YDK package will not install on MacOS Mojave
Daniel Felix Da Silva
Hello team, this seems to be an old issue but I could not find a solution on this forum besides moving the ydk to a linux machine instead of a Mac OS, it would be good if there was a solution to this.
I have followed all pre-req documented on http://ydk.cisco.com/py/docs/getting_started.html#system-requirements but still getting an error when trying to install ydk package on Mac OS:
DFELIXDA-M-X0YC:~ dfelixda$ pip3 install ydk
Collecting ydk
  Using cached ydk-0.8.4.tar.gz (33 kB)
Requirement already satisfied: pybind11>=2.1.1 in /usr/local/lib/python3.8/site-packages (from ydk) (2.5.0)
Building wheels for collected packages: ydk
  Building wheel for ydk (setup.py) ... error
  ERROR: Command errored out with exit status 1:
   command: /usr/local/opt/python@3.8/bin/python3.8 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/private/var/folders/7_/65p28bss3txdfm60vb6vc_0h0000gn/T/pip-install-0w_pqw1j/ydk/setup.py'"'"'; __file__='"'"'/private/var/folders/7_/65p28bss3txdfm60vb6vc_0h0000gn/T/pip-install-0w_pqw1j/ydk/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /private/var/folders/7_/65p28bss3txdfm60vb6vc_0h0000gn/T/pip-wheel-axlejbai
       cwd: /private/var/folders/7_/65p28bss3txdfm60vb6vc_0h0000gn/T/pip-install-0w_pqw1j/ydk/
  Complete output (104 lines):
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.macosx-10.14-x86_64-3.8
  creating build/lib.macosx-10.14-x86_64-3.8/ydk
  copying ydk/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk
  copying ydk/exthook.py -> build/lib.macosx-10.14-x86_64-3.8/ydk
  creating build/lib.macosx-10.14-x86_64-3.8/ydk/filters
  copying ydk/filters/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/filters
  creating build/lib.macosx-10.14-x86_64-3.8/ydk/types
  copying ydk/types/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/types
  copying ydk/types/py_types.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/types
  creating build/lib.macosx-10.14-x86_64-3.8/ydk/_core
  copying ydk/_core/_importer.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/_core
  copying ydk/_core/_dm_meta_info.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/_core
  copying ydk/_core/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/_core
  creating build/lib.macosx-10.14-x86_64-3.8/ydk/providers
  copying ydk/providers/netconf_provider.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/providers
  copying ydk/providers/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/providers
  copying ydk/providers/codec_provider.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/providers
  creating build/lib.macosx-10.14-x86_64-3.8/ydk/path
  copying ydk/path/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/path
  creating build/lib.macosx-10.14-x86_64-3.8/ydk/ext
  copying ydk/ext/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/ext
  creating build/lib.macosx-10.14-x86_64-3.8/ydk/entity_utils
  copying ydk/entity_utils/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/entity_utils
  copying ydk/entity_utils/entity_utils.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/entity_utils
  creating build/lib.macosx-10.14-x86_64-3.8/ydk/models
  copying ydk/models/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/models
  creating build/lib.macosx-10.14-x86_64-3.8/ydk/errors
  copying ydk/errors/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/errors
  copying ydk/errors/error_handler.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/errors
  creating build/lib.macosx-10.14-x86_64-3.8/ydk/logging
  copying ydk/logging/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/logging
  creating build/lib.macosx-10.14-x86_64-3.8/ydk/services
  copying ydk/services/netconf_service.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/services
  copying ydk/services/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/services
  copying ydk/services/executor_service.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/services
  copying ydk/services/crud_service.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/services
  copying ydk/services/codec_service.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/services
  creating build/lib.macosx-10.14-x86_64-3.8/ydk/path/sessions
  copying ydk/path/sessions/netconf_session.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/path/sessions
  copying ydk/path/sessions/__init__.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/path/sessions
  copying ydk/path/sessions/restconf_session.py -> build/lib.macosx-10.14-x86_64-3.8/ydk/path/sessions
  running build_ext
  -- The C compiler identification is AppleClang 10.0.1.10010046
  -- The CXX compiler identification is AppleClang 10.0.1.10010046
  -- Detecting C compiler ABI info
  -- Detecting C compiler ABI info - done
  -- Check for working C compiler: /Library/Developer/CommandLineTools/usr/bin/cc - skipped
  -- Detecting C compile features
  -- Detecting C compile features - done
  -- Detecting CXX compiler ABI info
  -- Detecting CXX compiler ABI info - done
  -- Check for working CXX compiler: /Library/Developer/CommandLineTools/usr/bin/c++ - skipped
  -- Detecting CXX compile features
  -- Detecting CXX compile features - done
  python version: 3.8
  -- Found PythonLibs: /usr/local/Frameworks/Python.framework/Versions/3.8/lib/libpython3.8.dylib (found version "3.8.5")
  pybind11 include: /usr/local/lib/python3.8/site-packages/pybind11/include;/usr/local/lib/python3.8/site-packages/pybind11/include
  -- Configuring done
  -- Generating done
  -- Build files have been written to: /private/var/folders/7_/65p28bss3txdfm60vb6vc_0h0000gn/T/pip-install-0w_pqw1j/ydk/build/temp.macosx-10.14-x86_64-3.8
  Scanning dependencies of target ydk_
  [ 50%] Building CXX object CMakeFiles/ydk_.dir/python.cpp.o
  /private/var/folders/7_/65p28bss3txdfm60vb6vc_0h0000gn/T/pip-install-0w_pqw1j/ydk/python.cpp:22:10: fatal error: 'ydk/path_api.hpp' file not found
  #include <ydk/path_api.hpp>
  1 error generated.
