| Task Name | IModify NetApp Quotas |
| Description | Modify NetApp Quotas |
| Prerequisites | - Tested on 5.2.0.2
| Category | Workflow (and tasks) |
| Components | It has a custom task and sample test workflow.. |
- Download the attached .ZIP file below to your computer. *Remember the location of the saved file on your computer.
- Unzip the file on your computer. Should end up with a .WFD file.
- Log in to UCS Director as a user that has "system-admin" privileges.
- Navigate to "Policies-->Orchestration" and click on "Import".
- Click "Browse" and navigate to the location on your computer where the .WFD file resides. Choose the .WFD file and click "Open".
- Click "Upload" and then "OK" once the file upload is completed. Then click "Next".
- Click the "Select" button next to "Import Workflows". Click the "Check All" button to check all checkboxes and then the "Select" button.
- Click "Submit".
- A new folder should appear in "Policies-->Orchestration" that contains the imported workflow.
Thanks goes out to Brian McDaniel.
The quota screen:
The modify option:
The resulting screen from the selection:
The workflow:
The task inputs:
