Orf Gelbrich
Task NameCreate Tenant VDC and its policies
Description
  1. Change the user of a running workflow
Prerequisites
  1. Tested on 5.3.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  1. userid to change to
Output
  8. Click "Submit".
A big thank you goes out to Lucas Hoge for this contribution:
This also uses datastore clusters!
The workflow via custom task:
The User input:
Screen Shot 2015-07-24 at 10.00.59 AM.pngScreen Shot 2015-07-24 at 10.01.06 AM.png
The Code all done in functions and no API calls:
importPackage(java.lang);
importPackage(java.util);
importPackage(com.cloupia.model.cIM);
importPackage(com.cloupia.service.cIM.inframgr);
importPackage(com.cloupia.service.cIM.inframgr.profiles);
importPackage(com.cloupia.lib.cIaaS.vmware);
var vDCID;
var compPolicyId;
var storPolicyId;
var netPolicyId;
var sysPolicyId;
function createTenantPolicy(){
var vdcProfile = input.vDCProfile;
var vdcName = input.VDCName;
var sysPolicyName = input.SysPolicyName;
var compPolicyName = input.CompPolicyName;
var storPolicyName = input.StorPolicyName;
var netPolicyName = input.NetPolicyName;
var groupId = input.GroupId;
var cluster = input.Cluster;
var resourcePool = input.ResourcePool;
//var datastore = input.Datastore;
var datastoreClusterIdentity = input.DatastoreCluster;
var datastoreClusterArray =[];
datastoreClusterArray = datastoreClusterIdentity.split("@");
var datastoreCluster=[];
datastoreCluster[0] = datastoreClusterArray[2];
var scopeType=input.datastoreClusterScope;
logger.addInfo("scopeType Var Defined, Value: " +scopeType);
var dvPortGroup = input.PortGroup;
var ipPool = input.StaticIPPool;
var domainName = input.DomainName;
var userName = input.UserName;
var password = input.Password;
var nicAlias = input.NICAlias;
  logger.addInfo("dvPortGroup: "+dvPortGroup);
  logger.addInfo("ipPool: "+ipPool);
  logger.addInfo("datastoreCluster: "+datastoreCluster);
  logger.addInfo("cluster: "+cluster);
var oldVDC = VDCUtil.getVDC(vdcProfile);
var vdcExists = VDCUtil.getVDCByName(vdcName);
try{
  if(oldVDC != null){
  if(vdcExists == null){
  var compPolicy =  createCompPolicy(oldVDC, compPolicyName, cluster, resourcePool);
  var netPolicy = createNetPolicy(oldVDC, netPolicyName, nicAlias, dvPortGroup, ipPool);
  var storPolicy =  createStorPolicy(oldVDC, storPolicyName, datastoreCluster, scopeType);
  var sysPolicy =  createSysPolicy(oldVDC, sysPolicyName, domainName, userName, password);
  }else{
  throw new Exception("VDC with name "+vdcName+" already exist");
  }else{
  throw new Exception("vDC Profile does not exist");
    var vdc = new VDC();
  vdc.setVdcName(vdcName);
  vdc.setVdcDescription("Desc");
  vdc.setGroupId(groupId);
  vdc.setCloudName(oldVDC.getCloudName());
  if (oldVDC.getApproverList() != null) {
        vdc.setApproverList(oldVDC.getApproverList());
    vdc.setPrimaryApprovers(oldVDC.getPrimaryApprovers());
    vdc.setSecondaryApprovers(oldVDC.getSecondaryApprovers());
  vdc.setApprovalReqUsers(oldVDC.isApprovalReqUsers());
  vdc.setResendMailCount(oldVDC.getResendMailCount());
  vdc.setReminderInterval(oldVDC.getReminderInterval());
  vdc.setVdcSupportEmail(oldVDC.getVdcSupportEmail());
  vdc.setVdcCustomerNoticationEmail(oldVDC.getVdcCustomerNoticationEmail());
  vdc.setComputingPolicy(compPolicy.getPolicyName());
  vdc.setStoragePolicy(storPolicy.getPolicyName());
  vdc.setNetworkPolicy(netPolicy.getPolicyName());
  vdc.setPrimaryDeployPolicy(sysPolicy.getPolicyName());
  vdc.setSecondaryDeployPolicy(null);
  vdc.setIsoMappingPolicy(oldVDC.getIsoMappingPolicy());
  vdc.setCostModel(oldVDC.getCostModel());
  vdc.setDisableCostModelDisplay(oldVDC.isDisableCostModelDisplay());
  vdc.setUserActionsPolicy(oldVDC.getUserActionsPolicy());
  vdc.setEnableStorageEfficiency(oldVDC.isEnableStorageEfficiency());
  vdc.setDeletable(true);
  vdc.setInactivityPeriodForDeletion(-1);
  vdc.setSelfServiceEndUserPolicyId(oldVDC.getSelfServiceEndUserPolicyId());
