decoder upset of ISIS TE?!
mamikhai
using ISIS get oper samples, if the router isis is configured for TE I get traceback:
$ ./nc-read-xr-clns-isis-oper-22-ydk.py ssh://cisco:cisco@10.101.112.1:830
/usr/lib/python2.7/dist-packages/Crypto/Cipher/blockalgo.py:141: FutureWarning: CTR mode needs counter parameter, not IV
  self._cipher = factory.new(key, *args, **kwargs)
Traceback (most recent call last):
  File "./nc-read-xr-clns-isis-oper-22-ydk.py", line 146, in <module>
    isis = crud.read(provider, isis)
  File "/usr/local/lib/python2.7/dist-packages/ydk/services/crud_service.py", line 152, in read
    return provider.decode(payload, read_filter)
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/netconf_provider.py", line 91, in decode
    return self.sp_instance.decode(payload, read_filter)
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/_provider_plugin.py", line 132, in decode
    XmlDecoder._bind_to_object(payload, entity, self._get_capabilities())
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/_decoder.py", line 73, in _bind_to_object
    raise e
ydk.errors.YPYModelError: Value 0 already in leaf-list: te_ext_admin_sub
abhirame
Hi Magued,
This is similar to the issue seen in this thread: Re: CRUD read error on Cisco_IOS_XR_ip_rib_ipv4_operPlease see that thread for potential ways to handle this.
The bug ID tracking this is CSCvd74932 and it should be fixed in the upcoming 6.3.1 release of XR.
abhirame
Hi Magued,
Magued,
Note that YDK is doing the right thing here (detecting duplicates in leaf lists).  Some of these YDK scripts have help us identify issues in the NETCONF/YANG implementation in XR as you can see in this case.
