hapresto
Prerequisites
  1. Built on UCSD 5.3
  8. Click "Submit".
The most common "scripting" I need to do with UCSD is around input formatting, particularly taking a user input string, and cleaning it up to match a standard.  I usually just pull in a cloupia script task to the workflow, and build the JavaScript to do the task.  Not difficult, but certainly repetitive.  I recently built a custom task that handles most of what I need to do for these examples.
This task does the following:
1) Take the Input String and Remove Spaces
2) Optionally trim the length to a certain character length
3) Add optional prefix to the string
4) Add optional suffix to the string (I often use -u${SR_ID} to ensure uniqueness)
The attached file includes a sample workflow and the custom task.
