NetconfServiceProvider is not able to establish ssh tunnel
aligang1988
Level 4
Level 4
Hi !
I ran out of ideas and ask for help
Could you please explain issue which was lightly mentioned in the very end of this question ?:
Pointers on how to test YDK app on some opensource router with NETCONF support ?
Details:
I use YDK 0.7.1
When I try to execute this piece of code
from ydk.providers import NetconfServiceProvider
device = {
    "address":"192.168.2.11",
    "port":830,
    "username":"ali",
    "password":"password",
    "protocol":"ssh"
provider = NetconfServiceProvider(
    address=device["address"],
    username=device["username"],
    password=device["password"],
    protocol=device["protocol"],
    port=device["port"]
I get such output :
Traceback (most recent call last):
  File "ydk/trash/3.py", line 13, in <module>
    provider = NetconfServiceProvider(address=device["address"], username=device["username"], password=device["password"], protocol=device["protocol"], port=device["port"])
RuntimeError: YClientError: Could not connect to 192.168.2.11
I tried both versions of interpretation(2.7 and 3.5), but result is the same
According to trace ssh  handshake was started, but stuck somewhere on the stage of authentication
At the same time, openssh is able to successfully establish session and receive hello message from server
I ran such command
root@host~# ssh 192.168.2.11 -l ali -p 830 -s netconf
Password:
<!-- No zombies were killed during the creation of this user interface -->
<!-- user ali, class j-super-user -->
<nc:hello xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0">
   <nc:capabilities>
    <nc:capability>urn:ietf:params:netconf:base:1.0</nc:capability>
    <nc:capability>urn:ietf:params:netconf:capability:candidate:1.0</nc:capability>
    <nc:capability>urn:ietf:params:netconf:capability:confirmed-commit:1.0</nc:capability>
    <nc:capability>urn:ietf:params:netconf:capability:validate:1.0</nc:capability>
    <nc:capability>urn:ietf:params:netconf:capability:url:1.0?protocol=http,ftp,file</nc:capability>
    <nc:capability>urn:ietf:params:xml:ns:netconf:base:1.0</nc:capability>
    <nc:capability>urn:ietf:params:xml:ns:netconf:capability:candidate:1.0</nc:capability>
    <nc:capability>urn:ietf:params:xml:ns:netconf:capability:confirmed-commit:1.0</nc:capability>
    <nc:capability>urn:ietf:params:xml:ns:netconf:capability:validate:1.0</nc:capability>
    <nc:capability>urn:ietf:params:xml:ns:netconf:capability:url:1.0?protocol=http,ftp,file</nc:capability>
    <nc:capability>urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring</nc:capability>
    <nc:capability>http://xml.juniper.net/netconf/junos/1.0</nc:capability>
    <nc:capability>http://xml.juniper.net/dmi/system/1.0</nc:capability>
  </nc:capabilities>
  <nc:session-id>69773</nc:session-id>
</nc:hello>
Question: what is the reason of issue and how to workaround it ?
10 Replies 10
abhirame
Can you please enable and post the ydk logs:
http://ydk.cisco.com/py/docs/guides/introduction.html#logging
Thanks for your response !
Now code looks like this:
(ydk) testuser@host:~/ydk/tests$ cat 3.py
import logging
log_ydk = logging.getLogger('ydk')
log_ydk.setLevel(logging.DEBUG)
handler = logging.StreamHandler()
log_ydk.addHandler(handler)
device = {"address":"192.168.2.11", "port":830, "username":"ali", "password":"gp36s8s8", "protocol":"ssh"}
(ydk) testuser@host:~/ydk/tests$ python3 3.py
##Then it stuck for approx 2 minutes , and output provided:
Connection error occurred: Starting the SSH session failed (Socket error: disconnected)
Trace: Error code 2.
  File "3.py", line 12, in <module>
Thanks. Doesn't look like the log contains much information. Is that all the output you saw?
Based on the message here:
Re: Pointers on how to test YDK app on some opensource router with NETCONF support ?
It looks like the problem is that your server expects a openssh connection whereas the default implementation of YDK is for llibssh.
Internally, YDK uses the 3rd party library libnetconf to establish netconf connections. From their docs, looks like libnetconf provides an option to disable lissh at compile time using --disable-libssh option.
This is the line in YDK CMake file where libnetconf is compiled.
