ydk085: Output of parsed fields are empty for a container in OC model
ruppunda
Hi Team,
One of the container(cpu/utilization/state) in openconfig-platform-cpu model is returning data when we send rpc request , but while I Parse the output , the fields are empty . Able to fetch the data for other containers in the same model. I am using latest ydk models Any help is appreciated.
In [121]: rpc_out.component[0].cpu.utilization.state.min
In [122]: rpc_out.component[0].state
Out[122]: <ydk.models.cisco_ios_xr.openconfig_platform.Components.Component.State at 0x2b69efb9d258>
In [123]: rpc_out.component[0].state.type
Out[123]: <ydk.models.cisco_ios_xr.openconfig_platform_types.CONTROLLERCARD at 0x2b69f07d5678>
In [124]: rpc_out.component[0].state.id
Out[124]: '110593'
In [125]: rpc_out.component[0].state.location
Out[125]: '0/RP0'
Here is the output from read(), do let me know if I am missing out anything.
rpc_out = self.device.read(comp.cpu.utilization.state)
2022-04-19 12:58:37,617 - ydk - Info---- - Executing CRUD read operation on [openconfig-platform:components]
Info----:ydk:Executing CRUD read operation on [openconfig-platform:components]
2022-04-19 12:58:37,617 - ydk - Info---- - Executing 'get' RPC on [openconfig-platform:components]
Info----:ydk:Executing 'get' RPC on [openconfig-platform:components]
2022-04-19 12:58:37,619 - ydk - Debug--- - Getting new modules for path 'ietf-netconf:get'
Debug---:ydk:Getting new modules for path 'ietf-netconf:get'
2022-04-19 12:58:37,620 - ydk - Debug--- - Loading module 'ietf-netconf', revision ''
Debug---:ydk:Loading module 'ietf-netconf', revision ''
2022-04-19 12:58:37,620 - ydk - Debug--- - The module 'ietf-netconf' schema has already been populated in YDK repository
Debug---:ydk:The module 'ietf-netconf' schema has already been populated in YDK repository
2022-04-19 12:58:37,621 - ydk - Debug--- - Encoding the subtree filter request using XML subtree codec
Debug---:ydk:Encoding the subtree filter request using XML subtree codec
2022-04-19 12:58:37,621 - ydk.types.Entity - Debug--- - Get name leaf data for "components". Count: 0
Debug---:ydk.types.Entity:Get name leaf data for "components". Count: 0
2022-04-19 12:58:37,621 - ydk - Debug--- - Getting new modules for path 'openconfig-platform:components'
Debug---:ydk:Getting new modules for path 'openconfig-platform:components'
2022-04-19 12:58:37,622 - ydk - Debug--- - Loading module 'openconfig-platform', revision ''
Debug---:ydk:Loading module 'openconfig-platform', revision ''
2022-04-19 12:58:37,622 - ydk - Debug--- - The module 'openconfig-platform' schema has already been populated in YDK repository
Debug---:ydk:The module 'openconfig-platform' schema has already been populated in YDK repository
2022-04-19 12:58:37,622 - ydk - Debug--- - Loading module 'cisco-xr-openconfig-platform-deviations', revision ''
Debug---:ydk:Loading module 'cisco-xr-openconfig-platform-deviations', revision ''
2022-04-19 12:58:37,622 - ydk - Debug--- - The module 'cisco-xr-openconfig-platform-deviations' schema present in Libyang repository, but not in YDK; consider populate
Debug---:ydk:The module 'cisco-xr-openconfig-platform-deviations' schema present in Libyang repository, but not in YDK; consider populate
2022-04-19 12:58:37,623 - ydk - Debug--- - Added new libyang deviation module 'cisco-xr-openconfig-platform-deviations'
Debug---:ydk:Added new libyang deviation module 'cisco-xr-openconfig-platform-deviations'
2022-04-19 12:58:37,623 - ydk - Debug--- - Populating new module schema 'cisco-xr-openconfig-platform-deviations'
Debug---:ydk:Populating new module schema 'cisco-xr-openconfig-platform-deviations'
2022-04-19 12:58:37,623 - ydk - Debug--- - Looking to populate schemas for 'openconfig-platform:components'
Debug---:ydk:Looking to populate schemas for 'openconfig-platform:components'
2022-04-19 12:58:37,623 - ydk - Debug--- - Getting new modules for path 'openconfig-platform:components'
2022-04-19 12:58:37,624 - ydk - Debug--- - Loading module 'openconfig-platform', revision ''
2022-04-19 12:58:37,624 - ydk - Debug--- - The module 'openconfig-platform' schema has already been populated in YDK repository
