Orf Gelbrich
This is an example of creating a input validator in this screen.  The inspiration came from the RegEx input validator.
The location for this is in:
     Policies -> Orchestration -> Custom Workflow Inputs (select validated input):
Basic Question is how is a new input validator in this screen created:
The next steps will answer that.
Eclipse is needed for the next step to compile the JAVA code.
     Notes:  This is not an exercise in how to set up Eclipse (please read Eclipse manual for that)
     Notes:  The inframgr.jar file was copied from the UCSD appliance /opt/infra/inframgr/inframgr.jar
Here is a picture of the over all Eclipse setup (note the left side and oder and placement):
Here is the Java Code:
Note:  Yes certain things are hard coded (this is an example one may want to use a credential Policy)
Note: I am using an SSH connection to talk to the UCSD appliance itself to execute a Linux Script)
package com.cloupia.service.cIM.inframgr.customactions.validators;
import com.cloupia.lib.util.ssh.SSHClient;
import com.cloupia.lib.util.ssh.SSHCommandOutput;
//import org.apache.log4j.Logger;
import com.cloupia.service.cIM.inframgr.customactions.UserInputValidatorIf;
public class NameValidatorPreProcessingCustom implements UserInputValidatorIf {
// static Logger logger = Logger.getLogger(NameValidator.class);
String regex = "[\"%&'*+,./:;<=>?^|\\\\]";
public NameValidatorPreProcessingCustom() {
@Override
public String getValidatorDescription() {
return "Custom Account name validator (SSH11 Pre Processing)";
@Override
public void validateUserInput(String name) throws Exception {
String returnParam = null;
try
returnParam = executeCommandThroughSSH( "127.0.0.1", 22, "root", "changeme",
"/tmp/preprocessing.sh", name);
} catch (Exception e) {
//for any exception being thrown by executeCommandThroughSSH,
//overwrite with your execption message
throw new Exception("**** YOUR EXCEPTION MESSAGE GOES HERE (SSh busted)**** ");
if ( returnParam != null && returnParam.trim().equals("1") )
throw new Exception("/tmp/preprocessing.sh script returned Error Account Number is not 12345");
public String executeCommandThroughSSH(
String host, int port, String userName, String password,
String command, String parameter) throws Exception
SSHClient client = new SSHClient(host, port, userName, password);
client.connect();
SSHCommandOutput o = client.executeCommand(command +" "+parameter);
if( o.getExitCode() != 0 )
throw new Exception("Error executing the command");
String stdOut = o.getStdOut();
return stdOut;
public static void main(String args[]) {
NameValidatorPreProcessingCustom abc = new NameValidatorPreProcessingCustom();
abc.getValidatorDescription();
System.out.println(abc.getValidatorDescription());
try {
abc.validateUserInput("12345");
// TODO Auto-generated catch block
e.printStackTrace();
The Linux script is here in /tmp:
    Note:  Make sure it is chmod +x 'ed
#!/bin/bash
date > /tmp/preprocessing.log
echo $1 >> /tmp/preprocessing.log
if [ "$1" == "12345" ];  then
  echo "0"
else
  echo "1"
fi
Here are the steps to export the JAR file:
Select Export:
Make next screen look like this:
Make the following screen look like this:
Resulting jar file is attached.
