hherring
Task NameAdd Disk to VM using Best Datastore
Description
Prerequisites
Tested on 5.4
CategoryWorkflow
ComponentsvSphere 5.x
User InputsVM, DiskType, DiskSizeGb
  8. Click "Submit".
Workflow Name:
Workflow:
Input Variables:
Importing with Custom Tasks:
Execution Log:
Service Request ID: 466
Workflow Inputs:
- Disk Size (GB)
- Select Disk Type
- Select VM
Jun 20, 2016 22:47:37 UTC Request submitted
Jun 20, 2016 22:47:40 UTC Executing workflow item number 1
Jun 20, 2016 22:47:40 UTC Completed workflow item number 0, with status Completed
Jun 20, 2016 22:47:47 UTC Executing workflow item number 2
Jun 20, 2016 22:47:47 UTC Trigger context executeWorkFlowStep called
Jun 20, 2016 22:47:47 UTC Executing custom action Add Disk to VM using Best Datastore (custom_getVMSummary)
Jun 20, 2016 22:47:47 UTC Executing custom script for getVMSummary
Jun 20, 2016 22:47:47 UTC vmId = 249
Jun 20, 2016 22:47:47 UTC Overview_VM_ID = 249
Jun 20, 2016 22:47:47 UTC Overview_Instance_Name = nsstest2
Jun 20, 2016 22:47:47 UTC Overview_Status = ON (poweredOn)
Jun 20, 2016 22:47:47 UTC Overview_IP_Address = 192.168.9.177
Jun 20, 2016 22:47:47 UTC Overview_Hostname = NSSTEST2
Jun 20, 2016 22:47:47 UTC Overview_Image_ID = nsstest2
Jun 20, 2016 22:47:47 UTC Overview_Cloud_Name = bbg-vc
Jun 20, 2016 22:47:47 UTC Overview_Cloud_Type = VMWare
Jun 20, 2016 22:47:47 UTC Ownership_Group = Default Group
Jun 20, 2016 22:47:47 UTC Ownership_vDC = bbg-nss-vdc
Jun 20, 2016 22:47:47 UTC Ownership_Category = Generic VM
Jun 20, 2016 22:47:47 UTC Ownership_Service_Request_ID = 169
Jun 20, 2016 22:47:47 UTC Ownership_Label = okay to delete
Jun 20, 2016 22:47:47 UTC Ownership_Provisioned_Time = Mar 24, 2016 17:57:06 UTC
Jun 20, 2016 22:47:47 UTC Ownership_Scheduled_Termination_Time =
Jun 20, 2016 22:47:47 UTC Overview_Host_Node = 192.168.10.50
Jun 20, 2016 22:47:47 UTC Network_Port_Group = Production 192.168.40.0
Jun 20, 2016 22:47:47 UTC Network_VLAN_ID = 0
Jun 20, 2016 22:47:47 UTC Network_No_of_vNics = 1
Jun 20, 2016 22:47:47 UTC Network_vNic_Mac_Address = 00:50:56:ba:8c:e2
Jun 20, 2016 22:47:47 UTC Network_vNic_Device_Config_Id = 4000
Jun 20, 2016 22:47:47 UTC Overview_Boot_Time = May 04, 2016 00:18:23 UTC
Jun 20, 2016 22:47:47 UTC Overview_Config_Name = nsstest2
Jun 20, 2016 22:47:47 UTC Overview_VM_Version = 7
Jun 20, 2016 22:47:47 UTC Resources_Resource_Pool = Resources
Jun 20, 2016 22:47:47 UTC Resources_Num_Virtual_CPUs = 1
Jun 20, 2016 22:47:47 UTC Resources_CPU_Reserved_MHz = 0
Jun 20, 2016 22:47:47 UTC Resources_CPU_Limit_MHz = -1
Jun 20, 2016 22:47:47 UTC Resources_CPU_Overhead_Limit_MHz = 0
Jun 20, 2016 22:47:47 UTC Resources_CPU_Shares = 1000
Jun 20, 2016 22:47:47 UTC Resources_Memory_MB = 1024
Jun 20, 2016 22:47:47 UTC Resources_Memory_Reserved_MB = 0
Jun 20, 2016 22:47:47 UTC Resources_Memory_Limit_MB = 0
Jun 20, 2016 22:47:47 UTC Resources_Memory_Overhead_Limit_MB = 49
Jun 20, 2016 22:47:47 UTC Resources_Memory_Shares = 40960
Jun 20, 2016 22:47:47 UTC Storage_Total_Provisioned_GB = 52.120000000000005
Jun 20, 2016 22:47:47 UTC Storage_Committed_GB = 14.03
Jun 20, 2016 22:47:47 UTC Storage_Uncommitted_GB = 38.09
Jun 20, 2016 22:47:47 UTC Storage_Non_shared_GB = 14.03
Jun 20, 2016 22:47:47 UTC Storage_Data_Store_Names = mgmt data store, prod datastore 1, prod datastore 2
