UCSD and Git, Better together
mt_solutions
Hi all,
we are a small HK based partner and we build some interesting integrations for UCSD and GIT, which makes our lives easier on our day to day develovpment:
MT Solutions - UCSD - GIT Integration on Vimeo
Hope you like it!
14 Replies 14
Kral Two
Level 4
Level 4
That's great!
what should it take to have a webhook calling the UCSD pull workflow when the repo is updated? :-)
You would need to run a scheduled workflow on UCSD that checks Git every few seconds.
I was thinking about calling a UCSD workflow via northbound API, when the repository see an update (action/module to be done on the repository side, gitlab, gogs, etc ...)
That would work as well if your UCSD instance is addressable from the outside world.
Now let it be noted in UCSD 6.5 you can check in and out workflows to Git.
Im not sure this is the case. I just upgraded to 6.5 and there is no ability (that I could find anyway) to check flows in and out of git.  You can pull custom task scripts out of git, but thats it.  It also appears to only work with github.  I was unable to get it to talk to our internal git server. I do have a ticket open on that though.
Pretty disappointing if thats the only git integration and Im really hoping that im just missing things.
Try this:
Hi Orf,
Thanks for the response. And thanks for all the great stuff you have put up here the last few years. I have used lots of it.
Does this integration only work with github servers?  Our internal repos are all bitbucket.
Also you mentioned above that we would be able to check flows in and out. Is that the case? I cant fine that anywhere.
What you do here is a simple backup. You could have used FTP or anything else, as well. GIT is ment to be a code repository, it's not very suitable for binary files. What I would rather see (will come with 6.5, but still limited) is a possibility to update the source code of a custom task locally, push it to the git, and then UCSD should get the code and apply to the custom task. It can be done directly via the UCSD or maybe with Jenkins fetching the code, adding to UCSD and even running some tests with temporary data (pure devops style). So, you do not have to go thgough all GUI options of the custom task when you want to just update the javascript code. The main issue is that the worflow is a binary file, and you cannot upload remotely just the code.
Cheers,
Krzysztof
gene.williams
Hey Orf,
Do you have answers for Erich's questions (9.) ?
In here https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-director/custom-task-mgmt-guide/6-5/cisco-ucs-director-custom-task-getting-started-65/Cisco-UCS-Director-Custom-Task-Getting-Started-Guide-7-0_chapter_011.html?bookSearch=true
They only talk about github.
But I would turn on debug and connect and turn debug off and see what else you can find in the log.
The PDF in the link below says "or your own private enterprise Git repository" at item one under "Custom Tasks and Git Repositories" on page 20.  Initially, nothing sticks out in the debug logs, but I'll keep plugging at it from different angles.
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-director/custom-task-mgmt-guide/6-5/cisco-ucs-director-custom-task-getting-started-65.pdf
Did you turn on debug logging in administration -> Support information -> debug logging
And the run a tail –f /opt/infra/inframgr/logfile.txt
I did and captured the catalina.log, CloupiaServiceClient.log, and the inframgr.log, debug mode started just before the connection test and stopped immediately after.  Only the inframgr log had anything obviously related to the connection test - and no tell-tale cause for only the authentication part of the test failing.  Below is entire inframgr.log during the debug capture.  Again, the ping test and connection test parts succeed - only the Login is unsuccessful.  I've repeatedly re-entered these credentials and triple checked them logging into the git repo via web browser.
Is it possible the connection test input field might not like certain special characters in a password?
2018-05-04 15:39:04,567 [ORP-1-34] INFO  startRecording(LogRecorder.java:145) - Start recording logs!
2018-05-04 15:39:04,569 [ORP-1-34] INFO  run(OperationRequestProcessor.java:138) - Sending response... requestId=22237
2018-05-04 15:39:04,569 [ORP-1-34] DEBUG sendReply(LANServerChannel.java:80) - sending reply ...
2018-05-04 15:39:04,916 [WorkFlowManager] DEBUG query(JDBCObjStore.java:195) - Query table --> limit -1 offset -1
2018-05-04 15:39:04,916 [WorkFlowManager] DEBUG query(JDBCObjStore.java:204) - Executing query (MySQL)
2018-05-04 15:39:04,916 [WorkFlowManager] DEBUG parseJDOQL(JDBCObjStore.java:816) - Incase of SQLInjection Excpetion below, query executed by POJO:class com.cloupia.model.cIM.WorkFlow
2018-05-04 15:39:04,916 [WorkFlowManager] DEBUG convertToJDBCQuery(QueryParser.java:106) -  jdoQuery priority <= 1 && adminStatus == 1 && executionStatus <= 1 && futureStartTime <= 1525448344916
2018-05-04 15:39:04,916 [WorkFlowManager] DEBUG query(JDBCObjStore.java:229) - Executing query SELECT * FROM WORKFLOW_DETAILS A WHERE priority <= 1  AND  adminStatus = 1  AND  executionStatus <= 1  AND  futureStartTime <= 1525448344916
2018-05-04 15:39:04,922 [WorkFlowManager] DEBUG query(JDBCObjStore.java:258) - Query result 0 rows, time =6 ms
2018-05-04 15:39:04,923 [WorkFlowManager] DEBUG startWorkFlowProcessing(WorkFlowManager.java:827) - Started processing Workflows, count: 0
2018-05-04 15:39:07,654 [ORR-InfraMgr:D941DC03FB] DEBUG getNextTransaction(LANServerChannel.java:68) - received transation for requestId 22238
2018-05-04 15:39:07,654 [ORR-InfraMgr:D941DC03FB] INFO  run(OperationRequestReceiver.java:38) - Received operational request, added to queue.