2022-04-19 12:58:37,624 - ydk - Debug--- - Loading module 'cisco-xr-openconfig-platform-deviations', revision ''
2022-04-19 12:58:37,624 - ydk - Debug--- - The module 'cisco-xr-openconfig-platform-deviations' schema present in Libyang repository, but not in YDK; consider populate
2022-04-19 12:58:37,625 - ydk - Debug--- - Added new libyang deviation module 'cisco-xr-openconfig-platform-deviations'
2022-04-19 12:58:37,626 - ydk - Debug--- - Populating new module schema 'cisco-xr-openconfig-platform-deviations'
2022-04-19 12:58:37,626 - ydk - Debug--- - Creating root data node with path '/openconfig-platform:components'
Debug---:ydk:Creating root data node with path '/openconfig-platform:components'
2022-04-19 12:58:37,626 - ydk - Debug--- - XMLCodec: Leaf count: 0
Debug---:ydk:XMLCodec: Leaf count: 0
2022-04-19 12:58:37,627 - ydk.types.Entity - Debug--- - Get name leaf data for "components". Count: 0
2022-04-19 12:58:37,627 - ydk - Debug--- - XMLCodec: Children count for: openconfig-platform:components : 1
Debug---:ydk:XMLCodec: Children count for: openconfig-platform:components : 1
2022-04-19 12:58:37,627 - ydk - Debug--- - ==================
Debug---:ydk:==================
2022-04-19 12:58:37,627 - ydk - Debug--- - XMLCodec: Looking at child 'component'
Debug---:ydk:XMLCodec: Looking at child 'component'
2022-04-19 12:58:37,628 - ydk.types.Entity - Debug--- - Get name leaf data for "component". Count: 1
Debug---:ydk.types.Entity:Get name leaf data for "component". Count: 1
2022-04-19 12:58:37,628 - ydk.types.Entity - Debug--- - Leaf data name: "name", value: "0/RP0", yfilter: "YFilter.not_set", is_set: "True"
Debug---:ydk.types.Entity:Leaf data name: "name", value: "0/RP0", yfilter: "YFilter.not_set", is_set: "True"
2022-04-19 12:58:37,628 - ydk - Debug--- - Looking to populate schemas for 'component[name='0/RP0']'
Debug---:ydk:Looking to populate schemas for 'component[name='0/RP0']'
2022-04-19 12:58:37,628 - ydk - Debug--- - Getting new modules for path 'component[name='0/RP0']'
Debug---:ydk:Getting new modules for path 'component[name='0/RP0']'
2022-04-19 12:58:37,629 - ydk - Debug--- - XMLCodec: Leaf count: 1
Debug---:ydk:XMLCodec: Leaf count: 1
2022-04-19 12:58:37,629 - ydk - Debug--- - Looking to populate schemas for 'name'
Debug---:ydk:Looking to populate schemas for 'name'
2022-04-19 12:58:37,629 - ydk - Debug--- - Getting new modules for path 'name'
Debug---:ydk:Getting new modules for path 'name'
2022-04-19 12:58:37,629 - ydk - Debug--- - XMLCodec: Creating child name of /openconfig-platform:platform-component-top/components/component with value: '0/RP0', is_set: true
Debug---:ydk:XMLCodec: Creating child name of /openconfig-platform:platform-component-top/components/component with value: '0/RP0', is_set: true
2022-04-19 12:58:37,629 - ydk - Debug--- - XmlCodec: Creating leaf node 'name' with value: '0/RP0'
Debug---:ydk:XmlCodec: Creating leaf node 'name' with value: '0/RP0'
2022-04-19 12:58:37,630 - ydk.types.Entity - Debug--- - Get name leaf data for "component". Count: 1
2022-04-19 12:58:37,630 - ydk.types.Entity - Debug--- - Leaf data name: "name", value: "0/RP0", yfilter: "YFilter.not_set", is_set: "True"
2022-04-19 12:58:37,631 - ydk - Debug--- - XMLCodec: Children count for: component[name='0/RP0'] : 17
Debug---:ydk:XMLCodec: Children count for: component[name='0/RP0'] : 17
2022-04-19 12:58:37,631 - ydk - Debug--- - ==================
2022-04-19 12:58:37,631 - ydk - Debug--- - XMLCodec: Looking at child 'backplane'
Debug---:ydk:XMLCodec: Looking at child 'backplane'
2022-04-19 12:58:37,631 - ydk - Debug--- - XMLCodec: Child has no data and no operations
Debug---:ydk:XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,632 - ydk - Debug--- - XMLCodec: Looking at child 'chassis'
Debug---:ydk:XMLCodec: Looking at child 'chassis'
2022-04-19 12:58:37,632 - ydk - Debug--- - XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,632 - ydk - Debug--- - ==================
2022-04-19 12:58:37,632 - ydk - Debug--- - XMLCodec: Looking at child 'config'
Debug---:ydk:XMLCodec: Looking at child 'config'
2022-04-19 12:58:37,633 - ydk - Debug--- - ==================
