Error During generating module using ydk-go
starlana
Hi ,
I am trying to generate models from yang file using ydk-go.
Below error seeing
Traceback (most recent call last):
  File "./generate.py", line 495, in <module>
    output_directory = (generator.generate(options.bundle))
  File "/root/ydk-gen/ydkgen/__init__.py", line 93, in generate
    return self._generate_bundle(description_file)
  File "/root/ydk-gen/ydkgen/__init__.py", line 123, in _generate_bundle
    curr_bundle, all_bundles = resolver.resolve(tmp_file)
  File "/root/ydk-gen/ydkgen/resolver/bundle_resolver.py", line 299, in resolve
    self._resolve_bundles(root)
  File "/root/ydk-gen/ydkgen/resolver/bundle_resolver.py", line 318, in _resolve_bundles
    node = Bundle(self._resolve_bundle_file(d.uri),
  File "/root/ydk-gen/ydkgen/resolver/bundle_resolver.py", line 369, in _resolve_bundle_file
    resolved_file = self._resolve_file(src, self.cached_bundles_dir)
UnboundLocalError: local variable 'src' referenced before assignment
Command :
./generate.py --go --bundle /root/ydk-gen/profiles/bundles/ciscocfm_profile.json  -o  --output-directory /root/yangfiles/test2
I have attached the profiles for reference.
Appreciate your help on this.
ygorelik
Hello Rao
From the code it is clear that bundle profile does not set properly source of the yang models, which led to not handled error conditions. I will open a bug for this error. But on your side you need to build properly bundle profile. Here is a link to documentation on how to build the profile.
Please let me know if you need help.
Yan
Hi Yan,
I resolved all the dependencies but seeing below issue.
Error(s) occurred in YdkGenerator()!
Error occured: "/root/test2/.cache/models/[email protected]/tailf-ncs-devices.yang:1535: node tailf-ncs::connect is not found
/root/test2/.cache/models/[email protected]/tailf-ncs-devices.yang:1546: node tailf-ncs::sync-to is not found
/root/test2/.cache/models/[email protected]/tailf-ncs-devices.yang:1556: node tailf-ncs::sync-from is not found
/root/test2/.cache/models/[email protected]/tailf-ncs-devices.yang:1566: node tailf-ncs::disconnect is not found
/root/test2/.cache/models/[email protected]/tailf-ncs-devices.yang:1576: node tailf-ncs::check-sync is not found
/root/test2/.cache/models/[email protected]/tailf-ncs-devices.yang:1586: node tailf-ncs::check-yang-modules is not found
/root/test2/.cache/models/[email protected]/tailf-ncs-devices.yang:1597: node tailf-ncs::fetch-ssh-host-keys is not found
/root/test2/.cache/models/[email protected]/tailf-ncs-devices.yang:3644: node tailf-ncs::disconnect is not found
Can you please help on this?
Shanmukha Rao.