            var appCatList = AppCategoryUtil.getAllCategories();
            var vdcCatList = new ArrayList();
        for (var i=0; i<appCatList.size(); i++)
            var vdcCat = new VDCAppCategory();
            vdcCat.setVdcCatId(appCatList.get(i).getCategoryId());
            vdcCatList.add(vdcCat);
        vdc.setAppCategoryList(vdcCatList);
  var isCreated = VDCUtil.addVDC(vdc);
  logger.addInfo("VDC created: "+isCreated);
  vDCID = vdc.getVdcId();
    }catch(e){
        logger.addError("Error occured"+e);
        ctxt.setFailed("error occured while creating VDC");
        ctxt.exit();
function createCompPolicy(oldVDC, compPolicyName, cluster, resourcePool)
  var policy;
    policy = InfraPersistenceUtil.getPrivateCloudComputingPolicy(compPolicyName);
    if (policy != null)
               ctxt.setFailed("Compute policy with name "+compPolicyName+" already exists");
               ctxt.exit();
    var profile = InfraPersistenceUtil.getPrivateCloudComputingPolicy(oldVDC.getComputingPolicy());
    policy = new PrivateCloudComputingPolicy();
       policy.setPolicyName(compPolicyName);
       policy.setPolicyDescription(compPolicyName+" created by SR "+ctxt.getSrId());
       policy.setCloudName(oldVDC.getCloudName());
    var scopeList = new ArrayList();
    var scope = new DRAPScope();
    scope.setEnabled(true);
    scope.setInclude(true);
    scope.setScopeContextName("Clusters");
    scope.setScopeContextValue(cluster);
    scopeList.add(scope);
  policy.setScopeList(scopeList);
  var rps = resourcePool.split(",");
    var resourcePoolName = new StringBuffer();
    for(var i = 0; i<rps.length; i++){
  var detailedIdentity = new ResourcePoolDetailedIdentity(rps[i]);
     resourcePoolName = resourcePoolName.append(detailedIdentity.getRpIdentity());
  resourcePoolName = resourcePoolName.append(",");
    resourcePoolName = resourcePoolName.substring(0,resourcePoolName.lastIndexOf(","));
    policy.setResourcePoolName(resourcePoolName);
  policy.setEsxType(profile.getEsxType());
  policy.setEsxVersion(profile.getEsxVersion());
  policy.setRules(profile.getRules());
  policy.setOverrideTemplateProperties(profile.isOverrideTemplateProperties());
  if(profile.isOverrideTemplateProperties()){
  policy.setNumVCPUs(profile.getNumVCPUs());
  policy.setCpuReservationMhz(profile.getCpuReservationMhz());
  policy.setCpuLimitMhz(profile.getCpuLimitMhz());
  policy.setCpuShares(profile.getCpuShares());
  policy.setMemoryMB(profile.getMemoryMB());
  policy.setReserveAllGuestMem(profile.isReserveAllGuestMem());
  if(!profile.isReserveAllGuestMem()){
  policy.setMemReservationMB(profile.getMemReservationMB());
  policy.setMemLimitMB(profile.getMemLimitMB());
  policy.setMemShares(profile.getMemShares());
  policy.setAllowResizing(profile.isAllowResizing());
  if(profile.isAllowResizing()){
  policy.setResizeAllowedCPUs(profile.getResizeAllowedCPUs());
  policy.setResizeAllowedMemoryMB(profile.getResizeAllowedMemoryMB());
  if(profile.getDeployToFolder() != null)
  policy.setDeployToFolder(profile.getDeployToFolder());
  InfraPersistenceUtil.persistPrivateCloudComputingPolicy(policy);
  compPolicyId = policy.getPolicyId();
  logger.addInfo("Compute Policy Created: " +compPolicyName)
       return policy;
function createNetPolicy(oldVDC, netPolicyName, nicAlias, dvPortGroup, ipPool)
       var policy;
       policy = InfraPersistenceUtil.getPrivateCloudNetworkPolicy(netPolicyName);
    if (policy !== null)
               ctxt.setFailed("Network policy with name "+netPolicyName+" already exists");
               ctxt.exit();
    var profilePolicy = InfraPersistenceUtil.getPrivateCloudNetworkPolicy(oldVDC.getNetworkPolicy());
    var policy = new PrivateCloudNetworkPolicy();
       policy.setPolicyName(netPolicyName);
       policy.setPolicyDescription(netPolicyName+" created by SR "+ctxt.getSrId());
    policy.setAllowOptionalNICs(profilePolicy.isAllowOptionalNICs());
    var nicList = profilePolicy.getVmNetworks().getList();
