YDK 0.7.1 - Golang 1.6.2
m.m.mazurek
While attempting to run ydk code with go on my Ubuntu machine (1.6.2, same version is in the docker container) I get:
/usr/lib/go-1.6/src/github.com/CiscoDevNet/ydk-go/ydk/types/types.go:331: syntax error: unexpected = in type declaration
/usr/lib/go-1.6/src/github.com/CiscoDevNet/ydk-go/ydk/types/types.go:342: syntax error: unexpected = in type declaration
That is caused by alias that is not supported in this go release. I tried with 1.9.7 & 1.10.3 but I was getting some other errors:
go build github.com/CiscoDevNet/ydk-go/ydk: invalid flag in #cgo LDFLAGS: -fprofile-arcs
Therefore my question is - which exact golang version shall be used to compile ?
Br,
M
abhirame
YDK has been tested with Go 1.9.2. Can you please try with this version?
abhirame
OK. Will try and update the discussion.
I tested with 1.9.2 and code compilation is successful. Thank you.
