Orf Gelbrich
Task Name
Example on how to load a SQL jar file into UCSD via script Module.
Description
Prerequisites
Tested on UCSD 6.0.0.0
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
A thank you goes out to Paul Kunzler for the inspiration:
Fine the SQL jar file on Microsofts web site. I found it here: https://msdn.microsoft.com/en-us/library/ms378526(v=sql.110).aspx
Down load the SQL jar file and extract it:
Create a script module SQL42:
Upload the jar file to UCSD:
The upload result and path:
Create a custom task:
ASCII version (PATH may differ in your install !!!!):
loadJar("SQL42/sqljdbc42.jar");
importClass(com.microsoft.sqlserver.jdbc.SQLServerDataSource);
var ds = new Packages.com.microsoft.sqlserver.jdbc.SQLServerDataSource();
Create workflow using this new task:
Run the workflow:
Export of the workflow does contain the script module and the SQL jar file:
