IS-IS configuration for Segment Routing (IPv4/IPv6)
saalvare
As part of the series of samples apps for configuring IS-IS, check out Segment Routing examples for IPv4 and IPv6 routing at:
https://github.com/CiscoDevNet/ydk-py-samples/tree/master/samples/basic/ydk/models/clns
As always, make sure you review the README file for instructions on how to use these apps.  You'll find it at:
By now, you can review and compare configuration examples for:
  • IS-IS single-area and inter-area for IPv4 and IPv6 routing
  • IS-IS TE with IPv4 routing
  • IS-IS Segment Routing for IPv4 and IPv6
That's a total of 16 sample apps to get started.  Not bad :-)
Enjoy!
khalilmeb
Hey saalvare,
Thanks for sharing!
First of all, the first given link is not working.
Secondly, I'm trying to configure IS-IS segment routing IPv4 on CSR 1000v deployed on AWS, from where would you recommend to start with?
