Orf Gelbrich
Task NameRetrieve VM IP
Description
  1. Retrieve VM IP
Prerequisites
  1. Tested on 5.2.0.0.A
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Thanks go out to Russ Whitear.
This is an example on how to retrieve the IP address for a VM:
Workflow:
Workflow execution select VM:
Workflow Execution Log Tab:
