rsivapra
Community Member
Task Name
Get Tenant IP Schema
Description
This custom task
  is designed for the workflow “FlexPod Secure Service Container with NetApp
  Application Storage”.
Using an IP
  schema of 10.<groupID>.<containerID>.0/24, this task will return
  the NetApp SVM LIF, ESX VMK interface IP values and NFS export spec to be
  used for secure app storage use cases
Prerequisites
Category
Custom Tasks
Components
UCSD 4.1.x.x
User Inputs
  1. Group ID
  2. Container ID
Output
LIF IP for NetApp SVM
VMK IP POOL for VMK interfaces
NFS_CLIENT_SPEC for NFS client
  export specification
Instructions for Use:
  1. Download the attached .ZIP file below to your computer.
    *Remember the location of the saved file on your computer.
  3. Log in to UCS Director as a user that has
    "system-admin" privileges.
  4. Navigate to "Policies-->Orchestration" and click on
    "Import".
  5. Click "Browse" and navigate to the location on your
    computer where the .WFD file resides. Choose the .WFD file and click "Open".
  6. Click "Upload" and then "OK" once the file
    upload is completed. Then click "Next".
  7. Click the "Select" button next to "Import
    Workflows". Click the "Check All" button to check all checkboxes
    and then the "Select" button.
  8. Click "Submit".
  9. A new folder should appear in
    "Policies-->Orchestration" that contains the imported workflow.
    You will now need to update the included tasks with information about the
    specific environment.
