Sample apps for XR LLDP using CRUD/gNMI
deom
Related image
Hello Community,
I came back with new YDK-py sample applications for ethernet LLDP configuration using Cisco native XR model and gNMI.
This set of sample apps configures XR LLDP using the gNMI provider and the CRUD service:
gn-create-xr-ethernet-lldp-cfg-10-ydk.py - create boilerplate
gn-create-xr-ethernet-lldp-cfg-20-ydk.py - Basic LLDP
gn-create-xr-ethernet-lldp-cfg-22-ydk.py - LLDP w/custom timers
gn-create-xr-ethernet-lldp-cfg-24-ydk.py - LLDP w/subintf and TLV select
gn-delete-xr-ethernet-lldp-cfg-10-ydk.py - delete boilerplate
gn-delete-xr-ethernet-lldp-cfg-20-ydk.py - delete all LLDP configuration
gn-read-xr-ethernet-lldp-cfg-10-ydk.py   - read boilerplate
gn-update-xr-ethernet-lldp-cfg-10-ydk.py - update boilerplate
The following link will direct you to the directory with python apps, JSON data, and CLI data about this set of sample applications.
https://github.com/CiscoDevNet/ydk-py-samples/tree/master/samples/basic/crud/gnmi/models/cisco-ios-xr/Cisco-IOS-XR-ethernet-lldp-cfg
Last June, we have posted about LLDP sample apps for OpenConfig/gNMI. You can check out the previous community posting for the LLDP OC/gNMI sample apps:
https://community.cisco.com/t5/yang-development-kit-ydk/sample-apps-for-configuring-lldp-using-openconfig-and-gnmi/m-p/3867828
Why don't you compare LLDP sample applications for XR/gNMI to OC/gNMI?
Have fun!
0 Replies 0