2022-04-19 12:58:37,633 - ydk - Debug--- - XMLCodec: Looking at child 'cpu'
Debug---:ydk:XMLCodec: Looking at child 'cpu'
2022-04-19 12:58:37,633 - ydk.types.Entity - Debug--- - Get name leaf data for "cpu". Count: 0
Debug---:ydk.types.Entity:Get name leaf data for "cpu". Count: 0
2022-04-19 12:58:37,633 - ydk - Debug--- - Looking to populate schemas for 'cpu'
Debug---:ydk:Looking to populate schemas for 'cpu'
2022-04-19 12:58:37,633 - ydk - Debug--- - Getting new modules for path 'cpu'
Debug---:ydk:Getting new modules for path 'cpu'
2022-04-19 12:58:37,634 - ydk - Debug--- - XMLCodec: Leaf count: 0
2022-04-19 12:58:37,634 - ydk.types.Entity - Debug--- - Get name leaf data for "cpu". Count: 0
2022-04-19 12:58:37,634 - ydk - Debug--- - XMLCodec: Children count for: cpu : 3
Debug---:ydk:XMLCodec: Children count for: cpu : 3
2022-04-19 12:58:37,634 - ydk - Debug--- - ==================
2022-04-19 12:58:37,634 - ydk - Debug--- - XMLCodec: Looking at child 'config'
2022-04-19 12:58:37,635 - ydk - Debug--- - XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,635 - ydk - Debug--- - ==================
2022-04-19 12:58:37,635 - ydk - Debug--- - XMLCodec: Looking at child 'state'
Debug---:ydk:XMLCodec: Looking at child 'state'
2022-04-19 12:58:37,635 - ydk - Debug--- - XMLCodec: Looking at child 'utilization'
Debug---:ydk:XMLCodec: Looking at child 'utilization'
2022-04-19 12:58:37,636 - ydk.types.Entity - Debug--- - Get name leaf data for "utilization". Count: 0
Debug---:ydk.types.Entity:Get name leaf data for "utilization". Count: 0
2022-04-19 12:58:37,636 - ydk - Debug--- - Looking to populate schemas for 'openconfig-platform-cpu:utilization'
Debug---:ydk:Looking to populate schemas for 'openconfig-platform-cpu:utilization'
2022-04-19 12:58:37,636 - ydk - Debug--- - Getting new modules for path 'openconfig-platform-cpu:utilization'
Debug---:ydk:Getting new modules for path 'openconfig-platform-cpu:utilization'
2022-04-19 12:58:37,637 - ydk - Debug--- - Loading module 'openconfig-platform-cpu', revision ''
Debug---:ydk:Loading module 'openconfig-platform-cpu', revision ''
2022-04-19 12:58:37,637 - ydk - Debug--- - The module 'openconfig-platform-cpu' schema present in Libyang repository, but not in YDK; consider populate
Debug---:ydk:The module 'openconfig-platform-cpu' schema present in Libyang repository, but not in YDK; consider populate
2022-04-19 12:58:37,637 - ydk - Debug--- - Added new libyang module 'openconfig-platform-cpu'
Debug---:ydk:Added new libyang module 'openconfig-platform-cpu'
2022-04-19 12:58:37,637 - ydk - Debug--- - Populating new module schema 'openconfig-platform-cpu'
Debug---:ydk:Populating new module schema 'openconfig-platform-cpu'
2022-04-19 12:58:37,637 - ydk - Debug--- - Populating augmented schema node 'component-cpu-utilization'
Debug---:ydk:Populating augmented schema node 'component-cpu-utilization'
2022-04-19 12:58:37,638 - ydk - Debug--- - Populating new schema node 'utilization'
Debug---:ydk:Populating new schema node 'utilization'
2022-04-19 12:58:37,638 - ydk - Debug--- - XMLCodec: Leaf count: 0
2022-04-19 12:58:37,638 - ydk.types.Entity - Debug--- - Get name leaf data for "utilization". Count: 0
2022-04-19 12:58:37,638 - ydk - Debug--- - XMLCodec: Children count for: openconfig-platform-cpu:utilization : 1
Debug---:ydk:XMLCodec: Children count for: openconfig-platform-cpu:utilization : 1
2022-04-19 12:58:37,638 - ydk - Debug--- - ==================
2022-04-19 12:58:37,639 - ydk - Debug--- - XMLCodec: Looking at child 'state'
2022-04-19 12:58:37,639 - ydk.types.Entity - Debug--- - Get name leaf data for "state". Count: 0
Debug---:ydk.types.Entity:Get name leaf data for "state". Count: 0
2022-04-19 12:58:37,639 - ydk - Debug--- - Looking to populate schemas for 'state'
Debug---:ydk:Looking to populate schemas for 'state'
2022-04-19 12:58:37,639 - ydk - Debug--- - Getting new modules for path 'state'
Debug---:ydk:Getting new modules for path 'state'
2022-04-19 12:58:37,639 - ydk - Debug--- - XMLCodec: Leaf count: 0
2022-04-19 12:58:37,640 - ydk.types.Entity - Debug--- - Get name leaf data for "state". Count: 0
