attach topology view to DOM element
beasleyjon
This ought to be very simple but I can't find an example of how its done.
How would I attach a topology view to a DOM element other than the default 'body' element?
Eg - I have a <div> in my page somewhere and I want the topology to appear within that DIV, not attached directly to 'body'.
thanks.
you can also use this way, this is easier.
var app = new nx.ui.Application();
app.container(document.getElementById('app'));
topo.attach(app);
beasleyjon
I found the answer to this eventually.
The 'GetContainer' method should be used to attach the application element as a child of a DOM element   -
  var Shell = nx.define(nx.ui.Application, {
                methods: {
                    start: function () {
                        var mv = new com.cisco.MainView();
                        mv.attach(this);
                    getContainer: function () {
                        return new nx.dom.Element(element);
topo.attach(app);
thats makes more sense - setting the container property rather than overriding the getcontainer method. I missed that. thanks!
