Orf Gelbrich
Task Name
Example on REST API integration
Description
Prerequisites
Minimum UCSD version: 5.4.0.2
CategoryCustom task
Components
User Inputs
User Output
  8. Click "Submit".
Thank you Ryan Criss.
The Custom Task:
The Document:
Screen Shot 2016-02-25 at 11.35.57 AM.pngScreen Shot 2016-02-25 at 11.36.05 AM.png
Screen Shot 2016-02-25 at 11.36.12 AM.pngScreen Shot 2016-02-25 at 11.36.18 AM.png
The Code Example:
importPackage(com.cloupia.lib.util);
importPackage(org.apache.commons.httpclient);
importPackage(org.apache.commons.httpclient.cookie);
importPackage(org.apache.commons.httpclient.methods);
importPackage(org.apache.commons.httpclient.auth);
importPackage(org.apache.commons.httpclient.protocol);
// Author: Ryan Criss (rcriss@cisco.com)
// Workflow Task Name: Open Library REST Example
// Version: 1.0
// Description:
// This custom task retrieves book details from the Open Library database when given an ISBN-10
// Inputs:
// ISBN10: The ISBN 10 of the book
// Outputs:
// None
//                                 ### FUNCTIONS ###
//    Created By: Ryan Criss (rcriss@cisco.com)
// Function Name: openlibraryRetrieveBookNameByIsbn()
//       Version: 1.0
//   Description: Retrieves the book name given an ISBN10
//       Inputs:
// isbn10: The ISBN-10 of the book
//       Outputs:
// bookName: The book name
function openlibraryRetrieveBookNameByIsbn10(isbn10) {
  logger.addInfo("function openlibraryRetrieveBookNameByIsbn10");
  // Setup HTTPS Connection
  var httpClient = new HttpClient();
  httpClient.getHostConfiguration().setHost("openlibrary.org", 443, "https");
  httpClient.getHostConfiguration().setProxy("proxy.test.com", 80);
  httpMethod = new GetMethod("/query.json?type=/type/edition&isbn_10="+isbn10+"&*=&limit=1");
  // If basic authorization is required, you could add an authorization header
  // httpMethod.addRequestHeader("Authorization", "Basic Y9laY346UjL7GmFAdSE=");
  // If an authorization cookie is required, you can add a cookie
  // httpMethod.addRequestHeader("Cookie", "cookiestring");
  // Execute HTTPS and Return Results
  httpClient.executeMethod(httpMethod);
  statusCode = httpMethod.getStatusCode();
  response = httpMethod.getResponseBodyAsString();
  httpMethod.releaseConnection();
  // Check Response Code and Parse Results
  if (statusCode == 200){
  logger.addInfo("Response received: "+response);
  var jsonResponse = JSON.getJsonElement(response, null);
  // Make sure the query found a matching book.
  if (jsonResponse.size() == 0){
  logger.addError("Request Failed. The book search did not find any books with that ISBN-10.");
  ctxt.setFailed("Open Library book search failed.");
  ctxt.exit();
  // Retrieve the Title from the JSON object
  var bookName = jsonResponse.get(0).get("title").getAsString();
  logger.addInfo("Book Name: " + bookName);
  return bookName;
  } else {
  // HTTP Request Failed
  logger.addError("Request Failed. HTTP response code: "+statusCode);
  logger.addError("Response = " + response);
  ctxt.setFailed("Open Library request failed.");
  ctxt.exit();
} //function openlibraryRetrieveBookNameByIsbn10
// Function Name: openlibraryRetrieveBookDetailsByIsbn()
//       Version: 1.0
//   Description: Retrieves the book details given an ISBN10
//       Inputs:
//       Outputs:
// bookDetails: The book details as an object with individual details stored as properties
function openlibraryRetrieveBookDetailsByIsbn10(isbn10) {
  logger.addInfo("function openlibraryRetrieveBookDetailsByIsbn10");
  // httpMethod.addRequestHeader("Authorization", "Basic Y936glaY346UjhL7Gm3FAdSE=");
  ctxt.exit();
  // Retrieve the Details from the JSON object
  var bookDetails = {};
  // Book Title
  bookDetails.title = jsonResponse.get(0).get("title").getAsString();
  logger.addInfo("Book Title: " + bookDetails.title);
