimeout
show platform software stackmgr chassis standby R0 sdpcounters
show wireless stats traceonfailure
show wireless mesh ap tree
show wireless mesh config
show ap summary
show ap slots
show ap tag summary
show ap apjoinprofile summary
show ap config general
show ap config slots
show ap image
show ap cdp neighbors
show ap autorf dot11 24ghz
show ap autorf dot11 5ghz
show ap dot11 24ghz bsscolor
show ap dot11 24ghz channel
show ap dot11 24ghz group
show ap dot11 24ghz monitor
show ap dot11 24ghz network
show ap dot11 24ghz profile
show ap dot11 24ghz summary
show ap dot11 24ghz summary extended
show ap dot11 24ghz txpower
show ap dot11 5ghz bsscolor
show ap dot11 5ghz channel
show ap dot11 5ghz group
show ap dot11 5ghz monitor
show ap dot11 5ghz network
show ap dot11 5ghz profile
show ap dot11 5ghz summary
show ap dot11 5ghz summary extended
show ap dot11 5ghz txpower
show ap dot11 dualband summary
show ap dot11 dualband summary extended
show ap auditreport summary
show wireless stats ap join summary
show ap rfprofile summary
show ap linkencryption
show wireless stats ap plumb
show wireless stats ap session termination
show wireless loadbalance ap affinity wncd 0
show wireless loadbalance ap affinity wncd 1
show wireless loadbalance ap affinity wncd 2
show wireless loadbalance ap affinity wncd 3
show wireless loadbalance ap affinity wncd 4
show wireless loadbalance ap affinity wncd 5
show wireless loadbalance ap affinity wncd 6
show wireless loadbalance ap affinity wncd 7
show wireless stats client detail
show wireless client steering
show wireless client calls active
show wireless client calls rejected
show wireless client sleepingclient
show wireless exclusionlist
show platform software wirelessclient chassis active R0 statistics
show platform software wirelessclient chassis active F0 statistics
show wireless client steering chassis standby R0
show wireless client calls active chassis standby R0
show wireless client calls rejected chassis standby R0
show wireless client sleepingclient chassis standby R0
show wireless client probing chassis standby R0
show wireless exclusionlist chassis standby R0
show wireless country configured chassis standby R0
show wireless tag rf summary chassis standby R0
show platform software wirelessclient chassis standby R0 statistics
show platform software wirelessclient chassis standby F0 statistics
show platform software bssid chassis active R0 statistics
show platform software radio chassis active R0 statistics
show platform software capwap chassis active R0 statistics
show platform software dtls chassis active R0 statistics
show platform software bssid chassis active F0 statistics
show platform software radio chassis active F0 statistics
show platform software capwap chassis active F0 statistics
show platform software dtls chassis active F0 statistics
show platform software ipc queuebased forwardingmanager chassis active R0 connection
show platform software ipc queuebased ios chassis active R0 connection
show platform software ipc queuebased smd chassis active R0 connection
show platform software ipc queuebased wireless chassis active R0 connection
show platform software ipc queuebased mobilityd chassis active R0 connection
show platform software ipc queuebased nmspd chassis active R0 connection
show platform software ipc queuebased rogued chassis active R0 connection
show platform software ipc queuebased rrmmgrd chassis active R0 connection
show platform software ipc queuebased wncd chassis active R0 connection
show platform software memory messaging smd chassis active R0
show platform software memory messaging wireless chassis active R0
show platform software memory messaging mobilityd chassis active R0
show platform software memory messaging nmspd chassis active R0
show platform software memory messaging rogued chassis active R0
show platform software memory messaging rrmmgrd chassis active R0
show platform software memory messaging wncd chassis active R0
show platform software memory wireless chassis active R0 brief
show platform software memory mobilityd chassis active R0 brief
show platform software memory nmspd chassis active R0 brief
show platform software memory rogued chassis active R0 brief
show platform software memory rrmmgrd chassis active R0 brief
show platform software memory wncd chassis active R0 brief
show platform software memory ios chassis active R0 brief
show platform software memory forwardingmanager chassis active R0 brief
show platform software memory forwardingmanager chassis active F0 brief
show platform software wlavc status wncmgrd
show platform software wlavc status wncd
show platform software wlavc status decoder
show platform software wlavc status cpexporter
show aaa server detail
show wireless country channels
show wireless detail
show wireless interface summary
show wireless loadbalancing
show wireless multicast
show wireless multicast group summary
show wireless stats multicast global
show ip igmp snooping wireless mcastipccount
show ip igmp snooping wireless mgid
show ip igmp snooping groups
show ip igmp snooping detail
show ip igmp snooping igmpv2tracking
show wireless mediastream group summary
show wireless mediastream message details
show wireless mediastream multicastdirect state
show wireless mediastream client summary
show wireless stats mobility
show wireless stats mobility messages
show wireless mobility summary
show wireless summary
show wireless wps summary
show wireless wps rogue adhoc summary
show wireless wps rogue ap rldp summary
show wireless wps rogue ap summary
show wireless wps rogue client summary