    /*for(var i = 0; i<nicList.size(); i++){
  if(nicList.get(i).getNicAlias().equalsIgnoreCase(nicAlias)){
  ctxt.setFailed("NIC Alias name should be unique");
  ctxt.exit();
    var profileNIC = nicList.get(0);
  var nic = new PrivateCloudNetworkPolicyNIC();
  nic.setNicAlias(nicAlias);
  nic.setMandatory(true);
  nic.setAllowToChangePortGroups(profileNIC.isAllowToChangePortGroups());
  nic.setCopyFromTemplate(profileNIC.isCopyFromTemplate());
  if(!profileNIC.isCopyFromTemplate())
  nic.setAdapterType(profileNIC.getAdapterType());
    var nicPortGroup = new PrivateCloudNetworkPolicyNICPortGroup();
    nicPortGroup.setPortGroup(dvPortGroup);
    nicPortGroup.setIpAddressType(1);//DHCP:0,Static:1
    nicPortGroup.setIpAddressSource(0);//IP Pool Policy:0, Inline Pool Policy:1
    var staticIPs = ipPool.split(",");
    nicPortGroup.setStaticIPPool(staticIPs);
    nic.getVmPortGroups().getList().add(nicPortGroup);
     var newNICList = new ArrayList();
  //newNICList.addAll(nicList);
  newNICList.add(nic);
    var def=new PrivateCloudNetworkPolicyNICDef();
       def.setNics(newNICList);
       var vmNicsDefInfoStr=VMWareUtils.getPrivateCloudNetworkPolicyNICDefStr(def);
       policy.setVmNicsDefInfoStr(vmNicsDefInfoStr);
       InfraPersistenceUtil.persistPrivateCloudNetworkPolicy(policy);
  netPolicyId = policy.getPolicyId();
  logger.addInfo("Network Policy Created: " +netPolicyName);
       return policy;
function createStorPolicy(oldVDC, storPolicyName, datastoreCluster, scopeType)
  var policy;
       var policy = InfraPersistenceUtil.getPrivateCloudStoragePolicy(storPolicyName);
    if (policy != null)
               ctxt.setFailed("Storage policy with name "+storPolicyName+" already exists");
               ctxt.exit();
    var profile = InfraPersistenceUtil.getPrivateCloudStoragePolicy(oldVDC.getStoragePolicy());
    policy = new PrivateCloudStoragePolicy();
    policy.setPolicyName(storPolicyName);
       policy.setPolicyDescription(storPolicyName+" created by SR "+ctxt.getSrId());
  var result = new DRAPScope();
        result.setEnabled(true);
        result.setInclude(true);
        result.setScopeContextName(DRAPFormUtil.SCOPE_CONTEXT_NAME_DATASTORE_CLUSTERS);
        result.setScopeContextValue(datastoreCluster);
        var list = new ArrayList();
        list.add(result);
  logger.addInfo("ScopeType Output: " +scopeType);
  policy.setScopeType(scopeType);
  policy.setDatastoreCluster(datastoreCluster);
  policy.setScopeList(list);
  policy.setLocalStorage(profile.isLocalStorage());
  policy.setNfsStorage(profile.isNfsStorage());
  policy.setISCSIStorage(profile.isISCSIStorage());
  policy.setUseLinkedClone(profile.isUseLinkedClone());
  policy.setDoThinProvisioning(profile.isDoThinProvisioning());
  if(profile.isManualDiskSize()){
  policy.setManualDiskSize(profile.isManualDiskSize());
  policy.setCustomDiskSizeGB(profile.getCustomDiskSizeGB());
  policy.setResizeAllowedDiskGB(profile.getResizeAllowedDiskGB());
  policy.setAllowDataStoreSelect(profile.isAllowDataStoreSelect());
       InfraPersistenceUtil.persistPrivateCloudStoragePolicy(policy);
  storPolicyId = policy.getPolicyId();
  logger.addInfo("Storage Policy Created: " +storPolicyName);
       return policy;
function createSysPolicy(oldVDC, sysPolicyName, domainName, userName, password)
  var policy;
  policy = InfraPersistenceUtil.getPrivateCloudSystemProfile(sysPolicyName);
       if (policy != null)
               ctxt.setFailed("System policy with name "+sysPolicyName+" already exists");
               ctxt.exit();
  var profile = InfraPersistenceUtil.getPrivateCloudSystemProfile(oldVDC.getPrimaryDeployPolicy());
    policy = new PrivateCloudSystemProfile();
    policy.setPolicyName(sysPolicyName);
       policy.setPolicyDescription(sysPolicyName+" created by SR "+ctxt.getSrId());
    policy.setVmNameTemplate(profile.getVmNameTemplate());
    policy.setVmNameValidationPolicy(profile.getVmNameValidationPolicy());