Import the JAR file:
Policies -> Orchestration -> Script Module (DynamicPreProcessingModuleSSH11):
Double click on the newly created item:
Select JAR and hot the green Plus button:
Load the file:
Result:
Register the new functions
The workflow that needs to be run to load the functions:
Note the selector for this workflow to load at UCSD Re-boot:
Custom task to register the code:
//importPackage(java.lang);
//loadJar("DynamicPreProcessingModuleSSH11/DynamicPreProcessingSSH11.jar");
//importPackage(Packages.com.cloupia.service.cIM.inframgr.customactions.validators);
//importClass(com.cloupia.service.cIM.inframgr.customactions.validators.UserInputValidatorRegistry)
//var dynValidator = new Packages.com.cloupia.service.cIM.inframgr.customactions.validators.NameValidatorPreProcessingCustom
//var validatorRegistry = UserInputValidatorRegistry.getInstance();
//validatorRegistry.addValidator(dynValidator.getValidatorDescription(),dynValidator.getClass());
//logger.addInfo( "loaded custom validator: "+dynValidator.getValidatorDescription() );
//loadJar("SXSZ/Cisco12345_InputValidator.jar");
importPackage(Packages.com.cloupia.service.cIM.inframgr.customactions.validators.dynamic);
importClass(com.cloupia.service.cIM.inframgr.customactions.CustomActionUtil)
importClass(com.cloupia.service.cIM.inframgr.customactions.WorkflowInputTypeRegistry)
importClass(com.cloupia.service.cIM.inframgr.customactions.WorkflowInputFieldTypeDeclaration)
//initializing the validator object
//var dynValidator = new Packages.com.cloupia.service.cIM.inframgr.customactions.validators.dynamic.MyCisco12345Validator
//get access to validators registry
//add the new validator within the validator registry
//get list of custom input types used within UCSD
var customInputTypesList = CustomActionUtil.getWFCustomLOVInputs();
//get access to all input types registry
var wfInputRegistry = WorkflowInputTypeRegistry.getInstance();
//iterate over custom wf input types
for(var i=0;i<customInputTypesList.size();i++)
  var WFCustomLovInputType = customInputTypesList.get(i);
  var validatorNameSetWithinCustomWfInput = WFCustomLovInputType.getValidator();
  //if we have a custom input type which makes use of the current validator
  if( dynValidator.getValidatorDescription().equals(validatorNameSetWithinCustomWfInput) )
    var customWfInputName = WFCustomLovInputType.getWfinputType();
    //retrieve the declaration  for the custom input type
    var customWfInputDeclaration = wfInputRegistry.getDeclaration(customWfInputName);
    //ensure we set the validator within the input type declaration
    customWfInputDeclaration.setValidator( dynValidator.getClass().newInstance() );
Workflow is attached and workflow run:
Creating the custom variable:
Test workflow for input variable:
Workflow execution:
UCSD 6.0 End user look and feel:
Log file:
[root@localhost tmp]# cat preprocessing.log
Wed Sep 21 22:55:01 UTC 2016
abc
Log file with correct input:
Wed Sep 21 22:57:10 UTC 2016
12345
Workflow is attached.
Incase some one wants to handle this via open automation vs. script module here is the code to register the new validator:
Registration code below:
package com.cloupia.feature.customLacValidators;
import java.util.List;
import com.cloupia.service.cIM.inframgr.AbstractCloupiaModule;
import com.cloupia.service.cIM.inframgr.AbstractTask;
import com.cloupia.service.cIM.inframgr.CustomFeatureRegistry;
import com.cloupia.service.cIM.inframgr.collector.controller.CollectorFactory;
import com.cloupia.service.cIM.inframgr.customactions.CustomActionUtil;
import com.cloupia.service.cIM.inframgr.customactions.WFCustomLovInput;
import com.cloupia.service.cIM.inframgr.customactions.validators.UserInputValidatorRegistry;
import com.cloupia.service.cIM.inframgr.customactions.WorkflowInputTypeRegistry;
import com.cloupia.service.cIM.inframgr.customactions.WorkflowInputFieldTypeDeclaration;
import com.cloupia.service.cIM.inframgr.customactions.lacValidators.AccountNumber;
import com.cloupia.service.cIM.inframgr.customactions.lacValidators.VMName;
import com.cloupia.service.cIM.inframgr.reports.simplified.CloupiaReport;
public class customLacValidatorsModule extends AbstractCloupiaModule {
public static final String CUSTOM_INDICATOR = "CUSTOM ";
public static final String VALIDATOR_ACCOUNT_NAME = "LAC Account Validator";
public static final String VALIDATOR_VM_NAME = "LAC VM Validator";
private static Logger logger = Logger.getLogger(customLacValidatorsModule.class);
public customLacValidatorsModule() {
// TODO Auto-generated constructor stub
@Override
public CollectorFactory[] getCollectors() {
// This class provides the ability to load and register dynamic
// field validators, therefore this class does not contain collectors
return null;
@Override
public CloupiaReport[] getReports() {
// field validators, therefore this class does not contain reports
return null;
@Override
public AbstractTask[] getTasks() {
// field validators, therefore this class does not contain tasks
return null;
@Override
public void onStart(CustomFeatureRegistry arg0) {
// TODO add method call to another class for the registrations here?