show wireless wps rogue autocontain
show wireless wps rogue ignorelist
show wireless wps rogue rule summary
show wireless wps rogue stats internal
show wlan all
show wlan summary
show wireless lawfulinterception status
show remotelan all
show remotelan summary
show guestlan all
show guestlan summary
show wireless guestlanmap summary
show ap dot11 24ghz mediastream rrc
show ap dot11 5ghz mediastream rrc
show wireless dtls connections
show wireless certification config
show wireless rfid summary
show nmsp capability
show nmsp notification interval
show nmsp status
show nmsp statistics connection
show nmsp subscription detail
show nmsp subscription group summary
show nmsp cloudservices summary
show nmsp cloudservices statistics
show networkassurance summary
show networkassurance sensorstatus summary
show platform software operationdatamanager odm chassis active r0 configure tbl_client_location_info
show platform software operationdatamanager odm chassis active r0 configure tbl_client_location_change_info
show ap hyperlocation detail
show ap hyperlocation cmx summary
show ap ble summary
show ap ble cmx summary
show ap location summary
show mdns servicetypes
show advanced eap
show wireless wgb summary
show wireless profile policy all
show wireless profile flex all
show wireless profile mesh all
show ap profile allprofiles
show wireless profile airtimefairness summary
show wireless profile ap summary
show wireless profile fabric summary
show wireless profile flex summary
show wireless profile mesh summary
show wireless profile policy summary
show wireless tag rf all
show wireless tag site all
show wireless tag policy all
show wireless tag site summary
show wireless tag policy summary
show wireless stats qos global
show ap cac voice
show platform software qos database
show platform software interface chassis active f0 brief
show platform software interface chassis standby f0 brief
show platform hardware chassis standby qfp feature wireless bssid summary
show platform software capwap chassis active r0
show platform software capwap chassis active f0
show platform software dtls chassis active r0
show platform software dtls chassis active f0
show wireless stats mobility messages chassis standby r0
show platform software capwap chassis standby r0
show platform software capwap chassis standby f0
show platform software dtls chassis standby r0
show platform software ipc queuebased mobilityd chassis standby R0 connection
show platform software memory messaging mobilityd chassis standby R0
show platform software dtls chassis standby f0
show platform hardware chassis standby qfp feature wireless capwap cppclient summary
show platform hardware chassis standby qfp feature wireless dtls cppclient summary
show platform hardware chassis standby qfp feature wireless capwap datapath summary
show platform hardware chassis standby qfp feature wireless dtls datapath statistics
show platform hardware chassis standby qfp feature wireless dtls datapath summary
show ap dot11 24ghz coverage
show ap dot11 5ghz coverage
show ap dot11 24ghz highdensity
show ap dot11 5ghz highdensity
show ap dot11 5ghz loadinfo
show ap dot11 24ghz loadinfo
show ap dot11 24ghz optimizedroaming
show ap dot11 5ghz optimizedroaming
show wireless stats ap dot11 24ghz optimizedroam
show wireless stats ap dot11 5ghz optimizedroam
show ap fra
show wireless bandselect
show ap status
show wireless dot11h
show ap dot11 24ghz cleanair config
show ap dot11 5ghz cleanair config
show ap dot11 24ghz cleanair airquality summary
show ap dot11 5ghz cleanair airquality summary
show ap dot11 24ghz summary extended chassis standby R0
show ap dot11 5ghz summary extended chassis standby R0
show ap dot11 dualband summary extended chassis standby R0
show ap dot11 24ghz bsscolor chassis standby R0
show ap dot11 5ghz bsscolor chassis standby R0
show platform hardware chassis active qfp bqs 0 packetbuffer utilization
show platform hardware chassis standby qfp bqs 0 packetbuffer utilization
show platform hardware chassis active qfp feature wireless capwap datapath statistics drop
show platform hardware chassis active qfp feature wireless wlclient datapath statistic drop
show platform hardware chassis active qfp feature wireless punt statistics
show platform hardware chassis active qfp feature wireless capwap cppclient statistics
show platform hardware chassis active qfp feature wireless capwap datapath statistics fragmentation
show platform hardware chassis active qfp feature wireless capwap datapath statistics reassembly
show platform hardware chassis active qfp feature wireless wlclient cppclient statistics provisioning
show platform hardware chassis active qfp feature wireless wlclient cppclient statistics guestlan
show platform hardware chassis active qfp feature wireless dtls cppclient statistics
show platform hardware chassis active qfp feature wireless dtls datapath statistics
show platform hardware chassis active qfp feature wireless ipsg cppclient statistics
show platform hardware chassis active qfp feature wireless ipsg datapath statistics global
show platform hardware chassis active qfp feature wireless etanalytics statistics
show platform hardware chassis active qfp feature wireless mgmtintf cppclient summary
show platform hardware chassis active qfp feature wireless mgmtintf datapath summary
show platform hardware chassis active qfp feature wireless fqdnfilter summary
show platform hardware chassis active qfp feature wireless etanalytics etapendingclienttree
show platform hardware chassis active qfp feature swport datapath lrntable
