Orf Gelbrich
Task NameUCSD chop variables by a certain Character
Description
Prerequisites
  1. Tested on 5.3.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Here are 4 examples on how to chop/split variables and typecast them:
The Split:
token = 'X-SDS-AUTH-TOKEN: BAAcS1kyYUNLTkhrK1BhQ1BVaFJLdTJGUzdPdjlBPQMAVAQADTE0NDY1ODU5MjM0MDYCAAEABQA9dXJuOnN0b3JhZ2VvczpUb2tlbjphYjY1NTMwYi1iZmRmLTRkOGMtODBiNy05ZjcxNjExYjM3MjM6dmRjMQIAAtAP'
var tokencookie = token.replaceAll(': ', '=');
PowerShell Example:
Massage example to go from
      Input = A1B2C3
     output = A1:B2:C3 ..
The custom task code...
importClass(org.apache.log4j.Logger);
importPackage(com.cloupia.model.serviceContainer.fenced);
importPackage(com.cloupia.service.cIM.inframgr.workflowmgr);
importPackage(com.cloupia.feature.customactions);
importPackage(com.cloupia.service.cIM.inframgr.reservation);
importPackage(java.lang);
importPackage(java.util);
importPackage(com.cloupia.service.cIM.inframgr);
importPackage(com.cloupia.model.cIM);
importPackage(com.cloupia.model.serviceContainer);
importClass(com.cloupia.service.cIM.inframgr.GroupManagerImpl);
importClass(org.apache.commons.lang3.builder.ReflectionToStringBuilder);
importPackage(java.io);
importPackage(java.net);
importPackage(java.security);
importPackage(javax.xml.xpath);
importPackage(org.xml.sax);
importPackage(com.cloupia.lib.connector.account);
importPackage(com.cloupia.lib.connector.account.credential);
importPackage(com.cloupia.lib.util);
importClass(com.cloupia.lib.util.JSON);
importPackage(com.cloupia.lib.util.easytrust);
importPackage(com.cloupia.lib.cIaaS.vcd.api);
importPackage(org.apache.http);
importPackage(org.apache.http.client.methods);
importPackage(org.apache.http.client.params);
importPackage(org.apache.http.conn.scheme);
importPackage(org.apache.http.entity);
importPackage(org.apache.http.impl.client);
importPackage(org.apache.http.util);
importClass(org.apache.http.conn.ssl.SSLSocketFactory);
importClass(javax.net.ssl.SSLContext);
importClass(javax.net.ssl.TrustManager);
importClass(javax.net.ssl.X509TrustManager);
var in1 = input.a;
var str1 = in1.substring(0,2);
var str2 = in1.substring(2,4);
var str3 = in1.substring(4,6);
var str4 = in1.substring(6,8);
var str5 = in1.substring(8,10);
var str6 = in1.substring(10,12);
var str7 = in1.substring(12,14);
var str8 = in1.substring(14,16);
logger.addInfo("str1 : " + str1);
logger.addInfo("str2 : " + str2);
logger.addInfo("str3 : " + str3);
logger.addInfo("str4 : " + str4);
logger.addInfo("str5 : " + str5);
logger.addInfo("str6 : " + str6);
logger.addInfo("str7 : " + str7);
logger.addInfo("str8 : " + str8);
var out1 = str1 + ":" + str2 + ":" + str3 + ":" + str4 + ":" + str5 + ":" + str6 + ":" + str7 + ":" + str8;
logger.addInfo("out1 : " + out1);
output.b = out1;