UserInputValidatorRegistry validatorRegistry = UserInputValidatorRegistry.getInstance();
AccountNumber acctValidator = new AccountNumber();
validatorRegistry.addValidator(VALIDATOR_ACCOUNT_NAME,acctValidator.getClass());
logger.info(CUSTOM_INDICATOR + "Loaded custom validator: "+VALIDATOR_ACCOUNT_NAME+": " +acctValidator.getValidatorDescription() );
VMName vmValidator = new VMName();
validatorRegistry.addValidator(VALIDATOR_VM_NAME,vmValidator.getClass());
logger.info(CUSTOM_INDICATOR + "Loaded custom validator: "+VALIDATOR_VM_NAME+": " +vmValidator.getValidatorDescription() );
List<WFCustomLovInput> customInputTypesList = null;
try {
logger.error(CUSTOM_INDICATOR + "Could not obtain custom input list. Custom field validations will not function properly.");
WorkflowInputTypeRegistry wfInputRegistry = WorkflowInputTypeRegistry.getInstance();
for (int i=0;i<customInputTypesList.size();i++)
  WFCustomLovInput WFCustomLovInputType = customInputTypesList.get(i);
  String validatorNameSetWithinCustomWfInput = WFCustomLovInputType.getValidator();
  //if we have a custom input type which makes use of the current VALIDATOR_ACCOUNT_NAME validator
  if( VALIDATOR_ACCOUNT_NAME.equals(validatorNameSetWithinCustomWfInput) )
    String customWfInputName = WFCustomLovInputType.getWfinputType();
    WorkflowInputFieldTypeDeclaration customWfInputDeclaration = wfInputRegistry.getDeclaration(customWfInputName);
    customWfInputDeclaration.setValidator(acctValidator);
  //if we have a custom input type which makes use of the current VALIDATOR_VM_NAME validator
  if( VALIDATOR_VM_NAME.equals(validatorNameSetWithinCustomWfInput) )
    customWfInputDeclaration.setValidator(vmValidator);
Bash Script Example to test for different RegEx :
cat preprocessingregex.sh
#!/bin/bash
date > /tmp/preprocessingregex.log
echo $1 >> /tmp/preprocessingregex.log
a="No Match"
# test for San Francisco
[[ $1 =~ ^SFO[0-9]{3}$ ]] && a="SFO match"
# test for New York
[[ $1 =~ ^NY[0-9]{3}$ ]] && a="New York match"
# test for Chicago
[[ $1 =~ ^ORD[0-9]{3}$ ]] && a="Chicago match"
echo $a
Another version of bash script:
#!/bin/bash
echo $0 >> /tmp/preprocessingregex.log
# test for server name existance
export c=`grep -m1 "^$1$" /tmp/servers.txt | wc -l`
if [ $c -gt 0 ]; then
  a="40"
  echo $a
  exit
fi
a="1"
# Start with SFO and followed by any char
if [[ $1 =~ ^[S][F][O].*$ ]];  then
  if [[ $1 =~ ^[S][F][O][0-9]{3}$ ]]; then
  # Adheres to SFO regex
  a="0"
  echo $a
  exit
  else
  # Started with SFO but does not adhere to SFO regex(1)
  a="10"
  echo $a
  exit
  fi
fi
# test for New York
# Start with NY and followed by any char
if [[ $1 =~ ^[N][Y].*$ ]];  then
  if [[ $1 =~ ^[N][Y][0-9]{3}$ ]]; then
  # Adheres to NY regex
  a="0"
  echo $a
  exit
  else
  # Started with NY but does not adhere to NY regex(1)
  a="20"
  echo $a
  exit
  fi
fi
# test for Chicago
# Start with ORD and followed by any char
if [[ $1 =~ ^[O][R][D].*$ ]];  then
  if [[ $1 =~ ^[O][R][D][0-9]{3}$ ]]; then
  # Adheres to ORD regex
  a="0"
  echo $a
  exit
  else
  # Started with ORD but does not adhere to ORD regex(1)
  a="30"
  echo $a
  exit
  fi
fi
# if a is still set to 1 then it did not adhere to any statements above
echo $a
Another Example:
The Bash script:
[root@localhost tmp]# cat runtime.sh
#!/bin/bash
date > /tmp/runtime.sh.log
echo $0 >> /tmp/runtime.sh.log
echo $1 >> /tmp/runtime.sh.log
a="Did not adhere to any RegEx statements..."