Jun 20, 2016 22:47:47 UTC Storage_VM_Path = [prod datastore 1] nsstest2/nsstest2.vmx
Jun 20, 2016 22:47:47 UTC Guest_Information_Guest_OS = Microsoft Windows Server 2008 R2 (64-bit)
Jun 20, 2016 22:47:47 UTC Guest_Information_Guest_State = running
Jun 20, 2016 22:47:47 UTC Guest_Information_Tools_Status = guestToolsRunning
Jun 20, 2016 22:47:47 UTC Guest_Information_Tools_Version = 9344
Jun 20, 2016 22:47:47 UTC Options_Default_PowerOff_Type = soft
Jun 20, 2016 22:47:47 UTC Processing output: Overview_VM_ID
Jun 20, 2016 22:47:47 UTC Processing output: Overview_Instance_Name
Jun 20, 2016 22:47:47 UTC Processing output: Overview_Status
Jun 20, 2016 22:47:47 UTC Processing output: Overview_IP_Address
Jun 20, 2016 22:47:47 UTC Processing output: Overview_Hostname
Jun 20, 2016 22:47:47 UTC Processing output: Overview_Image_ID
Jun 20, 2016 22:47:47 UTC Processing output: Overview_Cloud_Name
Jun 20, 2016 22:47:47 UTC Processing output: Overview_Cloud_Type
Jun 20, 2016 22:47:47 UTC Processing output: Ownership_Group
Jun 20, 2016 22:47:48 UTC Processing output: Ownership_vDC
Jun 20, 2016 22:47:48 UTC Processing output: Ownership_Category
Jun 20, 2016 22:47:48 UTC Processing output: Ownership_Service_Request_ID
Jun 20, 2016 22:47:48 UTC Processing output: Ownership_Label
Jun 20, 2016 22:47:48 UTC Processing output: Ownership_Provisioned_Time
Jun 20, 2016 22:47:48 UTC Processing output: Ownership_Scheduled_Termination_Time
Jun 20, 2016 22:47:48 UTC Processing output: Overview_Host_Node
Jun 20, 2016 22:47:48 UTC Processing output: Network_Port_Group
Jun 20, 2016 22:47:48 UTC Processing output: Network_VLAN_ID
Jun 20, 2016 22:47:48 UTC Processing output: Network_No_of_vNics
Jun 20, 2016 22:47:48 UTC Processing output: Network_vNic_Mac_Address
Jun 20, 2016 22:47:48 UTC Processing output: Network_vNic_Device_Config_Id
Jun 20, 2016 22:47:48 UTC Processing output: Overview_Boot_Time
Jun 20, 2016 22:47:48 UTC Processing output: Overview_Config_Name
Jun 20, 2016 22:47:48 UTC Processing output: Overview_VM_Version
Jun 20, 2016 22:47:48 UTC Processing output: Resources_Resource_Pool
Jun 20, 2016 22:47:48 UTC Processing output: Resources_Num_Virtual_CPUs
Jun 20, 2016 22:47:48 UTC Processing output: Resources_CPU_Reserved_MHz
Jun 20, 2016 22:47:49 UTC Processing output: Resources_CPU_Limit_MHz
Jun 20, 2016 22:47:49 UTC Processing output: Resources_CPU_Overhead_Limit_MHz
Jun 20, 2016 22:47:49 UTC Processing output: Resources_CPU_Shares
Jun 20, 2016 22:47:49 UTC Processing output: Resources_Memory_MB
Jun 20, 2016 22:47:49 UTC Processing output: Resources_Memory_Reserved_MB
Jun 20, 2016 22:47:49 UTC Processing output: Resources_Memory_Limit_MB
Jun 20, 2016 22:47:49 UTC Processing output: Resources_Memory_Overhead_Limit_MB
Jun 20, 2016 22:47:49 UTC Processing output: Resources_Memory_Shares
Jun 20, 2016 22:47:49 UTC Processing output: Storage_Total_Provisioned_GB
Jun 20, 2016 22:47:49 UTC Processing output: Storage_Committed_GB
Jun 20, 2016 22:47:49 UTC Processing output: Storage_Uncommitted_GB
Jun 20, 2016 22:47:49 UTC Processing output: Storage_Non_shared_GB
Jun 20, 2016 22:47:49 UTC Processing output: Storage_Data_Store_Names
Jun 20, 2016 22:47:49 UTC Processing output: Storage_VM_Path
Jun 20, 2016 22:47:49 UTC Processing output: Guest_Information_Guest_OS
Jun 20, 2016 22:47:49 UTC Processing output: Guest_Information_Guest_State
Jun 20, 2016 22:47:49 UTC Processing output: Guest_Information_Tools_Status
Jun 20, 2016 22:47:49 UTC Processing output: Guest_Information_Tools_Version
Jun 20, 2016 22:47:50 UTC Processing output: Options_Default_PowerOff_Type
Jun 20, 2016 22:47:50 UTC Task #1 (Add Disk to VM using Best Datastore (custom_getVMSummary)) completed successfully in 3 seconds
Jun 20, 2016 22:47:50 UTC Input/Output values for Task #1 (Add Disk to VM using Best Datastore (custom_getVMSummary)):
Jun 20, 2016 22:47:50 UTC [Mapped Input: VM_Id = 249]
Jun 20, 2016 22:47:50 UTC [Output: Overview_VM_ID = 249]
Jun 20, 2016 22:47:50 UTC [Output: Overview_Instance_Name = nsstest2]
Jun 20, 2016 22:47:50 UTC [Output: Overview_Status = ON (poweredOn)]
Jun 20, 2016 22:47:50 UTC [Output: Overview_IP_Address = 192.168.9.177]
Jun 20, 2016 22:47:50 UTC [Output: Overview_Hostname = NSSTEST2]
Jun 20, 2016 22:47:50 UTC [Output: Overview_Image_ID = nsstest2]
Jun 20, 2016 22:47:50 UTC [Output: Overview_Cloud_Name = bbg-vc]
Jun 20, 2016 22:47:50 UTC [Output: Overview_Cloud_Type = VMWare]
Jun 20, 2016 22:47:50 UTC [Output: Ownership_Group = Default Group]
Jun 20, 2016 22:47:50 UTC [Output: Ownership_vDC = bbg-nss-vdc]
Jun 20, 2016 22:47:50 UTC [Output: Ownership_Category = Generic VM]
Jun 20, 2016 22:47:50 UTC [Output: Ownership_Service_Request_ID = 169]
Jun 20, 2016 22:47:50 UTC [Output: Ownership_Label = okay to delete]
Jun 20, 2016 22:47:50 UTC [Output: Ownership_Provisioned_Time = Mar 24, 2016 17:57:06 UTC]
Jun 20, 2016 22:47:50 UTC [Output: Ownership_Scheduled_Termination_Time = ]
Jun 20, 2016 22:47:50 UTC [Output: Overview_Host_Node = 192.168.10.50]
Jun 20, 2016 22:47:50 UTC [Output: Network_Port_Group = Production 192.168.40.0]
Jun 20, 2016 22:47:50 UTC [Output: Network_VLAN_ID = 0]
Jun 20, 2016 22:47:50 UTC [Output: Network_No_of_vNics = 1]
Jun 20, 2016 22:47:50 UTC [Output: Network_vNic_Mac_Address = 00:50:56:ba:8c:e2]
Jun 20, 2016 22:47:50 UTC [Output: Network_vNic_Device_Config_Id = 4000]
Jun 20, 2016 22:47:50 UTC [Output: Overview_Boot_Time = May 04, 2016 00:18:23 UTC]
Jun 20, 2016 22:47:50 UTC [Output: Overview_Config_Name = nsstest2]
Jun 20, 2016 22:47:50 UTC [Output: Overview_VM_Version = 7]
Jun 20, 2016 22:47:50 UTC [Output: Resources_Resource_Pool = Resources]
Jun 20, 2016 22:47:50 UTC [Output: Resources_Num_Virtual_CPUs = 1]
Jun 20, 2016 22:47:50 UTC [Output: Resources_CPU_Reserved_MHz = 0]
Jun 20, 2016 22:47:50 UTC [Output: Resources_CPU_Limit_MHz = -1]
Jun 20, 2016 22:47:50 UTC [Output: Resources_CPU_Overhead_Limit_MHz = 0]
Jun 20, 2016 22:47:50 UTC [Output: Resources_CPU_Shares = 1000]
Jun 20, 2016 22:47:50 UTC [Output: Resources_Memory_MB = 1024]
Jun 20, 2016 22:47:50 UTC [Output: Resources_Memory_Reserved_MB = 0]
Jun 20, 2016 22:47:50 UTC [Output: Resources_Memory_Limit_MB = 0]
Jun 20, 2016 22:47:50 UTC [Output: Resources_Memory_Overhead_Limit_MB = 49]
Jun 20, 2016 22:47:50 UTC [Output: Resources_Memory_Shares = 40960]
Jun 20, 2016 22:47:50 UTC [Output: Storage_Total_Provisioned_GB = 52.120000000000005]
Jun 20, 2016 22:47:50 UTC [Output: Storage_Committed_GB = 14.03]
Jun 20, 2016 22:47:50 UTC [Output: Storage_Uncommitted_GB = 38.09]
Jun 20, 2016 22:47:50 UTC [Output: Storage_Non_shared_GB = 14.03]
