UCS sandbox not in the catalogue?
The content you are looking for has been archived. View related content below.
I need to run ssh command from powersehll like what I have below but UCS direcort replace " with ' ' , i tested all different combination but cant find how to pass double quoteinvoke-SSHCommand -SSHSession $session -Command "svctask mkvdisk -name ...
Hello All , I am running ESXI 7.0 in cisco UCS C240 Server , Server is shutting down yesterday for physical location migration activity and then server is not boot ESXI when power on again. and not able to see Local Drive in Boot order. Anyone help m...
I'm trying to find the correct option to reset the Admin password in UCS Director, as it's failing when I try to log in. I can access Shell_Admin and can access the menu to 29) Reset MySQL User password. Is that the same thing?We have a couple of the...
Is it possible to hide Admin fields in Summary details while creating a service request in a Catalog ?
Tying to make an API call with request body more than 1024 characterIs it possible to increase this limit of 1024 character for request body or any other work around ? Request body is of Input Type as gen_text_input
I am looking to get VM annotation from VMware VM. I see a task name Get VMware VM Details it does provides lot of details but not annotation. Is it possible to modify the script to extract annotations ? Below is the current script for VMware VM Deta...
Hi everyone, I created a Workflow to upload a file using "File Upload" input. It works, and I have my uploaded file on my ucsdirector server, on the path: /opt/infra/uploads/myuser/tempfolder/file.ext Now, using ssh and scp, I need to transfer tha...
Dear Experts, I have a XML string which is result of one of the previous task. XML string looks like below.$o = "<?xml version='1.0'?><Objects><Object Type='System.Boolean'>True</Object></Objects>"and I am using Select-Xml -Content $o -XPath '//Objec...
Hey everyone, I have had a bunch of large customers as of late who have asked me to come in to train them on Cisco UCS Director from a programming perspective. In all of these environments, we have been deploying large/national scale Hyper-V and ACI ...
Dears,We need to install new RAMs with P.N: UCS-MR-1X162RUA for UCS P.N: B200-M4. Unfortunately the server and related RMAs are end of sale. Do we have a chance to install third party RMS like HP, DELL, Kingston, etc? Thanks in advance.
Dear Experts, I am using "provision blank VM" task to create a new VM and there is no option where i can select the boot mode. I have also checked the different available APIs but still could not figure out. has anyone experience with this or any adv...
Hi, I am planning on upgrading NXOS and epld for our N9508s that have dual supervisors. having never done one before so wondering if one of you could could help me with the steps. I have read many documents by now and online threads they all seems to...
I wonder, how to apply a "vCenter VM Customization Specification" using UCS-Director. In PowerCLI I can use "Set-VMWVM ... -OSCustomizationSpec $spec" which applies a VM-Customization-Spec configured in the vCenter. I know the UCSD "VMware - Guest Cu...
Hello,Does anyone know why VMRC console is not starting? The end-user has a possibility to enable/disable and launch the console. Once enabled, when I try to open it I get the message: Resource Not Available. It is UCSD 6.7.4 and vCenter 6.7. VM is u...
| Subject | Author | Posted |
| 06-26-2024 01:15 PM | ||
| 07-06-2022 03:37 PM | ||
| 08-17-2021 11:22 AM | ||
| 01-30-2021 07:08 AM | ||
| 10-20-2020 03:22 AM |
