Orf Gelbrich
Task NameUCSD Create your own DB Entries / Report / Mulit Column LOV
Description
  1. UCSD Create your own DB Entries / Report / Mulit Column LOV
Prerequisites
  1. Tested on 5.4
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Inspiration came from Stanly Abraham. Thank you very much.
The possible workflow input for the workflow create from a custom report:
After the selection:
The run with the hidden management column:
The workflow result:
Different run of this workflow:
The workflow for illustration:
The e-mail set up with the report variable:
The global variable set up in the workflow:
Report_1 is the custom report variable!
The script module Tabular Report
The script module Tabular Report Column definitions:
Note column D is hidden and is the result from the selection process!
The script that gets generated from the creation of the columns:
Make sure your code is between the start and end of the "your implementation"!
If not you will re-create it!
The script for this example.
This could be read in from CSV file or some SQL statements as well.
Note for export of workflow:
Make sure the script module is checked!
RobinSchrooten
Community Member
I like the idea of using the tabular report, but is there a possibility to put all information of the report into the mail?
The resulting mail now only reports Steel or Aluminium truck. Is it possible to also add the brand an colour in the mail?
Orf Gelbrich
only way I have seen this have a filed that is hidden and looks like this
Ford,Aluminium,red  and you make the the main filed.