Jun 20, 2016 22:47:50 UTC [Output: Storage_Data_Store_Names = mgmt data store, prod datastore 1, prod datastore 2]
Jun 20, 2016 22:47:50 UTC [Output: Storage_VM_Path = [prod datastore 1] nsstest2/nsstest2.vmx]
Jun 20, 2016 22:47:50 UTC [Output: Guest_Information_Guest_OS = Microsoft Windows Server 2008 R2 (64-bit)]
Jun 20, 2016 22:47:50 UTC [Output: Guest_Information_Guest_State = running]
Jun 20, 2016 22:47:50 UTC [Output: Guest_Information_Tools_Status = guestToolsRunning]
Jun 20, 2016 22:47:50 UTC [Output: Guest_Information_Tools_Version = 9344]
Jun 20, 2016 22:47:50 UTC [Output: Options_Default_PowerOff_Type = soft]
Jun 20, 2016 22:47:50 UTC Completed workflow item number 1, with status Completed
Jun 20, 2016 22:47:56 UTC Executing workflow item number 3
Jun 20, 2016 22:47:56 UTC Trigger context executeWorkFlowStep called
Jun 20, 2016 22:47:56 UTC Executing custom action Add Disk to VM using Best Datastore (custom_VARIABLE_CONVERTER_DISKSIZE)
Jun 20, 2016 22:47:56 UTC Executing custom script for VARIABLE_CONVERTER_DISKSIZE
Jun 20, 2016 22:47:56 UTC a1 ; 1
Jun 20, 2016 22:47:56 UTC Processing output: A_Prime
Jun 20, 2016 22:47:56 UTC Task #2 (Add Disk to VM using Best Datastore (custom_VARIABLE_CONVERTER_DISKSIZE)) completed successfully in 0 seconds
Jun 20, 2016 22:47:56 UTC Input/Output values for Task #2 (Add Disk to VM using Best Datastore (custom_VARIABLE_CONVERTER_DISKSIZE)):
Jun 20, 2016 22:47:56 UTC [Mapped Input: A = 1]
Jun 20, 2016 22:47:56 UTC [Output: A_Prime = 1]
Jun 20, 2016 22:47:56 UTC Completed workflow item number 2, with status Completed
Jun 20, 2016 22:48:02 UTC Executing workflow item number 4
Jun 20, 2016 22:48:02 UTC Trigger context executeWorkFlowStep called
Jun 20, 2016 22:48:02 UTC Executing custom action Add Disk to VM using Best Datastore (custom_NSS Get Best Datastore)
Jun 20, 2016 22:48:02 UTC Executing custom script for NSS Get Best Datastore
Jun 20, 2016 22:48:02 UTC cloudName = bbg-vc
Jun 20, 2016 22:48:02 UTC diskSize = 1
Jun 20, 2016 22:48:02 UTC vmDatastoreNames = mgmt data store, prod datastore 1, prod datastore 2
Jun 20, 2016 22:48:02 UTC vmDatastoreNameArray = mgmt data store,prod datastore 1,prod datastore 2
Jun 20, 2016 22:48:03 UTC Total Datastores found: 54
Jun 20, 2016 22:48:03 UTC Datastore datastore1 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore datastore1 (1) skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore netapp-vmfs skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore netapp-vmfs-2 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore local_hollywood_scality skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore netapp skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore local_madison_scality skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore local_Portland_scality skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore local_blacksburg_scality skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore local_manhattan_scality skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore aci-vmfs-1 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore aci-vmfs-2 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore NFS-test skipped because our VM isn't using it
Jun 20, 2016 22:48:03 UTC Found VM datastore prod datastore 2 in report
