Unable to read interfaces with ydk 0.7.0
sihart
Hi all,
The following code worked before I updated to ydk 0.7.0.  Now I am receiving an error when a ydk.errors.YPYCoreError when I run it.  I have tested against several virtual devices running XR (code level 6.0 and 6.2.1 as well as XR router in YDK Sandbox 2.1, with all the same result.
I have run the code in both my native Mac environment as well as on Vagrant.  Any help would be appreciated
CODE being Run
from ydk.services import CRUDService
from ydk.providers import NetconfServiceProvider
from ydk.models.cisco_ios_xr import Cisco_IOS_XR_ifmgr_cfg as xr_ifmgr_cfg
from ydk.services.codec_service import CodecService
from ydk.providers.codec_provider import CodecServiceProvider
crud = CRUDService()
codec = CodecService()
codec_provider = CodecServiceProvider(type='xml')
provider = NetconfServiceProvider(address=<********>
   port=830,
   username=<*****>,
   password=<*****>,
   protocol='ssh')
interface_configurations = xr_ifmgr_cfg.InterfaceConfigurations()
interface_configuration = interface_configurations.InterfaceConfiguration()
interface_configuration.interface_name = 'Loopback0'
interface_configurations.interface_configuration.append(interface_configuration)
read_data = crud.read(provider, interface_configurations)
print(codec.encode(codec_provider, read_data))
TRACEBACK
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/usr/local/lib/python2.7/dist-packages/ydk/errors/error_handler.py", line 112, in helper
    return func(self, provider, entity, *args, **kwargs)
  File "/usr/local/lib/python2.7/dist-packages/ydk/services/crud_service.py", line 35, in read
    return self._crud.read(provider, read_filter)
  File "/usr/lib/python2.7/contextlib.py", line 35, in __exit__
    self.gen.throw(type, value, traceback)
  File "/usr/local/lib/python2.7/dist-packages/ydk/errors/error_handler.py", line 82, in handle_runtime_error
    _raise(_exc)
  File "/usr/local/lib/python2.7/dist-packages/ydk/errors/error_handler.py", line 56, in _raise
    raise exc
ydk.errors.YPYCoreError:  Couldn't fetch child entity 'Cisco-IOS-XR-ipv4-io-cfg:ipv4-network' in parent /Cisco-IOS-XR-ifmgr-cfg:interface-configurations/interface-configuration[active='act'][interface-name='Loopback0']
abhirame
Can you please raise an issue at and we can take a look at it?
YDK-Gen Issues
