Sabina Al Farah
Task NameCert integration Example
Description
  1. Cert integration Example
Prerequisites
  1. Tested on 5.3.x
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
In case we have a server that presents invalid SSL certificate, and we need to invoke the server from UCSD, use the CloupiaScript attached to this workflow. This scenario occurs very often in DEV/TEST environments. The script will trust all certificates presented by any server irrespective of selfsigned/authoritysigned/expired/server-validity.
(However, any PRODUCTION server should present valid certificates and the following code should not be used in Production)
Custom Workflow Task: Get_UCSM_https_ServiceProfileBootOrder
Workflow using this task : Get UCSM Boot Order (Custom Task HTTPS)