Jun 20, 2016 22:48:03 UTC Added the following Datastore: prod datastore 2::500.0::304.861328125::67.74362
Jun 20, 2016 22:48:03 UTC Found VM datastore mgmt data store in report
Jun 20, 2016 22:48:03 UTC Added the following Datastore: mgmt data store::500.0::304.26953125::26.25712000000001
Jun 20, 2016 22:48:03 UTC Datastore esx1-boot skipped because our VM isn't using it
Jun 20, 2016 22:48:03 UTC Datastore esx2-boot skipped because our VM isn't using it
Jun 20, 2016 22:48:03 UTC Datastore datastore1 skipped because our VM isn't using it
Jun 20, 2016 22:48:03 UTC Found VM datastore prod datastore 1 in report
Jun 20, 2016 22:48:03 UTC Added the following Datastore: prod datastore 1::500.0::294.5830078125::-24.07586
Jun 20, 2016 22:48:03 UTC Datastore esx0-boot skipped because our VM isn't using it
Jun 20, 2016 22:48:03 UTC Datastore templates and iso skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore SSD-FC skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore C210-local-vmfs skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore C210-FC-VMFS skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore c210-local-vmfs-2 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore tah-vmfs-fc-1 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore prod-boot-3 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore 144.21 sanboot skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore tah-templates skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore tah-vmfc-fc-2 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore Nimble03 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore prod-boot-2 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore prod-fc-sas-3 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore prod-fc-sas-2 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore Nimble01 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore prod-boot-1 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore local_33 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore vm_swing skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore Nimble02 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore vm_floater skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore netapp_vmfs skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore prod-fc-sas-1 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore vacs-vmfs1 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC Datastore vacs-vmfs0 skipped because it's not in Cloud bbg-vc
Jun 20, 2016 22:48:03 UTC VM Datastore 0: [prod datastore 2] has 305GB free and is 68% overcommitted
Jun 20, 2016 22:48:03 UTC VM Datastore 1: [mgmt data store] has 304GB free and is 26% overcommitted
Jun 20, 2016 22:48:03 UTC VM Datastore 2: [prod datastore 1] has 295GB free and is -24% overcommitted
Jun 20, 2016 22:48:03 UTC Total Datastores in the Array: 3
Jun 20, 2016 22:48:03 UTC Sorting the array
Jun 20, 2016 22:48:03 UTC Reversing the array
Jun 20, 2016 22:48:03 UTC Getting the top 3
Jun 20, 2016 22:48:03 UTC Now sort by overcommit
Jun 20, 2016 22:48:03 UTC Datastore 0 Free space: 294.5830078125
Jun 20, 2016 22:48:03 UTC Datastore 0 Overcommit: -24.07586
Jun 20, 2016 22:48:03 UTC Datastore 1 Free space: 304.26953125
Jun 20, 2016 22:48:03 UTC Datastore 1 Overcommit: 26.25712000000001