2022-04-19 12:58:37,640 - ydk - Debug--- - XMLCodec: Children count for: state : 0
Debug---:ydk:XMLCodec: Children count for: state : 0
2022-04-19 12:58:37,640 - ydk - Debug--- - ==================
2022-04-19 12:58:37,640 - ydk - Debug--- - XMLCodec: Looking at child 'fabric'
Debug---:ydk:XMLCodec: Looking at child 'fabric'
2022-04-19 12:58:37,641 - ydk - Debug--- - XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,641 - ydk - Debug--- - ==================
2022-04-19 12:58:37,641 - ydk - Debug--- - XMLCodec: Looking at child 'fan'
Debug---:ydk:XMLCodec: Looking at child 'fan'
2022-04-19 12:58:37,641 - ydk - Debug--- - XMLCodec: Looking at child 'integrated-circuit'
Debug---:ydk:XMLCodec: Looking at child 'integrated-circuit'
2022-04-19 12:58:37,642 - ydk - Debug--- - XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,642 - ydk - Debug--- - ==================
2022-04-19 12:58:37,642 - ydk - Debug--- - XMLCodec: Looking at child 'linecard'
Debug---:ydk:XMLCodec: Looking at child 'linecard'
2022-04-19 12:58:37,643 - ydk - Debug--- - ==================
2022-04-19 12:58:37,643 - ydk - Debug--- - XMLCodec: Looking at child 'optical-channel'
Debug---:ydk:XMLCodec: Looking at child 'optical-channel'
2022-04-19 12:58:37,644 - ydk - Debug--- - XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,644 - ydk - Debug--- - ==================
2022-04-19 12:58:37,644 - ydk - Debug--- - XMLCodec: Looking at child 'optical-port'
Debug---:ydk:XMLCodec: Looking at child 'optical-port'
2022-04-19 12:58:37,645 - ydk - Debug--- - XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,645 - ydk - Debug--- - ==================
2022-04-19 12:58:37,645 - ydk - Debug--- - XMLCodec: Looking at child 'port'
Debug---:ydk:XMLCodec: Looking at child 'port'
2022-04-19 12:58:37,646 - ydk - Debug--- - ==================
2022-04-19 12:58:37,646 - ydk - Debug--- - XMLCodec: Looking at child 'power-supply'
Debug---:ydk:XMLCodec: Looking at child 'power-supply'
2022-04-19 12:58:37,646 - ydk - Debug--- - XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,647 - ydk - Debug--- - XMLCodec: Looking at child 'properties'
Debug---:ydk:XMLCodec: Looking at child 'properties'
2022-04-19 12:58:37,647 - ydk - Debug--- - XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,648 - ydk - Debug--- - ==================
2022-04-19 12:58:37,648 - ydk - Debug--- - XMLCodec: Looking at child 'state'
2022-04-19 12:58:37,649 - ydk - Debug--- - XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,649 - ydk - Debug--- - ==================
2022-04-19 12:58:37,649 - ydk - Debug--- - XMLCodec: Looking at child 'storage'
Debug---:ydk:XMLCodec: Looking at child 'storage'
2022-04-19 12:58:37,650 - ydk - Debug--- - XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,650 - ydk - Debug--- - ==================
2022-04-19 12:58:37,650 - ydk - Debug--- - XMLCodec: Looking at child 'subcomponents'
Debug---:ydk:XMLCodec: Looking at child 'subcomponents'
2022-04-19 12:58:37,651 - ydk - Debug--- - XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,651 - ydk - Debug--- - ==================
2022-04-19 12:58:37,651 - ydk - Debug--- - XMLCodec: Looking at child 'transceiver'
Debug---:ydk:XMLCodec: Looking at child 'transceiver'
2022-04-19 12:58:37,652 - ydk - Debug--- - XMLCodec: Child has no data and no operations
2022-04-19 12:58:37,653 - ydk - Debug--- - Populating schema for 'filter'
Debug---:ydk:Populating schema for 'filter'
2022-04-19 12:58:37,653 - ydk - Debug--- - Looking to populate schemas for 'filter'
Debug---:ydk:Looking to populate schemas for 'filter'
2022-04-19 12:58:37,653 - ydk - Debug--- - Getting new modules for path 'filter'
Debug---:ydk:Getting new modules for path 'filter'
2022-04-19 12:58:37,654 - ydk - Debug--- - Populating schema for '<components xmlns="http://openconfig.net/yang/platform">
  <component>
    <name>0/RP0</name>
    <cpu>
      <utilization xmlns="http://openconfig.net/yang/platform/cpu">
        <state/>
      </utilization>
    </cpu>
  </component>
</components>'
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components>'