CONFIGURE_COMMAND "./configure"
to
CONFIGURE_COMMAND "./configure --disable-libssh"
To make the above, follow the below steps. After changing the above line, you can regenerate and install libydk & the ydk core python package:
# First uninstall libydk
# Ubuntu
apt-get remove libydk
# Centos
rpm -q libydk
# Remove ydk python core
pip uninstall ydk
# Clone ydk-gen and checkout 0.7.1 tag
git clone https://github.com/CiscoDevNet/ydk-gen.git -b 0.7.1
cd ydk-gen
# Change the above line and save the file
vi sdk/cpp/core/CMakeLists.txt
# Generate & install libydk
./generate.py --libydk
[sudo] make -C gen-api/cpp/ydk/build install
# Generate & install ydk python core
./generate.py --core --python
pip install gen-api/python/ydk/dist/ydk-07.1*.tar.gz
Yes, unfortunately that is all log output.
after changing  line in ydk-gen/sdk/cpp/core/CMakeLists.txt
from
to
Running of  sudo make -C gen-api/cpp/ydk/build install
Brought to such result
[  4%] Performing configure step for 'project_libnetconf'
/bin/sh: 1: ./configure --disable-libssh: not found
CMakeFiles/project_libnetconf.dir/build.make:108: recipe for target 'project_libnetconf/src/project_libnetconf-stamp/project_libnetconf-configure' failed
make[2]: *** [project_libnetconf/src/project_libnetconf-stamp/project_libnetconf-configure] Error 127
make[2]: Leaving directory '/home/alex-limonov/ydk0.7.1_py3.5/ydk-gen/gen-api/cpp/ydk/build'
CMakeFiles/Makefile2:174: recipe for target 'CMakeFiles/project_libnetconf.dir/all' failed
make[1]: *** [CMakeFiles/project_libnetconf.dir/all] Error 2
make[1]: Leaving directory '/home/alex-limonov/ydk0.7.1_py3.5/ydk-gen/gen-api/cpp/ydk/build'
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2
make: Leaving directory '/home/alex-limonov/ydk0.7.1_py3.5/ydk-gen/gen-api/cpp/ydk/build'
Then I changed line in  gen-api/cpp/ydk/build/CMakeFiles/project_libnetconf.dir/build.make
from
cd /home/alex-limonov/ydk0.7.1_py3.5/ydk-gen/gen-api/cpp/ydk/build/project_libnetconf/src/project_libnetconf && "./configure --disable-libssh"
to
cd /home/alex-limonov/ydk0.7.1_py3.5/ydk-gen/gen-api/cpp/ydk/build/project_libnetconf/src/project_libnetconf && ./configure --disable-libssh
And ran sudo make -C gen-api/cpp/ydk/build install again.
This time another error were returned and pretty later
CMakeFiles/ydk.dir/build.make:662: recipe for target 'CMakeFiles/ydk.dir/src/netconf_ssh_client.cpp.o' failed
make[2]: *** [CMakeFiles/ydk.dir/src/netconf_ssh_client.cpp.o] Error 1
CMakeFiles/Makefile2:100: recipe for target 'CMakeFiles/ydk.dir/all' failed
make[1]: *** [CMakeFiles/ydk.dir/all] Error 2
(more verbse description of error in attachement)
Thanks !
Apologies. Please remove the quotes as below:
from
to
CONFIGURE_COMMAND ./configure --disable-libssh
As for the other errors, looks like there needs to be some more changes done on YDK side. We can take a look. Based on current schedule, this could take a while. But in the meanwhile, feel free to take a shot at making any code changes that can help you with this.
Understood !
Thank you for your time !
Whether I could find  a workaround  I will post here
I could make ssh connection work
To do this i have downloaded libssh sources and build it locally
## first removed all existing libssh packages from my system and then :
git clone https://git.libssh.org/projects/libssh.git libssh
cd libssh
mkdir bin
cd bin
cmake  -DCMAKE_BUILD_TYPE=RelWithDebInfo  ..
cmake .
apt install checkinstall
sudo checkinstall
After that I  followed your recommendation  to generate & install libydk and  ydk-python-core!
Thanks !
Glad it worked!
I have same problem, and have no luck fixing it. I am stuck in building libydk. I get same error line in aligang1988 attached output file. Maybe I am using wrong libssh version?
Solved, by using libssh version 0.7.7 and did not use "--disable-libssh" while building cpp core.
Seems that problem is with libssh version 0.6.4 which is default in docker image.
