Getting uri keypath not found error when trying to post Loopback interface to ios-xe-mgmt.cisco.com router
dmyooran71221
Community Member
Using postman I created a post request with to the url https://ios-xe-mgmt.cisco.com:9443/restconf/data/ieft-interfaces:interfaces with basic authentication of username: developer, password: C1sco12345, header of Content-Type: application/yang-data+json, and a body of {
"ieft-interfaces:interface": {
"name": "Loopback100",
"description": "What's up",
"type": "iana-if-type:softwareLoopback",
"enabled": true,
"ietf-ip:ipv4": {
"address": [
"ip": "172.16.100.1",
"netmask": "255.255.255.255"
but I get a URI keypath not found error
"errors": {
"error": [
"error-message": "uri keypath not found",
"error-tag": "invalid-value",
"error-type": "application"
Any help would be much appreciated
@dmyooran71221 I ran a POST request using
https://ios-xe-mgmt.cisco.com:9443/restconf/data/ietf-interfaces:interfaces
The error you have would indicate that you have a misinformed or wrong URI, but from what you have pasted this looks ok.
        "enabled": true,
        "ietf-ip:ipv4": {
            "address": [
csr1000v-1#sh ip int brief
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet1       10.10.20.48     YES NVRAM  up                    up
GigabitEthernet2       unassigned      YES NVRAM  administratively down down
GigabitEthernet3       unassigned      YES NVRAM  administratively down down
Loopback100            172.16.100.1    YES other  up                    up
csr1000v-1#
csr1000v-1#
csr1000v-1#sh run int lo100
Building configuration...
Current configuration : 93 bytes
interface Loopback100
 description What's up
 ip address 172.16.100.1 255.255.255.255
end
I could remove this with
https://ios-xe-mgmt.cisco.com:9443/restconf/data/ietf-interfaces:interfaces/interface=Loopback100
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
        "enabled": true,
        "ietf-ip:ipv4": {
            "address": [
csr1000v-1#
csr1000v-1#
end
Hope this helps.
Tried it again today and it worked might be an issue with postman I think. Thanks for your help!!
jcohoe
Can you try this with YANGSuite-RESTCONF plugin instead of Postman ? Is the same happen ?
I was actually wondering how I can get the YANGSuite-RESTCONF plugin the install only come with the NETCONF plugin and I don't see it available to install under admin->manage plugins. I download YANGSuite through pip on windows.
