reading value of a input in another input
KAKA_2
Dear Experts,
is it possible to read value of a Input in another Input. here is the Scenario.
in a subworkflow I have two Tasks to be executed. I have defined two Input at workflow Level.
InputfortaskA = <emailid> (this will be feeded by main workflow)
InputfortaskB = Task has been completed
but i want this more dynamic i.e InputfortaskB = Task has been completed for <VALUEOFInputfortaskA>.
any help in this regard is appriciated.
-KAKA-
Chris K.
I would create a simple Custom Workflow Task, that creates the input for task B, e.g:
var input1 = input.InputfortaskA;
var input2 = input.InputfortaskB;
output.dynamicInputForTaskB = input2 + input1;
You execute this custom task somewhere before Task B and then you can use the output of this task as input for Task B
Cisco UCS X-Series Energy Efficiency Offer
