Orf Gelbrich
This is an example on how to run a custom workflow task (some modifications are necessary) from the command line for rapid custom task testing.
Big thank you goes to
          Russ Whitear and James Spurin
Tested on UCSD 6.0 (other versions may require jar file updates)
1) SSH to the UCSD instance (root)
2) It is important to be in the correct directory (cd /opt/infra/inframgr)
3) Test file:
[root@localhost inframgr]# cat /tmp/a
// Load the Nashorn Engine, remove when uploading to UCSD
load("nashorn:mozilla_compat.js");
importPackage(java.io);
importPackage(java.util);
importPackage(com.cloupia.model.cEvent.notify);
importPackage(com.cloupia.model.cIM);
importPackage(com.cloupia.lib.util.mail);
importPackage(com.cloupia.fw.objstore);
importPackage(java.lang);
importPackage(com.cloupia.service.cIM.inframgr);
// Create the context usually created by UCSD, remove when passing to UCSD, disable
// entries that use input.property
importPackage(com.cloupia.service.cIM.inframgr.customactions)
ctx = new CustomActionTriggerContext()
var target = "www.cisco.com"
var uri = "/getmystuff/lala"
//var target = input.target;
//var uri = input.uri;
logger = new CustomActionLogger(ctx)
var a=123;
logger.addInfo("****************"+a+"*********");
ar = new BufferedWriter(new FileWriter("/tmp/b.txt",true));
ar.write("Varaibale " + a +"\r\n");
ar.flush();
ar.close();
4) Execution (yes rather long, but notice /tmp/a is at the end of this long line):
/opt/bin/jre/bin/jjs -cp .:inframgr.jar:google-gson.jar:ruby-gems-1.1.jar:java-xmlbuilder-0.6.jar:vmguest.jar:vim25-wsdl.jar:vijava60compat.jar:vijava55b20130927.jar:ssoclient-wsdl.jar:srm.jar:pbm-wsdl.jar:jaxen-1.1-beta-6.jar:dom4j-1.6.1.jar:velocity-1.6.2.jar:velocity-1.6.2-dep.jar:jclouds-vcloud-1.0-beta-7.jar:jclouds-terremark-1.0-beta-7.jar:jclouds-scriptbuilder-1.0-SNAPSHOT.jar:jclouds-log4j-1.0-beta-7.jar:jclouds-jsch-1.0-beta-7.jar:jclouds-core-1.0-beta-7-jar-with-dependencies.jar:jclouds-compute-1.0-beta-7.jar:vcloud-java-sdk-1.5.0.jar:rest-api-schemas-1.5.0.jar:syslog4j-0.9.43-bin.jar:maverick-all.jar:pd_ipc_server.jar:nesla-1.1.jar:libthrift-0.9.1.jar:jruby-complete-1.7.9.jar:javax.ws.rs-api-2.0.1.jar:javax.inject-2.3.0-b10.jar:javax.annotation-api-1.2.jar:gch_client.jar:aopalliance-repackaged-2.3.0-b10.jar:xalan-2.7.0.jar:trustpool.jar:quartz-2.1.7.jar:gch_server.jar:bcprov-jdk15on-151.jar:bcpkix-jdk15on-151.jar:slf4j-log4j12-1.7.6.jar:slf4j-api-1.7.6.jar:ant-1.8.4.jar:ss_css2.jar:pd4ml.jar:ojdbc14.jar:classes12.jar:manageontap-5.3.1.jar:mysql-connector-java-5.1.24-bin.jar:mongo-java-driver-2.11.3.jar:log4j-1.2.15.jar:jxl.jar:junit-4.9b2.jar:jsoup-1.7.3.jar:json-lib.jar:jackson-databind-2.8.0.jar:jackson-core-2.8.0.jar:jackson-annotations-2.8.0.jar:jackson-all-1.9.5.jar:jsch-0.1.45.jar:jfreechart-1.0.13.jar:jcommon-1.0.16.jar:jdepend-2.9.jar:smtp.jar:mailapi.jar:javassist.jar:jade.jar:jssc.jar:guava-15.0.jar:google-gson.jar:flexlm.jar:Vendor_info.jar:EccpressoAll.jar:ehcache-core-2.6.6.jar:aws-java-sdk-1.4.3.jar:jdo2-api-2.3-eb.jar:datanucleus-rdbms-4.1.0-release.jar:datanucleus-core-4.1.0-release.jar:datanucleus-cache-4.0.4.jar:datanucleus-api-jdo-4.1.0-release.jar:asm-5.0.4.jar:ucsd-rest-api-sdk-v2.jar:cuic-client.jar:bonecp-0.8.0.RELEASE.jar:servlet-api.jar:commons-validator-1.4.0.jar:commons-pool