    policy.setAllowEndUserSuffix(profile.isAllowEndUserSuffix());
    policy.setPowerOn(profile.isPowerOn());
    policy.setHostNameTemplate(profile.getHostNameTemplate());
    policy.setHostNameValidationPolicy(profile.getHostNameValidationPolicy());
    policy.setDnsDomain(profile.getDnsDomain());
    policy.setLinuxTimezone(profile.getLinuxTimezone());
    if(profile.getDnsSuffixList() != null)
  policy.setDnsSuffixList(profile.getDnsSuffixList());
  if(profile.getDnsServerList() != null)
  policy.setDnsServerList(profile.getDnsServerList());
    policy.setImageType(profile.getImageType());
    if(profile.getProductId() != null)
  policy.setProductId(profile.getProductId());
    policy.setFullName(profile.getFullName());
    policy.setOrgName(profile.getOrgName());
    policy.setLicenseMode(profile.getLicenseMode());
    if(profile.getLicenseUsers() != null)
  policy.setLicenseUsers(profile.getLicenseUsers());
    if(profile.getWinList() != null)
  policy.setWinList(profile.getWinList());
    policy.setSIDUnique(profile.isSIDUnique());
    policy.setAutoLogon(profile.isAutoLogon());
    if(profile.getAutoLogonCount() != null)
  policy.setAutoLogonCount(profile.getAutoLogonCount());
    policy.setPassword(profile.getPassword());
    policy.setWindowsTimezone(profile.getWindowsTimezone());
    policy.setDomain(domainName);
    policy.setDomainAdmin(userName);
    policy.setDomainPassword(password);
    if(profile.isDefineAnnotation()){
  policy.setDefineAnnotation(profile.isDefineAnnotation());
  if(profile.getNotes() != null)
  policy.setNotes(profile.getNotes());
  policy.setCustomAttributesList(profile.getCustomAttributesList());
       InfraPersistenceUtil.persistPrivateCloudSystemProfile(policy);
  sysPolicyId = policy.getPolicyId();
  logger.addInfo("Storage Policy Created: " +sysPolicyName);
       return policy;
function registerUndoTask(vDCID, compPolicyId, netPolicyId, storPolicyId, sysPolicyId) {
    // register undo task
    var undoHandler = "custom_rollback_tenant_vdc";
    var undoContext = ctxt.createInnerTaskContext(undoHandler);
    var undoConfig = undoContext.getConfigObject();
  undoConfig.vDCId = vDCID;
  undoConfig.compPolicyId = compPolicyId;
  undoConfig.netPolicyId = netPolicyId;
  undoConfig.storPolicyId = storPolicyId;
  undoConfig.sysPolicyId = sysPolicyId;
    ctxt.getChangeTracker().undoableResourceModified("Rollback vdc ",
                ""+vDCID,"rollback ",
                "Rollback "+vDCID,undoHandler,undoConfig);
createTenantPolicy();
//registerUndoTask(vDCID, compPolicyId, netPolicyId, storPolicyId, sysPolicyId);
phirobin
Community Member
This is very helpful - but what if you want to create the Tenant and then the vDC?  The above assumes that there is a vDC profile to select - I am looking to create a Tenant and then a set of vDCs - there is no function I can find to create the vDC service profile specifying the Tenant/Group and then selecting the cloud.
I have 3x vCenters - one for Linux (but not Oracle) and Windows, 1x for Oracle Single and 1x for Oracle RAC - Is there a function that can be written to create the vDC Service Profile too (or supply the values for it)?
Phil
31-05-2017 - Update
I have resolved this by creating 3x Service profiles (one for each vCenter for the Default Group) and the built in task to Create a vDC has the GroupID as an input - so I then ran this 3 times in my workflow using the vDC profile as a Base and supplying the GroupId input.  This goes and creates a Network, Storage, Compute and Service Delivery Policy based on the vDC Profile and associates them within each of the new vDCs. I end up with 3x of each of the Network, Storage, Compute and Service Delivery (one for each vDC) per Tenant/Group but I am happy with that
Orf Gelbrich
Cool – glad it is working.
Orf Gelbrich
Check out UCS Director Workflow INDEX<https://communities.cisco.com/docs/DOC-56419> on Cisco Communities Site (Twitter @UCSDGURU)
