10-27-2021 06:31 AM - edited 10-27-2021 08:41 AM
I'm trying to install yangsuite on linux (Kali on WSL), but I received this error:
Building docker containers... Traceback (most recent call last): File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 699, in urlopen httplib_response = self._make_request( File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 394, in _make_request conn.request(method, url, **httplib_request_kw) File "/usr/lib/python3.9/http/client.py", line 1279, in request self._send_request(method, url, body, headers, encode_chunked) File "/usr/lib/python3.9/http/client.py", line 1325, in _send_request self.endheaders(body, encode_chunked=encode_chunked) File "/usr/lib/python3.9/http/client.py", line 1274, in endheaders self._send_output(message_body, encode_chunked=encode_chunked) File "/usr/lib/python3.9/http/client.py", line 1034, in _send_output self.send(msg) File "/usr/lib/python3.9/http/client.py", line 974, in send self.connect() File "/usr/lib/python3/dist-packages/docker/transport/unixconn.py", line 30, in connect sock.connect(self.unix_socket) FileNotFoundError: [Errno 2] No such file or directory During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/requests/adapters.py", line 439, in send resp = conn.urlopen( File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 755, in urlopen retries = retries.increment( File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 532, in increment raise six.reraise(type(error), error, _stacktrace) File "/usr/lib/python3/dist-packages/six.py", line 718, in reraise raise value.with_traceback(tb) File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 699, in urlopen httplib_response = self._make_request( File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 394, in _make_request conn.request(method, url, **httplib_request_kw) File "/usr/lib/python3.9/http/client.py", line 1279, in request self._send_request(method, url, body, headers, encode_chunked) File "/usr/lib/python3.9/http/client.py", line 1325, in _send_request self.endheaders(body, encode_chunked=encode_chunked) File "/usr/lib/python3.9/http/client.py", line 1274, in endheaders self._send_output(message_body, encode_chunked=encode_chunked) File "/usr/lib/python3.9/http/client.py", line 1034, in _send_output self.send(msg) File "/usr/lib/python3.9/http/client.py", line 974, in send self.connect() File "/usr/lib/python3/dist-packages/docker/transport/unixconn.py", line 30, in connect sock.connect(self.unix_socket) urllib3.exceptions.ProtocolError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory')) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/docker/api/client.py", line 214, in _retrieve_server_version return self.version(api_version=False)["ApiVersion"] File "/usr/lib/python3/dist-packages/docker/api/daemon.py", line 181, in version return self._result(self._get(url), json=True) File "/usr/lib/python3/dist-packages/docker/utils/decorators.py", line 46, in inner return f(self, *args, **kwargs) File "/usr/lib/python3/dist-packages/docker/api/client.py", line 237, in _get return self.get(url, **self._set_request_timeout(kwargs)) File "/usr/lib/python3/dist-packages/requests/sessions.py", line 555, in get return self.request('GET', url, **kwargs) File "/usr/lib/python3/dist-packages/requests/sessions.py", line 542, in request resp = self.send(prep, **send_kwargs) File "/usr/lib/python3/dist-packages/requests/sessions.py", line 655, in send r = adapter.send(request, **kwargs) File "/usr/lib/python3/dist-packages/requests/adapters.py", line 498, in send raise ConnectionError(err, request=request) requests.exceptions.ConnectionError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory')) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/bin/docker-compose", line 33, in <module> sys.exit(load_entry_point('docker-compose==1.27.4', 'console_scripts', 'docker-compose')()) File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 67, in main command() File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 123, in perform_command project = project_from_options('.', options) File "/usr/lib/python3/dist-packages/compose/cli/command.py", line 60, in project_from_options return get_project( File "/usr/lib/python3/dist-packages/compose/cli/command.py", line 131, in get_project client = get_client( File "/usr/lib/python3/dist-packages/compose/cli/docker_client.py", line 41, in get_client client = docker_client( File "/usr/lib/python3/dist-packages/compose/cli/docker_client.py", line 170, in docker_client client = APIClient(**kwargs) File "/usr/lib/python3/dist-packages/docker/api/client.py", line 197, in __init__ self._version = self._retrieve_server_version() File "/usr/lib/python3/dist-packages/docker/api/client.py", line 221, in _retrieve_server_version raise DockerException( docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
I have no idea, that file it is complaining about. Any hint from the community?
10-27-2021 09:37 AM
YANG Suite requires python 3.6, 3.7, or 3.8. It has not been validated on python 3.9.
11-03-2021 11:58 AM
Hello @Tobias Heisele,
DevNet also has a YANG Suite external mailer in case you have more questions in the future:
yangsuite-support-ext(mailer list) <yangsuite-support-ext@cisco.com>
