GRACEFUL_DISCONNECT_WAIT_SEC does not work
rasmus.elmholt
Level 7
Level 7
Hi all
I have a small script that collects information from a list of devices, but it takes a long time.
I have found out that there is a disconnection time of 10s I think I am hitting.
I have found the documentation that says I can change the settings but when I test it out there is still a delay after the disconnect.
def atswrapper_bfd(dev_ip, cli_username, cli_password):
    atsbfd = None
    testbed = loader.load(
            "devices": {
                device["name"]: {
                    "connections": {
                        "cli": {
                            "protocol": "ssh",
                            "ip": dev_ip,
                            "init_exec_commands": [],
                            "init_config_commands": []
                        "settings": {
                            "GRACEFUL_DISCONNECT_WAIT_SEC": 1,
                            "POST_DISCONNECT_WAIT_SEC": 1
                    }, # Find a better way to do this: https://github.com/CiscoTestAutomation/genielibs/issues/12
                    "credentials": {
                        "default": {
                            "username": cli_username,
                            "password": cli_password,
                    "type": "Device",
                    "os": "iosxe"
    atsdevice = testbed.devices[device["name"]]
    atsdevice.connect(via='cli', log_stdout=True, learn_hostname=True, connection_timeout=2)
    atsbfd = atsdevice.parse('show bfd neighbors details')
    atsdevice.disconnect()
    return atsbfd
Hmm... from what you describe, it seems that the 10-second delay you are see is not directly related to GRACEFUL_DISCONNECT_WAIT_SEC / POST_DISCONNECT_WAIT_SEC settings. It might be caused by a combination a few things such as network latency, connection timeouts, or device-specific limitations. I am also unsure if the genielibs library might have additional logic for disconnection that overrides your settings too (guessing here)?
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hi @bigevilbeard
When I look at the logs it gives from log_stdout=True it completes the show command, hangs for 10 seconds and then continue.
I have tried to add the following lines and then the function is a lot faster.
    atsdevice.settings.GRACEFUL_DISCONNECT_WAIT_SEC = 0
    atsdevice.settings.POST_DISCONNECT_WAIT_SEC  = 0
But I still cannot get it to work when using the dictionary with configuration.
Not sure if this would work, but try this idea below, the GRACEFUL_DISCONNECT_WAIT_SEC and POST_DISCONNECT_WAIT_SEC settings are now set within the settings key of the device dictionary, it _should_ correctly set the values and reduce the delay between sending the show command and disconnecting from the device. (I hope!)
    atsbfd = None
            "devices": {
                device["name"]: {
                    "connections": {
                        "cli": {
                            "protocol": "ssh",
                            "ip": dev_ip,
                    "credentials": {
                        "default": {
                    "type": "Device",
                    "os": "iosxe",
                    "settings": {
                        "GRACEFUL_DISCONNECT_WAIT_SEC": 0,
                        "POST_DISCONNECT_WAIT_SEC": 0
    return atsbfd