Debug---:ydk:Populating schema for '<components xmlns="http://openconfig.net/yang/platform">
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components>'
2022-04-19 12:58:37,654 - ydk - Debug--- - Looking to populate schemas for '<components xmlns="http://openconfig.net/yang/platform">
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components>'
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components>'
Debug---:ydk:Looking to populate schemas for '<components xmlns="http://openconfig.net/yang/platform">
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components>'
2022-04-19 12:58:37,655 - ydk - Debug--- - Getting new modules for path '<components xmlns="http://openconfig.net/yang/platform">
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components>'
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components>'
Debug---:ydk:Getting new modules for path '<components xmlns="http://openconfig.net/yang/platform">
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components>'
2022-04-19 12:58:37,655 - ydk - Debug--- - Creating node 'filter' with value '<components xmlns="http://openconfig.net/yang/platform">
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components>'
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components>'
Debug---:ydk:Creating node 'filter' with value '<components xmlns="http://openconfig.net/yang/platform">
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components>'
2022-04-19 12:58:37,655 - ydk - Debug--- - Current path: /ietf-netconf:get
Debug---:ydk:Current path: /ietf-netconf:get
2022-04-19 12:58:37,656 - ydk - Debug--- - Top container path: ietf-netconf:get
Debug---:ydk:Top container path: ietf-netconf:get
2022-04-19 12:58:37,656 - ydk - Debug--- - Populating schema for 'filter'
2022-04-19 12:58:37,656 - ydk - Debug--- - Looking to populate schemas for 'filter'
2022-04-19 12:58:37,657 - ydk - Debug--- - Getting new modules for path 'filter'
2022-04-19 12:58:37,657 - ydk - Debug--- - Getting child schema with path 'filter' in /ietf-netconf:get
Debug---:ydk:Getting child schema with path 'filter' in /ietf-netconf:get
2022-04-19 12:58:37,657 - ydk - Debug--- - Getting data nodes with path 'filter'
Debug---:ydk:Getting data nodes with path 'filter'
2022-04-19 12:58:37,657 - ydk - Debug--- - Creating new data path 'filter' with value '<components xmlns="http://openconfig.net/yang/platform">
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components>' in 'get'
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
Debug---:ydk:Creating new data path 'filter' with value '<components xmlns="http://openconfig.net/yang/platform">
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
2022-04-19 12:58:37,658 - ydk - Debug--- - Getting new modules for path 'ydk:create'
Debug---:ydk:Getting new modules for path 'ydk:create'
2022-04-19 12:58:37,658 - ydk - Debug--- - Loading module 'ydk', revision ''
Debug---:ydk:Loading module 'ydk', revision ''
2022-04-19 12:58:37,659 - ydk - Debug--- - The module 'ydk' schema has already been populated in YDK repository
Debug---:ydk:The module 'ydk' schema has already been populated in YDK repository
2022-04-19 12:58:37,659 - ydk - Debug--- - Getting new modules for path 'ydk:read'
Debug---:ydk:Getting new modules for path 'ydk:read'
2022-04-19 12:58:37,659 - ydk - Debug--- - Loading module 'ydk', revision ''
2022-04-19 12:58:37,660 - ydk - Debug--- - The module 'ydk' schema has already been populated in YDK repository
2022-04-19 12:58:37,660 - ydk - Debug--- - Getting new modules for path 'ydk:update'
Debug---:ydk:Getting new modules for path 'ydk:update'
2022-04-19 12:58:37,660 - ydk - Debug--- - Loading module 'ydk', revision ''
2022-04-19 12:58:37,660 - ydk - Debug--- - Getting new modules for path 'ydk:delete'
Debug---:ydk:Getting new modules for path 'ydk:delete'
2022-04-19 12:58:37,661 - ydk - Debug--- - Loading module 'ydk', revision ''
2022-04-19 12:58:37,661 - ydk - Debug--- - The module 'ydk' schema has already been populated in YDK repository
2022-04-19 12:58:37,661 - ydk - Debug--- - ydk::path::Codec: Encoding data node '/ietf-netconf:get' to XML formated string
