04-27-2017 02:04 AM - edited 03-01-2019 06:24 AM
Hi Team,
I am trying get info eth0, eth1, eth2 and so one separately.
How i am trying is
scope org
scope service-profile service-profile-name
show vnic expand
This will give all 6 eth information. Is there separate command to get only eth0 info for service-profile
04-27-2017 04:53 AM
Instead of the show vnic expand command try
show vnic eth0 expand
show vnic eth1 expand
Hope that helps.
John
04-27-2017 06:08 AM
I see you can also use a pipe "|" and have grep as an option...
begin count cut egrep end exclude grep head include last less no-more sort tr uniq wc
you could grep for eth0
