RedHat integration problem
Ziga M
Level 2
Level 2
I have problems integrating RedHat virtualization into UCS Director, or in other words, creating new virtual RHEV account in UCSD. I get an error "not KVM account".
logs shows connection was somewhat successful, but UCSD returns "connection failed".
I created new account on RHEV, no luck.
API on RHEV works, ansible playbook "ovirt-vms" works for example..
I'm using latest RHEV  Version 4.2.6.4-0.1.el7ev
and latest UCSD 6.6.0.0
2018-09-18 06:04:33,926 [ORP-1-35] INFO  run(OperationRequestProcessor.java:77) - Executing request... requestId=43116; opName=doFormSubmit
2018-09-18 06:04:33,927 [ORP-1-35] INFO  doFormSubmit(APIProvider.java:1247) - FORM SUBMIT custom.add.account.form.Red Hat KVM?
2018-09-18 06:04:33,927 [ORP-1-35] INFO  definePage(FormBindings.java:801) - Field = Red Hat KVMgeneric.props.id.podName, LovProviderName =
2018-09-18 06:04:33,928 [ORP-1-35] INFO  definePage(FormBindings.java:801) - Field = Red Hat KVMspecific.props.id.policy, LovProviderName =
2018-09-18 06:04:33,928 [ORP-1-35] INFO  validatePageData(PhysicalAccountAddForm.java:187) -
2018-09-18 06:04:33,928 [ORP-1-35] INFO  validatePageData(PhysicalAccountAddForm.java:192) - Default Pod
2018-09-18 06:04:33,931 [ORP-1-35] INFO  newAccountAdded(PhysicalAccountManager.java:57) - Processing new account addition: rhev2
2018-09-18 06:04:33,933 [ORP-1-35] INFO  handleAddAccount(AbstractAccountHandler.java:42) - adding account to system
2018-09-18 06:04:33,938 [ORP-1-35] INFO  testConnection(RhevAccountTestConnectionHandler.java:22) - Called
2018-09-18 06:04:33,944 [ORP-1-35] INFO  <init>(RhevRequest.java:63) - Adding the kvm account url isrhev2.aci.riviera.local
2018-09-18 06:04:33,944 [ORP-1-35] INFO  constructUrl(RhevRequest.java:290) - The constructUrl is rhev2.aci.riviera.local 443
2018-09-18 06:04:34,304 [ORP-1-35] INFO  is_rhev_version_atleast_four(RhevRequest.java:282) - HttpResponse is 200
2018-09-18 06:04:34,305 [ORP-1-35] INFO  execute(RhevRequest.java:100) - method 0
2018-09-18 06:04:34,305 [ORP-1-35] INFO  execute(RhevRequest.java:101) - url https://rhev2.aci.riviera.local:443/ovirt-engine/api
2018-09-18 06:04:34,461 [ORP-1-35] INFO  sendNotificationEmail(EmailPolicyNotificationEmailSender.java:49) - Send email option is disabled : false
2018-09-18 06:04:34,462 [ORP-1-35] INFO  run(OperationRequestProcessor.java:138) - Sending response... requestId=43116
If someone else is looging for documentation: https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-director/kvm-install-guide/6-6/cisco-ucs-director-redhatkvm-mgmt-66/cisco-ucs-director-redhatkvm-mgmt-66_chapter_011.html
Ziga M
Level 2
Level 2
If someone else is struggling: there is no current support for v4.2. UCSD support redhat 4.1 which is described in compatibility matrix
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-director/compatibility-matrix/6-6/cisco-ucs-director-compatibility-matrix-66.html#reference_vjx_pdg_cdb
Cisco UCS X-Series Energy Efficiency Offer