Debug---:ydk:ydk::path::Codec: Encoding data node '/ietf-netconf:get' to XML formated string
2022-04-19 12:58:37,661 - ydk - Info---- - ============= Sending RPC to device =============
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><get xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <filter><components xmlns="http://openconfig.net/yang/platform">
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</components></filter>
</get>
</rpc>
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</get>
</rpc>
Info----:ydk:============= Sending RPC to device =============
  <component>
    <name>0/RP0</name>
    <cpu>
        <state/>
      </utilization>
    </cpu>
  </component>
</get>
</rpc>
2022-04-19 12:58:37,662 - ydk - Debug--- - NetconfSSHClient: NC session status: 1
Debug---:ydk:NetconfSSHClient: NC session status: 1
2022-04-19 12:58:37,663 - ydk - Debug--- - Trace: Missing message-id in rpc.
Debug---:ydk:Trace: Missing message-id in rpc.
2022-04-19 12:58:37,663 - ydk - Debug--- - Netconf SSH Client: sending RPC
Debug---:ydk:Netconf SSH Client: sending RPC
2022-04-19 12:58:37,663 - ydk - Debug--- - Trace: Writing message (session 2933664974):
<?xml version="1.0"?>
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="12">
  <get>
    <filter>
        <component>
          <name>0/RP0</name>
          <cpu>
              <state/>
            </utilization>
          </cpu>
        </component>
      </components>
    </filter>
  </get>
</rpc>
  <get>
    <filter>
        <component>
          <name>0/RP0</name>
          <cpu>
              <state/>
            </utilization>
          </cpu>
        </component>
      </components>
    </filter>
  </get>
</rpc>
Debug---:ydk:Trace: Writing message (session 2933664974):
  <get>
    <filter>
        <component>
          <name>0/RP0</name>
          <cpu>
              <state/>
            </utilization>
          </cpu>
        </component>
      </components>
    </filter>
  </get>
</rpc>
2022-04-19 12:58:37,664 - ydk - Debug--- - NetconfSSHClient: NC session status: 1
2022-04-19 12:58:37,664 - ydk - Debug--- - Netconf SSH Client: receiving reply RPC
Debug---:ydk:Netconf SSH Client: receiving reply RPC
2022-04-19 12:58:37,887 - ydk - Debug--- - Trace: Received message (session 2933664974):
<rpc-reply message-id="12" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<data>
   <component>
    <name>0/RP0</name>
    <cpu xmlns="http://openconfig.net/yang/platform/cpu">
     <utilization>
      <state>
       <instant>1</instant>
       <avg>1</avg>
       <min>1</min>
       <max>1</max>
       <interval>300000000000</interval>
       <min-time>1650352294935292431</min-time>
       <max-time>1650352294935292431</max-time>
      </state>
     </utilization>
    </cpu>
   </component>
  </components>
</data>
</rpc-reply>
<data>
  <component>
    <name>0/RP0</name>
     <utilization>
      <state>
       <avg>1</avg>
       <min>1</min>
       <max>1</max>
      </state>
     </utilization>
    </cpu>
   </component>
  </components>
</data>
</rpc-reply>
Debug---:ydk:Trace: Received message (session 2933664974):
<data>
   <component>
    <name>0/RP0</name>
     <utilization>
      <state>
       <avg>1</avg>
       <min>1</min>
       <max>1</max>
      </state>
     </utilization>
    </cpu>
   </component>
  </components>
</data>
</rpc-reply>
2022-04-19 12:58:37,888 - ydk - Debug--- - Netconf SSH Client: processing reply
Debug---:ydk:Netconf SSH Client: processing reply
2022-04-19 12:58:37,888 - ydk - Info---- - ============= Received RPC from device =============
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="12">
  <data>
      <component>
        <name>0/RP0</name>
          <utilization>
            <state>
              <avg>1</avg>
              <min>1</min>
              <max>1</max>
            </state>
          </utilization>
        </cpu>
      </component>
    </components>
  </data>
</rpc-reply>
  <data>
      <component>
        <name>0/RP0</name>
          <utilization>
            <state>
              <avg>1</avg>
              <min>1</min>
              <max>1</max>
            </state>
          </utilization>