  // Book Description
  bookDetails.description = jsonResponse.get(0).get("description").getAsString();
  logger.addInfo("Book Description: " + bookDetails.description);
  // Book Genres - Might be multiple genres, so will create an array
  bookDetails.genres = [];
  for (var i = 0; i < jsonResponse.get(0).get("genres").size(); i++){
  bookDetails.genres.push(jsonResponse.get(0).get("genres").get(i).getAsString());
  logger.addInfo("Book Genres: " + bookDetails.genres.toString());
  // Book Publishers - Might be multiple publishers, so will create an array
  bookDetails.publishers = [];
  for (var i = 0; i < jsonResponse.get(0).get("publishers").size(); i++){
  bookDetails.publishers.push(jsonResponse.get(0).get("publishers").get(i).getAsString());
  logger.addInfo("Book Publishers: " + bookDetails.publishers.toString());
  // Author Keys - Might be multiple author keys, so will create an array
  bookDetails.authorKeys = [];
  for (var i = 0; i < jsonResponse.get(0).get("authors").size(); i++){
  bookDetails.authorKeys.push(jsonResponse.get(0).get("authors").get(i).get("key").getAsString());
  logger.addInfo("Author Keys: " + bookDetails.authorKeys.toString());
  // Return the bookDetails Object
  return bookDetails;
  } else {
  ctxt.exit();
} //function openlibraryRetrieveBookDetailsByIsbn10
// Function Name: openlibraryRetrieveAuthorNameByAuthorKey()
//       Version: 1.0
//   Description: Retrieves the author name given an author key
//       Inputs:
// authorKey: The author key
//       Outputs:
// authorName: The author name
function openlibraryRetrieveAuthorNameByAuthorKey(authorKey) {
  logger.addInfo("function openlibraryRetrieveAuthorNameByAuthorKey");
  httpMethod = new GetMethod(authorKey+".json");
  // Retrieve the author name from the JSON object
  var authorName = jsonResponse.get("name").getAsString();
  logger.addInfo("Author Name: " + authorName);
  return authorName;
  } else {
  ctxt.exit();
} //function openlibraryRetrieveAuthorNameByAuthorKey
//                                 ### MAIN PROGRAM ###
// Workflow Inputs Mappings
var isbn10 = input.isbn10;
// Retrieve Book Name By ISBN-10 (Example to show retrieving and returning a single item)
var bookName = openlibraryRetrieveBookNameByIsbn10(isbn10);
// Retrieve Book Details By ISBN-10 (Retrieves the bookDetails object with the details stored in properties)
var bookDetails = openlibraryRetrieveBookDetailsByIsbn10(isbn10);
// Retrieve Author Names by Author Keys (Because the above method only returned the author key - not the name)
var authorNames = [];
for (var i = 0; i < bookDetails.authorKeys.length; i++){
  authorNames.push(openlibraryRetrieveAuthorNameByAuthorKey(bookDetails.authorKeys[i]));
// Pass Outputs
output.bookName = bookName;
output.bookTitle = bookDetails.title;
output.bookDescription = bookDetails.description;
output.bookGenres = bookDetails.genres.toString();
output.bookPublishers = bookDetails.publishers.toString();
output.bookAuthors = authorNames.toString();
thom.schumacher
I added the following function:
function authenticateUser(user,password)
    var token = user +":" + password;
    var hash = Base64.encode(token);
    return "Basic " + hash;
So that  I can base 64 encode the input..  Director tells me that both these functions don't exist
boa and
Base64.encode
am I missing something
Orf Gelbrich
try this
importPackage(java.util);
importPackage(java.lang);
importPackage(java.io);
var x=input.mask;
logger.addInfo("My Netmask = "+x);
var base64encodedString = Base64.getEncoder().encodeToString(x.getBytes("utf-8"));
logger.addInfo("Base64 Encoded String: " + base64encodedString);
thom.schumacher
That worked.
    var hash = Base64.getEncoder().encodeToString(token.getBytes("utf-8"));
    return hash
Orf Gelbrich
Good..