2018-05-04 15:39:07,655 [ORP-1-46] INFO  run(OperationRequestProcessor.java:77) - Executing request... requestId=22238; opName=validateForm
2018-05-04 15:39:07,655 [ORP-1-46] INFO  validateForm(APIProvider.java:1177) - FORM VALIDATE SystemSettings.gitrepo_edit_form
2018-05-04 15:39:07,656 [ORP-1-46] INFO  testURL(AddRepoForm.java:267) - Ping check to stash.ercot.com
2018-05-04 15:39:07,658 [ORP-1-46] INFO  testURL(AddRepoForm.java:278) - Host stash.ercot.com is reachable.
2018-05-04 15:39:07,658 [ORP-1-46] INFO  testURL(AddRepoForm.java:287) - Connection check...
2018-05-04 15:39:07,923 [WorkFlowManager] DEBUG query(JDBCObjStore.java:195) - Query table --> limit -1 offset -1
2018-05-04 15:39:07,923 [WorkFlowManager] DEBUG query(JDBCObjStore.java:204) - Executing query (MySQL)
2018-05-04 15:39:07,923 [WorkFlowManager] DEBUG parseJDOQL(JDBCObjStore.java:816) - Incase of SQLInjection Excpetion below, query executed by POJO:class com.cloupia.model.cIM.WorkFlow
2018-05-04 15:39:07,923 [WorkFlowManager] DEBUG convertToJDBCQuery(QueryParser.java:106) -  jdoQuery priority <= 0 && adminStatus == 1 && executionStatus <= 1 && futureStartTime <= 1525448347923
2018-05-04 15:39:07,923 [WorkFlowManager] DEBUG query(JDBCObjStore.java:229) - Executing query SELECT * FROM WORKFLOW_DETAILS A WHERE priority <= 0  AND  adminStatus = 1  AND  executionStatus <= 1  AND  futureStartTime <= 1525448347923
2018-05-04 15:39:07,929 [WorkFlowManager] DEBUG query(JDBCObjStore.java:258) - Query result 0 rows, time =6 ms
2018-05-04 15:39:07,930 [WorkFlowManager] DEBUG startWorkFlowProcessing(WorkFlowManager.java:827) - Started processing Workflows, count: 0
2018-05-04 15:39:08,340 [ORP-1-46] INFO  testURL(AddRepoForm.java:296) - Connected successfully to: https://stash.ercot.com/projects/UCSD
2018-05-04 15:39:08,342 [ORP-1-46] INFO  validateLogin(AddRepoForm.java:165) - Test login  to stash.ercot.com/projects/UCSD
2018-05-04 15:39:08,754 [ORP-1-46] INFO  run(OperationRequestProcessor.java:138) - Sending response... requestId=22238
2018-05-04 15:39:08,754 [ORP-1-46] DEBUG sendReply(LANServerChannel.java:80) - sending reply ...
2018-05-04 15:39:10,930 [WorkFlowManager] DEBUG query(JDBCObjStore.java:195) - Query table --> limit -1 offset -1
2018-05-04 15:39:10,930 [WorkFlowManager] DEBUG query(JDBCObjStore.java:204) - Executing query (MySQL)
2018-05-04 15:39:10,930 [WorkFlowManager] DEBUG parseJDOQL(JDBCObjStore.java:816) - Incase of SQLInjection Excpetion below, query executed by POJO:class com.cloupia.model.cIM.WorkFlow
2018-05-04 15:39:10,930 [WorkFlowManager] DEBUG convertToJDBCQuery(QueryParser.java:106) -  jdoQuery priority <= 1 && adminStatus == 1 && executionStatus <= 1 && futureStartTime <= 1525448350930
2018-05-04 15:39:10,930 [WorkFlowManager] DEBUG query(JDBCObjStore.java:229) - Executing query SELECT * FROM WORKFLOW_DETAILS A WHERE priority <= 1  AND  adminStatus = 1  AND  executionStatus <= 1  AND  futureStartTime <= 1525448350930
2018-05-04 15:39:10,936 [WorkFlowManager] DEBUG query(JDBCObjStore.java:258) - Query result 0 rows, time =6 ms
2018-05-04 15:39:10,937 [WorkFlowManager] DEBUG startWorkFlowProcessing(WorkFlowManager.java:827) - Started processing Workflows, count: 0
Cisco UCS X-Series Energy Efficiency Offer