        </cpu>
      </component>
    </components>
  </data>
</rpc-reply>
Info----:ydk:============= Received RPC from device =============
  <data>
      <component>
        <name>0/RP0</name>
          <utilization>
            <state>
              <avg>1</avg>
              <min>1</min>
              <max>1</max>
            </state>
          </utilization>
        </cpu>
      </component>
    </components>
  </data>
</rpc-reply>
2022-04-19 12:58:37,888 - ydk - Debug--- - ydk::path::Codec: Decoding from XML formatted payload:
      <component>
        <name>0/RP0</name>
          <utilization>
            <state>
              <avg>1</avg>
              <min>1</min>
              <max>1</max>
            </state>
          </utilization>
        </cpu>
      </component>
    </components>
      <component>
        <name>0/RP0</name>
          <utilization>
            <state>
              <avg>1</avg>
              <min>1</min>
              <max>1</max>
            </state>
          </utilization>
        </cpu>
      </component>
    </components>
Debug---:ydk:ydk::path::Codec: Decoding from XML formatted payload:
      <component>
        <name>0/RP0</name>
          <utilization>
            <state>
              <avg>1</avg>
              <min>1</min>
              <max>1</max>
            </state>
          </utilization>
        </cpu>
      </component>
    </components>
2022-04-19 12:58:37,888 - ydk - Debug--- - Populating new schema from payload:
      <component>
        <name>0/RP0</name>
          <utilization>
            <state>
              <avg>1</avg>
              <min>1</min>
              <max>1</max>
            </state>
          </utilization>
        </cpu>
      </component>
    </components>
      <component>
        <name>0/RP0</name>
          <utilization>
            <state>
              <avg>1</avg>
              <min>1</min>
              <max>1</max>
            </state>
          </utilization>
        </cpu>
      </component>
    </components>
Debug---:ydk:Populating new schema from payload:
      <component>
        <name>0/RP0</name>
          <utilization>
            <state>
              <avg>1</avg>
              <min>1</min>
              <max>1</max>
            </state>
          </utilization>
        </cpu>
      </component>
    </components>
2022-04-19 12:58:37,889 - ydk - Debug--- - Extracting module namespaces from XML payload
Debug---:ydk:Extracting module namespaces from XML payload
2022-04-19 12:58:37,890 - ydk - Debug--- - Loading module 'openconfig-platform-cpu', revision ''
2022-04-19 12:58:37,890 - ydk - Debug--- - The module 'openconfig-platform-cpu' schema present in Libyang repository, but not in YDK; consider populate
2022-04-19 12:58:37,890 - ydk - Debug--- - Added new libyang module 'openconfig-platform-cpu'
2022-04-19 12:58:37,890 - ydk - Debug--- - Loading module 'openconfig-platform', revision ''
2022-04-19 12:58:37,890 - ydk - Debug--- - The module 'openconfig-platform' schema has already been populated in YDK repository
2022-04-19 12:58:37,891 - ydk - Debug--- - Loading module 'cisco-xr-openconfig-platform-deviations', revision ''
2022-04-19 12:58:37,891 - ydk - Debug--- - The module 'cisco-xr-openconfig-platform-deviations' schema present in Libyang repository, but not in YDK; consider populate
2022-04-19 12:58:37,891 - ydk - Debug--- - Added new libyang deviation module 'cisco-xr-openconfig-platform-deviations'
2022-04-19 12:58:37,892 - ydk - Debug--- - Populating new module schema 'openconfig-platform-cpu'
2022-04-19 12:58:37,892 - ydk - Debug--- - Populating augmented schema node 'component-cpu-utilization'
2022-04-19 12:58:37,892 - ydk - Debug--- - Populating new schema node 'utilization'
2022-04-19 12:58:37,892 - ydk - Debug--- - Populating new module schema 'cisco-xr-openconfig-platform-deviations'
2022-04-19 12:58:37,893 - ydk - Debug--- - [libyang] Resolving unresolved data nodes and their constraints...
Debug---:ydk:[libyang] Resolving unresolved data nodes and their constraints...
2022-04-19 12:58:37,893 - ydk - Debug--- - [libyang] All data nodes and constraints resolved.