show platform hardware chassis active qfp feature swport datapath system
show platform hardware chassis active qfp feature swport datapath system statistics
show platform hardware chassis active qfp feature swport client mactable statistics
show platform hardware chassis active qfp feature switch_l2m client global
show platform software cgacl chassis active f0 statistics
show ip accesslist
show platform hardware chassis standby qfp datapath utilization
show platform hardware chassis standby qfp statistics drop
show platform hardware chassis standby qfp feature wireless capwap datapath statistics drop
show platform hardware chassis standby qfp feature wireless wlclient datapath statistic drop
show platform hardware chassis standby qfp feature wireless punt statistics
show platform hardware chassis standby qfp infrastructure punt statistics type percause
show platform hardware chassis standby qfp infrastructure exmem statistics
show platform hardware chassis standby qfp infrastructure exmem statistics user
show platform software capwap chassis standby F0 statistics
show platform hardware chassis standby qfp feature wireless capwap cppclient statistics
show platform hardware chassis standby qfp feature wireless capwap datapath statistics fragmentation
show platform hardware chassis standby qfp feature wireless capwap datapath statistics reassembly
show platform hardware chassis standby qfp feature wireless wlclient cppclient statistics provisioning
show platform hardware chassis standby qfp feature wireless wlclient cppclient statistics guestlan
show platform software dtls chassis standby F0 statistics
show platform hardware chassis standby qfp feature wireless dtls cppclient statistics
show platform hardware chassis standby qfp feature wireless ipsg cppclient statistics
show platform hardware chassis standby qfp feature wireless ipsg datapath statistics global
show platform hardware chassis standby qfp feature wireless etanalytics statistics
show platform software bssid chassis standby F0 statistics
show platform hardware chassis standby qfp feature wireless mgmtintf cppclient summary
show platform hardware chassis standby qfp feature wireless mgmtintf datapath summary
show platform hardware chassis standby qfp feature wireless fqdnfilter summary
show platform hardware chassis standby qfp feature wireless etanalytics etapendingclienttree
show platform hardware chassis standby qfp feature swport datapath lrntable
show platform hardware chassis standby qfp feature swport datapath system
show platform hardware chassis standby qfp feature swport datapath system statistics
show platform hardware chassis standby qfp feature swport client mactable statistics
show platform hardware chassis standby qfp feature switch_l2m client global
show platform software cgacl chassis standby f0 statistics
show platform software process database wncd 0 chassis standby R0 details WNCD_DB "table tbl_sm_upn_data"
show platform software process database wncd 0 chassis active R0 details WNCD_DB "table tbl_sm_upn_data"
show platform software process database wncd 1 chassis standby R0 details WNCD_DB "table tbl_sm_upn_data"
show platform software process database wncd 1 chassis active R0 details WNCD_DB "table tbl_sm_upn_data"
show platform software process database wncd 2 chassis standby R0 details WNCD_DB "table tbl_sm_upn_data"
show platform software process database wncd 2 chassis active R0 details WNCD_DB "table tbl_sm_upn_data"
show platform software process database wncd 3 chassis standby R0 details WNCD_DB "table tbl_sm_upn_data"
show platform software process database wncd 3 chassis active R0 details WNCD_DB "table tbl_sm_upn_data"
show platform software process database wncd 4 chassis standby R0 details WNCD_DB "table tbl_sm_upn_data"
show platform software process database wncd 4 chassis active R0 details WNCD_DB "table tbl_sm_upn_data"
show platform hardware chassis active qfp feature wireless udn cppclient summary
show platform hardware chassis active qfp feature wireless udn cppclient statistics all
show platform software udn chassis active R0
show platform software udn chassis active F0
show platform software udn port chassis active R0
show platform software udn port chassis active F0
show platform hardware chassis standby qfp feature wireless udn cppclient summary
show platform hardware chassis standby qfp feature wireless udn cppclient statistics all
show platform software udn chassis standby R0
show platform software udn chassis standby F0
show platform software udn port chassis standby R0
show platform software udn port chassis standby F0
show mdnssd summary
show mdnssd cache statistics
show mdnssd service statistics
show mdnssd cache
show mdnssd cache wired
show mdnssd statistics
show mdnssd statistics debug
show run mdnssd
show mdnssd ap
show mdnssd flexconnect summary
show mdnssd statistics flexconnect
show mdnssd servicepeer statistics
show mdnssd querydb
show ipc all
show platform software dbal ios chassis active R0 statistics
show platform software ipc queuebased dbm chassis active R0 connection
show platform software ipc streambased wncd chassis active R0 connection
show platform software ipc streambased ios chassis active R0 connection
show platform software ipc streambased dbm chassis active R0 connection
show radius statistics
show aaa memory stats all
show aaa servers detailed
show aaa memory detailed
show platform software memory messaging wncd chassis active R0 brief
show platform software memory data wncd chassis active R0 brief
show wireless client device count
show processes memory sorted
show processes cpu sorted
