Orf Gelbrich
This is to show case a few important workflow every UCSD administrator should have in their environment:
Backing up your workflows:
         UCSD - Export Workflows with a scheduled workflow
Backing up your UCSD DB:
     UCSD internal DB backup example (Single Node)
Schedule this alerting workflow on UCSD disk and UCSD DB
     UCSD Disk and DB size Alerter Workflow
Know what the status is of your snapshots in your vCenter(s):
     Snapshot Report with Sum/Total (Multi Cloud)
     Potential in conjunction of scheduling the deletion of snapshots older then some time period
     UCSD Snap Shot Report / Delete Snap Shot Older Then
