Orf Gelbrich
Task Name
The regular if statemant can not test for a booean.  Here is an example on how to test if a user entered something and if the varaible is empty.
Description
Prerequisites
Tested on UCSD 5.4.0.3
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Many thanks for the inspiration go to Andreas Wentland.
The workflow:
     2 custom task
          1 to pint a line of the actual content of the variable to the log file (to see the variable is empty)
          2 to do the if check to see if the variable is true or false
The input test:
     Variable is not mandatory in order to produce an empty variable
The workflow goes down the failed path:
Test #2 with something being entered:
Workflow goes down the non failed path:
The logger displays the user input:
Custom task the conditional testing:
if (input.TestForEmptyVar) {
  logger.addInfo("...True...");
  output.out = "1";
} else {
  logger.addInfo("...False...");
  output.out = "0";
  ctxt.setFailed("Variable is empty" + input.TestForEmptyVar);
  ctxt.exit();
Custom task the logger:
     logger.addInfo(">"+input.LogFileEntry+"<");
Workflow export contains these tasks:
