Tools
I'm building NetDocAi, a tool that turns Cisco network configurations into structured documentation and highlights potential configuration issues.I'm opening a small Phase 1 beta and looking for a few people who can test it and give honest technical ...
Hello Fellas, I am having an issue with the DevNet CML sandbox, when trying to connect to my local Ubuntu VM inside VirtualBox. My host computer is a Windows 10. I do have connectivity from the Ubuntu VM to the nodes inside CML. I can ping them just ...
I have been able to use this yang model to get a lot information about AP: https://wlc_ip/restconf/data/Cisco-IOS-XE-wireless-access-point-oper:access-point-oper-dataBut that YANG model does not have any information about APs that goes down, and fall...
AndreasWA by • Community Member
  • 1999 Views
  • 3 replies
 does anyone know of an open-config path that returns the max speed of an interface for cisco c9ks running 17.9?  I tried /oc-if:/interfaces/interface/ethernet/config/port-speed - Doesn't exist /oc-if:interfaces/interface/ethernet/state/negotiated-po...
munroe by • Visitor
  • 692 Views
  • 1 replies
Hi all,I'd like to parse multiple L3Out bgp table on my border leaf but I can't find any suitable command parser in genie. I've tried multiple commands that are on the parser list but none of them worked for me.  Isn't it possible to parse ACI"show b...
rchrdbkn by • Community Member
  • 1017 Views
  • 2 replies
Made a post in the wrong forum. Hopefully this is the correct one. Does anyone here have any experience with AI automation tools? We have been looking closely at tools like Cisco AI Canvas, and other 3rd party tools like mploi.ai and was curious if a...
Hi, I'm trying to use gnmic to gather some QFP stats on a Cisco C83000-1N1S-6T running IOS 17.12.04 I managed to fetch simple counters like: gnmic get --path '/interfaces/interface[name=GigabitEthernet0/0/0]/state' But I can't figure out the right pa...
dbillon by • Level 3
  • 3349 Views
  • 8 replies
  • 1 Helpful votes
pyATS has HTML log viewer which spins local web server when using the command "pyats logs view"Seems the test data comes from a .zip file which gets created after tests has been executed.How can that .zip file be converted to HTML for local viewing i...
l00pback by • Frequent Visitor
  • 1663 Views
  • 3 replies
I would like to have multiple test suite .py files which will be run as a bundle by pyATS job.How can I have single defined common setup/cleanup routines which will run once whenever the pyATS job is executed instead of having the same common setup/c...
  • 985 Views
  • 1 replies