  make[2]: *** [CMakeFiles/ydk_.dir/python.cpp.o] Error 1
  make[1]: *** [CMakeFiles/ydk_.dir/all] Error 2
  make: *** [all] Error 2
  Traceback (most recent call last):
    File "<string>", line 1, in <module>
    File "/private/var/folders/7_/65p28bss3txdfm60vb6vc_0h0000gn/T/pip-install-0w_pqw1j/ydk/setup.py", line 111, in <module>
      setup(
    File "/usr/local/lib/python3.8/site-packages/setuptools/__init__.py", line 165, in setup
      return distutils.core.setup(**attrs)
    File "/usr/local/Cellar/python@3.8/3.8.5/Frameworks/Python.framework/Versions/3.8/lib/python3.8/distutils/core.py", line 148, in setup
      dist.run_commands()
    File "/usr/local/Cellar/python@3.8/3.8.5/Frameworks/Python.framework/Versions/3.8/lib/python3.8/distutils/dist.py", line 966, in run_commands
      self.run_command(cmd)
    File "/usr/local/Cellar/python@3.8/3.8.5/Frameworks/Python.framework/Versions/3.8/lib/python3.8/distutils/dist.py", line 985, in run_command
      cmd_obj.run()
    File "/usr/local/lib/python3.8/site-packages/wheel/bdist_wheel.py", line 223, in run
      self.run_command('build')
    File "/usr/local/Cellar/python@3.8/3.8.5/Frameworks/Python.framework/Versions/3.8/lib/python3.8/distutils/cmd.py", line 313, in run_command
      self.distribution.run_command(command)
      cmd_obj.run()
    File "/usr/local/Cellar/python@3.8/3.8.5/Frameworks/Python.framework/Versions/3.8/lib/python3.8/distutils/command/build.py", line 135, in run
      self.run_command(cmd_name)
      cmd_obj.run()
    File "/private/var/folders/7_/65p28bss3txdfm60vb6vc_0h0000gn/T/pip-install-0w_pqw1j/ydk/setup.py", line 68, in run
      self.build_extension(ext)
    File "/private/var/folders/7_/65p28bss3txdfm60vb6vc_0h0000gn/T/pip-install-0w_pqw1j/ydk/setup.py", line 101, in build_extension
      subprocess.check_call([cmake_executable, '--build', '.'], cwd=self.build_temp)
    File "/usr/local/Cellar/python@3.8/3.8.5/Frameworks/Python.framework/Versions/3.8/lib/python3.8/subprocess.py", line 364, in check_call
      raise CalledProcessError(retcode, cmd)
  subprocess.CalledProcessError: Command '['cmake', '--build', '.']' returned non-zero exit status 2.
  ERROR: Failed building wheel for ydk
  Running setup.py clean for ydk
Failed to build ydk
The error seems related to this file:
But I have checked and it is present o the correct directory:
DFELIXDA-M-X0YC:~ dfelixda$ cd /usr/local/include/ydk
DFELIXDA-M-X0YC:ydk dfelixda$ ls
capabilities_parser.hpp		gnmi_client.hpp			network_topology.hpp
codec_provider.hpp		gnmi_path_api.hpp		opendaylight_parser.hpp
codec_service.hpp		gnmi_provider.hpp		opendaylight_provider.hpp
common_utilities.hpp		gnmi_service.hpp		path_api.hpp
crud_service.hpp		gnmi_util.hpp			restconf_client.hpp
entity_data_node_walker.hpp	ietf_parser.hpp			restconf_provider.hpp
entity_lookup.hpp		json.hpp			service_provider.hpp
entity_util.hpp			logger.hpp			types.hpp
errors.hpp			logging_callback.hpp		validation_service.hpp
executor_service.hpp		netconf_client.hpp		xml_subtree_codec.hpp
filters.hpp			netconf_model_provider.hpp	xml_util.hpp
gnmi.grpc.pb.h			netconf_provider.hpp		ydk.h
gnmi.pb.h			netconf_service.hpp		ydk_gnmi.h
I have tried building the libydk myself with same error.
Daniel
yangorelik
I am also running YDK on MacOS Mojave. Honestly, it was not easy to make it work.
First of all you need install YDK core library from source, because libydk package located in artifactory was built on Sierra (10.12), which uses older C/C++ compiler clang-8. Therefore I am not sure if that package will be fully compatible with clang-10 in Mojave. It is though worth trying for the YDK community benefits.
Second. Based on the error, the cmake cannot find YDK C++ header file ydk/path_api.hpp. This case has been documented here. Assuming that you have successfully installed the YDK core package, you need to define couple of environment variables to help cmake to find the header files:
export C_INCLUDE_PATH=/usr/local/include
export CPLUS_INCLUDE_PATH=/usr/local/include
Yan Gorelik
YDK Solutions
yangorelik
Yan Gorelik
YDK Solutions
Thank you my friend... it has worked now...
As reference to anyone else with this issue, I have manually installed ydk from its source at:
https://github.com/CiscoDevNet/ydk-gen
Then just include the paths.