Debug---:ydk:[libyang] All data nodes and constraints resolved.
2022-04-19 12:58:37,893 - ydk - Debug--- - Performing decode operation
Debug---:ydk:Performing decode operation
2022-04-19 12:58:37,894 - ydk - Debug--- - Looking at parent entity 'components'
Debug---:ydk:Looking at parent entity 'components'
2022-04-19 12:58:37,894 - ydk - Debug--- - Looking at child list '/openconfig-platform:components/component[name='0/RP0']'
Debug---:ydk:Looking at child list '/openconfig-platform:components/component[name='0/RP0']'
2022-04-19 12:58:37,894 - ydk - Debug--- - Going into child component in parent /openconfig-platform:components
Debug---:ydk:Going into child component in parent /openconfig-platform:components
2022-04-19 12:58:37,894 - ydk.types.Entity - Debug--- - Looking for 'component'
Debug---:ydk.types.Entity:Looking for 'component'
2022-04-19 12:58:37,912 - ydk - Debug--- - Created entity child 'component' in parent '/openconfig-platform:components'
Debug---:ydk:Created entity child 'component' in parent '/openconfig-platform:components'
2022-04-19 12:58:37,912 - ydk - Debug--- - Looking at parent entity 'component'
Debug---:ydk:Looking at parent entity 'component'
2022-04-19 12:58:37,912 - ydk - Debug--- - Looking at child leaf '/openconfig-platform:components/component[name='0/RP0']/name'
Debug---:ydk:Looking at child leaf '/openconfig-platform:components/component[name='0/RP0']/name'
2022-04-19 12:58:37,912 - ydk - Debug--- - Creating entity leaf 'name' of value '0/RP0' in parent '/openconfig-platform:components/component[name='0/RP0']'
Debug---:ydk:Creating entity leaf 'name' of value '0/RP0' in parent '/openconfig-platform:components/component[name='0/RP0']'
2022-04-19 12:58:37,913 - ydk - Debug--- - Created entity leaf 'name' of value '0/RP0' in parent '/openconfig-platform:components/component[name='0/RP0']'
Debug---:ydk:Created entity leaf 'name' of value '0/RP0' in parent '/openconfig-platform:components/component[name='0/RP0']'
In [8]: dir(rpc_out)
Out[8]:
['__class__',
'__delattr__',
'__dict__',
'__dir__',
'__doc__',
'__eq__',
'__format__',
'__ge__',
'__getattribute__',
'__gt__',
'__hash__',
'__init__',
'__init_subclass__',
'__le__',
'__lt__',
'__module__',
'__ne__',
'__new__',
'__reduce__',
'__reduce_ex__',
'__repr__',
'__setattr__',
'__sizeof__',
'__str__',
'__subclasshook__',
'_absolute_path',
'_assign_yleaf',
'_assign_yleaflist',
'_child_classes',
'_children_name_map',
'_children_yang_names',
'_get_absolute_path',
'_get_child_by_seg_name',
'_is_frozen',
'_leafs',
'_local_refs',
'_logger',
'_perform_setattr',
'_prefix',
'_python_type_validation_enabled',
'_revision',
'_segment_path',
'avg',
'children',
'clone',
'clone_ptr',
'get_absolute_path',
'get_child_by_name',
'get_children',
'get_name_leaf_data',
'get_order_of_children',
'get_segment_path',
'has_data',
'has_leaf_or_child_of_name',
'has_list_ancestor',
'has_operation',
'ignore_validation',
'instant',
'interval',
'is_presence_container',
'is_top_level_class',
'max',
'max_time',
'min',
'min_time',
'parent',
'path',
'set_filter',
'set_value',
'yang_name',
'yang_parent_name',
'yfilter',
'ylist_key',
'ylist_key_names']
In [9]: rpc_out.max
In [10]:
Ramya
ygorelik
Could you please elaborate, what is the issue. I do not see it from the log.
Yan
Hi Yan,
Trying to Automate the container(Cpu/Utilization/State) in Openconfig-Platform-cpu model. Rpc response is fetched properly through AP, but on parsing the output the fields are empty.  Other containers in the model are fetched properly.
Ramya
ygorelik
Hi Ramya
Here is your CRUD read command:
It is missing initialization of top level container of class Components and attachment to it of a list element of class Component. Your initialization must be something like this:
from ydk.models.openconfig import openconfig_platform as oc
comps = oc.Components() # Always start building model object from top level container
comp = oc.Components.Component()
comp.name = '0/RP0'
comps.component.append(comp) # The list element must be attached to appropriate YList object
Yan
