Orf Gelbrich
Task Name
example of merging data from a loop into one varaible
Description
Prerequisites
vCenter
CategoryWorkflow
ComponentsUCSD 6.6
User Inputs
Output
  5. Click "Browse" and navigate to the location on your computer where the .WFDX file resides. Choose the .WFDX file and click "Open".
  8. Click "Submit".
A massive Thank You goes out to:
     Andrews Bob for contributing this.
This is an example of merging output from a task that is in a loop into one variable.
The workflow:
E-mail output:
Workflow run:
Workflow input:
Log output:
Custom task input:
Output of custom task fed into input:
E-mail:
Custom task code:
function buildName(userInput, inputLength, prefix, suffix)
// Trim Length
if (inputLength > 0 && userInput.length() > inputLength)
userInput = userInput.slice(0,inputLength);
// Add prefix
if (prefix)
userInput = prefix + "\n" + userInput;
// Add suffix
if (suffix)
userInput = userInput + "\n" + suffix;
userInput = userInput + "\n";
return userInput;
//   --  Begin  --
var userInput = input.userInput;
var inputLength = input.inputLength;
var prefix = input.prefix;
var suffix = input.suffix;
logger.addInfo("userInput: " + userInput);
logger.addInfo("inputLength: " + inputLength);
logger.addInfo("prefix: " + prefix);
logger.addInfo("suffix: " + suffix);
if ( prefix.contains("${")) {
    logger.addInfo("setting prefix to null since ${var} is not resolved")
    prefix = "";
var mergedData = buildName(userInput, inputLength, prefix, suffix);
logger.addInfo("Merged Output: " + mergedData);
ctxt.setTaskStatusMessage("Merged Output: " + mergedData);
output.mergedOutput = mergedData;
