Data is invalid according to the yang model.
IBMeR
I'm tring to create IPIP or GRE tunnel:
tunnel=native.interface.Tunnel()
tunnel.name=999
tunnel.description="test123"
tunnel.vrf.forwarding="Stateful"
tunnel.ip.address.primary.address="192.168.206.206"
tunnel.ip.address.primary.mask="255.255.255.252"
tunnel.ip.tcp.adjust_mss=1360
tunnel.tunnel.source="Loopback0"
destination=tunnel.Tunnel_.Destination()
destination.ipaddress_or_host="8.8.8.8"
tunnel.tunnel.destination=destination
tunnel.tunnel.mode.ipip=tunnel.tunnel.mode.Ipip()
native.interface.tunnel.append(tunnel)
crud.create(provider,tunnel)
And receive error like it:
2019-01-09 19:49:28,180 - ydk - INFO - Path where models are to be downloaded: /xxx/
2019-01-09 19:49:28,189 - ydk - INFO - Connected to x.x.x.x on port 830 using ssh with timeout of -1
2019-01-09 19:49:28,607 - ydk - INFO - Executing CRUD create operation on [Tunnel[name='999']]
2019-01-09 19:49:28,712 - ydk - ERROR - Data is invalid according to the yang model. Libyang error: Invalid value "" in "destination" element. Path: '/Cisco-IOS-XE-native:native/interface/Tunnel[name='999']/Cisco-IOS-XE-tunnel:tunnel/destination'
Traceback (most recent call last):
File "./createtunnel.py", line 66, in <module>
File "/usr/local/lib/python2.7/dist-packages/ydk/errors/error_handler.py", line 112, in helper
return func(self, provider, entity, *args, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/ydk/services/crud_service.py", line 49, in create
return self._crud.create(provider, entity)
File "/usr/lib/python2.7/contextlib.py", line 35, in __exit__
self.gen.throw(type, value, traceback)
File "/usr/local/lib/python2.7/dist-packages/ydk/errors/error_handler.py", line 82, in handle_runtime_error
_raise(_exc)
File "/usr/local/lib/python2.7/dist-packages/ydk/errors/error_handler.py", line 56, in _raise
raise exc
ydk.errors.YModelError: Invalid value "" in "destination" element. Path: /Cisco-IOS-XE-native:native/interface/Tunnel[name='999']/Cisco-IOS-XE-tunnel:tunnel/destination
Am I doing anything wrong or is it bug?
libyang=0.8.0
models for ios_xe=16.9.1
ios_xe=16.06.04
ygorelik
Hello IBMeR
I built a test based on your script, but could not reproduce the issue with YDK-0.8.0 and cisco-ios-xe 16.8.1 model bundle. I only can assume that model bundle that you are using and device are not fully compatible. I need more details of your environment to make the judgement.
FYI
My test script
from __future__ import absolute_import
import logging
from argparse import ArgumentParser
from ydk.providers import CodecServiceProvider
from ydk.services import CodecService
from ydk.models.cisco_ios_xe import Cisco_IOS_XE_native
def enable_logging(level):
log = logging.getLogger('ydk')
log.setLevel(level)
handler = logging.StreamHandler()
formatter = logging.Formatter(("%(asctime)s - %(name)s - %(levelname)s - %(message)s"))
handler.setFormatter(formatter)
log.addHandler(handler)
def build_tunnel(native):
tunnel.name=999
if __name__ == "__main__":
"""Execute main program."""
parser = ArgumentParser()
parser.add_argument("-v", "--verbose", help="print debugging messages", action="store_true")
args = parser.parse_args()
# log debug messages if verbose argument specified
if args.verbose:
enable_logging(logging.DEBUG)
# create codec provider and service
provider = CodecServiceProvider(type="xml")
codec = CodecService()
The run results
yan@ubuntu-yan:~/ydk-workspace/ydk-gen$ python ./scripts/tests/test_xe_tunnel.py
999
test123
Stateful
192.168.206.206
255.255.255.252
1360
Loopback0
8.8.8.8
Initial and Decoded entities are equal
yan@ubuntu-yan:~/ydk-workspace/ydk-gen$ pip list | grep ydk
ydk (0.8.1)
ydk-models-cisco-ios-xe (16.9.1)
ydk-models-cisco-ios-xr (6.5.1.post1)
ydk-models-ietf (0.1.5.post2)
ygorelik
Hello IBMeR
FYI
My test script
import logging
log.setLevel(level)
tunnel.name=999
if args.verbose:
The run results
999
test123
Stateful
192.168.206.206
255.255.255.252
1360
Loopback0
8.8.8.8
ydk (0.8.1)
Thank you.
You was right.
After upgrade IOS on router problem has solved.