export c=`grep $1 /tmp/servers.txt | wc -l`
  a="Server Name found in /tmp/server.txt"
  echo $a
  exit
fi
  a="0"
  echo $a
  exit
  else
  a="Started with SFO but does not adhere to SFO regex(1)"
  echo $a
  exit
  fi
fi
# test for New York
  a="0"
  echo $a
  exit
  else
  a="Started with NY but does not adhere to NY regex(1)"
  echo $a
  exit
  fi
fi
# test for Chicago
  a="0"
  echo $a
  exit
  else
  a="Started with ORD but does not adhere to ORD regex(1)"
  echo $a
  exit
  fi
fi
echo $a
The Java Code:
import java.io.*;
@Override
return "Custom Account name validator (SSH20 Pre Processing)";
@Override
  String s = null;
  try
  Process p = Runtime.getRuntime().exec("/tmp/runtime.sh "+name);
  BufferedReader stdInput = new BufferedReader(new InputStreamReader(p.getInputStream()));
  s = stdInput.readLine();
  }catch (Exception e) {
  throw new Exception("**** Runtime EXEC hat issue (20)**** ");
  if ( s != null && !s.trim().equals("0") )
  throw new Exception("Error >"+s+"<");
try
returnParam = executeCommandThroughSSH( "127.0.0.1", 22, "root", "cloupia123",
"/tmp/preprocessingregex.sh", name);
throw new Exception("**** SSH to localhost had issues (18)**** ");
throw new Exception("/tmp/preprocessingregex.sh Error does not adhere to any RegEx (18) ");
if ( returnParam != null && returnParam.trim().equals("10") )
throw new Exception("/tmp/preprocessingregex.sh Error does not adhere to SFO RegEx (18) ");
if ( returnParam != null && returnParam.trim().equals("20") )
throw new Exception("/tmp/preprocessingregex.sh Error does not adhere to NY RegEx (18) ");
if ( returnParam != null && returnParam.trim().equals("30") )
throw new Exception("/tmp/preprocessingregex.sh Error does not adhere to ORD RegEx (18) ");
if ( returnParam != null && returnParam.trim().equals("40") )
throw new Exception("/tmp/preprocessingregex.sh /tmp/servers.txt Server Name Exists already (18) ");
client.connect();
return stdOut;
try {
More Generic JAVA code (also attached jar file)
import java.io.*;
@Override
return "Custom Bash Validation (/usr/local/bin/UCSDPreProcessingRuntime.sh)";
@Override
  String s = null;
  try
  Process p = Runtime.getRuntime().exec("/usr/local/bin/UCSDPreProcessingRuntime.sh "+name);
  throw new Exception("**** Check file /usr/local/bin/UCSDPreProcessingRuntime.sh **** ");
  throw new Exception(s);
try
client.connect();
return stdOut;
try {
Generic Input Validator Installation (tested on UCSD 6.0):
Create script module named: CustomBashValidation
Import jar file into script module: CustomBashValidation_v1.jar
     Policies -> Orchestration -> Script Module -> CustomBashValidation -> JAR -> ADD
Import workflow: CustomBashValidation_v1_Loader.wfdx (unzip first!)
     Policies -> Orchestration -> Workflows -> Import
Run workflow to load new validator: LoadCustomBashValidation_v1_wf1
Download UCSDPREProcessingRuntime.sh and copy to UCSD instance to /usr/local/bin/UCSDPreProcessingRuntime.sh
chmod +x /usr/local/bin/UCSDPreProcessingRuntime.sh
create file to check if a server names does exist:
     (in this customer instance the file gets created from many different locations and the result ends up in /tmp/servers.txt):
     /tmp/servers.txt
          ORD111
          SFO111
          NY111
          ORD222
          SFO222
          SFO333
Create custom workflow input validator and use new Bash validator
          Variable: Servers
          Type: generic text
          Validator:
Create workflow and use newly create variable Servers
Test with:
