How to configure routing policies
saalvare
You can find basic apps for configuring routing policies at:
https://github.com/CiscoDevNet/ydk-py-samples/tree/master/samples/basic/ydk/models/policy
As usual, make sure you read the README file for basic apps.  It explains how apps are named and how to run them.
Check some of the policies against the examples in the guide to get started with OpenConfig:
https://github.com/CiscoDevNet/openconfig-getting-started/tree/master/models/policy
You'll get an idea of how the same policy can be configured with the XR native policy model or the OpenConfig routing policy model.
Enjoy!
0 Replies 0
