RestconfServiceProvider doesn't connect to my device
vadigreg
Hello, I'm trying to connect a restconf provider (in python) to my device. However when I try I get the following error:
2020-06-08 18:59:32,530 - ydk - INFO - Unable to retrieve restconf root. Assuming '/restconf' as the root
2020-06-08 18:59:32,530 - ydk - INFO - Ready to communicate with http://10.51.65.23:443/restconf using http
Traceback (most recent call last):
  File "main.py", line 46, in <module>
    encoding=EncodingFormat.JSON)
RuntimeError: invalid format string
This is my code:
        repo = Repository()
        provider = RestconfServiceProvider(repo=repo,
                                           address=args.restconf.hostname,
                                           port=args.restconf.port,
                                           username=args.restconf.username,
                                           password=args.restconf.password,
How can I set protocol to HTTPS?
Thanks.
yangorelik
Hello
This is well known YDK limitation #917, which requires significant new development. Your company would need to come up with some resources to support this new development.
Yan Gorelik
YDK Solutions
yangorelik
Hello
Yan Gorelik
YDK Solutions