Jun 20, 2016 22:48:03 UTC Datastore 2 Free space: 304.861328125
Jun 20, 2016 22:48:03 UTC Datastore 2 Overcommit: 67.74362
Jun 20, 2016 22:48:03 UTC Best datastore found: prod datastore 1 with Free space 295 and Overcommit% undefined
Jun 20, 2016 22:48:03 UTC Processing output: datastore
Jun 20, 2016 22:48:03 UTC Task #3 (Add Disk to VM using Best Datastore (custom_NSS Get Best Datastore)) completed successfully in 0 seconds
Jun 20, 2016 22:48:03 UTC Input/Output values for Task #3 (Add Disk to VM using Best Datastore (custom_NSS Get Best Datastore)):
Jun 20, 2016 22:48:03 UTC [Mapped Input: Name of vCenter cloud = bbg-vc]
Jun 20, 2016 22:48:03 UTC [Mapped Input: Comma list of Datastore Names = mgmt data store, prod datastore 1, prod datastore 2]
Jun 20, 2016 22:48:03 UTC [Mapped Input: Disk Size = 1]
Jun 20, 2016 22:48:03 UTC [Output: datastore = prod datastore 1]
Jun 20, 2016 22:48:03 UTC Completed workflow item number 3, with status Completed
Jun 20, 2016 22:48:08 UTC Executing workflow item number 5
Jun 20, 2016 22:48:08 UTC Trigger context executeWorkFlowStep called
Jun 20, 2016 22:48:08 UTC Executing custom action Add Disk to VM using Best Datastore (custom_VARIABLE_CONVERTER_DATASTORE)
Jun 20, 2016 22:48:08 UTC Executing custom script for VARIABLE_CONVERTER_DATASTORE
Jun 20, 2016 22:48:08 UTC a1 ; prod datastore 1
Jun 20, 2016 22:48:08 UTC Processing output: A_Prime
Jun 20, 2016 22:48:08 UTC Task #4 (Add Disk to VM using Best Datastore (custom_VARIABLE_CONVERTER_DATASTORE)) completed successfully in 0 seconds
Jun 20, 2016 22:48:08 UTC Input/Output values for Task #4 (Add Disk to VM using Best Datastore (custom_VARIABLE_CONVERTER_DATASTORE)):
Jun 20, 2016 22:48:08 UTC [Mapped Input: A = prod datastore 1]
Jun 20, 2016 22:48:08 UTC [Output: A_Prime = prod datastore 1]
Jun 20, 2016 22:48:08 UTC Completed workflow item number 4, with status Completed
Jun 20, 2016 22:48:11 UTC Executing workflow item number 6
Jun 20, 2016 22:48:11 UTC Trigger context executeWorkFlowStep called
Jun 20, 2016 22:48:11 UTC Executing custom action Add Disk to VM using Best Datastore (Create VM Disk)
Jun 20, 2016 22:48:11 UTC Executing create disk action on VM 249 as part of custom action Add Disk to VM using Best Datastore, (datastore=prod datastore 1, New Disk Size(GB)=1)
Jun 20, 2016 22:48:11 UTC Waiting for action to complete
Jun 20, 2016 22:48:41 UTC Action Complete
Jun 20, 2016 22:48:41 UTC Task #5 (Add Disk to VM using Best Datastore (Create VM Disk)) completed successfully in 30 seconds
Jun 20, 2016 22:48:41 UTC Input/Output values for Task #5 (Add Disk to VM using Best Datastore (Create VM Disk)):
Jun 20, 2016 22:48:41 UTC [Mapped Input: Select VM = 249]
Jun 20, 2016 22:48:41 UTC [Mapped Input: Disk Size (GB) = 1]
Jun 20, 2016 22:48:41 UTC [Mapped Input: Select Disk Type = 0]
Jun 20, 2016 22:48:41 UTC [Mapped Input: Select Datastore = prod datastore 1]
Jun 20, 2016 22:48:41 UTC [Local Input: Thin Provisioning = true]
Jun 20, 2016 22:48:41 UTC Completed workflow item number 5, with status Completed
Jun 20, 2016 22:48:44 UTC Executing workflow item number 7
Jun 20, 2016 22:48:44 UTC Completed workflow item number 6, with status Completed
Jun 20, 2016 22:48:51 UTC Email notification sent successfully
Orf Gelbrich
Thank you for adding this. Much appreciated.