-1.6.jar:commons-pool-1.3.jar:commons-net-3.1.jar:commons-logging-1.1.jar:commons-lang3-3.1.jar:commons-lang-2.5.jar:commons-io-2.0.1.jar:commons-dbcp-1.4.jar:commons-configuration-1.10.jar:commons-compress-1.9.jar:commons-logging-1.1.jar:httpmime-4.2.2.jar:httpcore-4.3.2.jar:httpclient-osgi-4.3.jar:httpclient-4.3.2.jar:commons-httpclient-3.1.jar:commons-codec-1.9.jar:wsdl4j-1.5.1.jar:saaj.jar:jaxrpc.jar:commons-logging-1.0.4.jar:commons-discovery.jar:commons-discovery-0.2.jar:axis.jar:XmlSchema-1.4.3.jar:xalan.jar:serializer.jar:commons-logging.jar:commons-httpclient-3.0.1.jar:stax-api-1.0.jar:jaxb-api-2.0.jar:geronimo-jta_1.0.1B_spec-1.0.1.jar:geronimo-jms_1.1_spec-1.1.1.jar:geronimo-j2ee-management_1.0_spec-1.0.jar:commons-logging-1.1.jar:activemq-jaas-5.2.0.jar:activemq-core-5.2.0.jar:activemq-all-5.13.2.jar:activation-1.1.jar:vision-api-2.5.3.0.jar:iControl.jar /tmp/a
5)RUN (very similar to step #4, just trying to show the prompt return)
[root@localhost inframgr]# /opt/bin/jre/bin/jjs -cp .:inframgr.jar:google-gson.jar:ruby-gems-1.1.jar:java-xmlbuilder-0.6.jar:vmguest.jar:vim25-wsdl.jar:vijava60compat.jar:vijava55b20130927.jar:ssoclient-wsdl.jar:srm.jar:pbm-wsdl.jar:jaxen-1.1-beta-6.jar:dom4j-1.6.1.jar:velocity-1.6.2.jar:velocity-1.6.2-dep.jar:jclouds-vcloud-1.0-beta-7.jar:jclouds-terremark-1.0-beta-7.jar:jclouds-scriptbuilder-1.0-SNAPSHOT.jar:jclouds-log4j-1.0-beta-7.jar:jclouds-jsch-1.0-beta-7.jar:jclouds-core-1.0-beta-7-jar-with-dependencies.jar:jclouds-compute-1.0-beta-7.jar:vcloud-java-sdk-1.5.0.jar:rest-api-schemas-1.5.0.jar:syslog4j-0.9.43-bin.jar:maverick-all.jar:pd_ipc_server.jar:nesla-1.1.jar:libthrift-0.9.1.jar:jruby-complete-1.7.9.jar:javax.ws.rs-api-2.0.1.jar:javax.inject-2.3.0-b10.jar:javax.annotation-api-1.2.jar:gch_client.jar:aopalliance-repackaged-2.3.0-b10.jar:xalan-2.7.0.jar:trustpool.jar:quartz-2.1.7.jar:gch_server.jar:bcprov-jdk15on-151.jar:bcpkix-jdk15on-151.jar:slf4j-log4j12-1.7.6.jar:slf4j-api-1.7.6.jar:ant-1.8.4.jar:ss_css2.jar:pd4ml.jar:ojdbc14.jar:classes12.jar:manageontap-5.3.1.jar:mysql-connector-java-5.1.24-bin.jar:mongo-java-driver-2.11.3.jar:log4j-1.2.15.jar:jxl.jar:junit-4.9b2.jar:jsoup-1.7.3.jar:json-lib.jar:jackson-databind-2.8.0.jar:jackson-core-2.8.0.jar:jackson-annotations-2.8.0.jar:jackson-all-1.9.5.jar:jsch-0.1.45.jar:jfreechart-1.0.13.jar:jcommon-1.0.16.jar:jdepend-2.9.jar:smtp.jar:mailapi.jar:javassist.jar:jade.jar:jssc.jar:guava-15.0.jar:google-gson.jar:flexlm.jar:Vendor_info.jar:EccpressoAll.jar:ehcache-core-2.6.6.jar:aws-java-sdk-1.4.3.jar:jdo2-api-2.3-eb.jar:datanucleus-rdbms-4.1.0-release.jar:datanucleus-core-4.1.0-release.jar:datanucleus-cache-4.0.4.jar:datanucleus-api-jdo-4.1.0-release.jar:asm-5.0.4.jar:ucsd-rest-api-sdk-v2.jar:cuic-client.jar:bonecp-0.8.0.RELEASE.jar:servlet-api.jar:commons-validator-1.4.0.jar:commons-pool-1.6.jar:commons-pool-1.3.jar:commons-net-3.1.jar:commons-logging-1.1.jar:commons-lang3-3.1.jar:commons-lang-2.5.jar:commons-io-2.0.1.jar:commons-dbcp-1.4.jar:commons-configuration-1.10.jar:commons-compress-1.9.jar:commons-logging-1.1.jar:httpmime-4.2.2.jar:httpcore-4.3.2.jar:httpclient-osgi-4.3.jar:httpclient-4.3.2.jar:commons-httpclient-3.1.jar:commons-codec-1.9.jar:wsdl4j-1.5.1.jar:saaj.jar:jaxrpc.jar:commons-logging-1.0.4.jar:commons-discovery.jar:commons-discovery-0.2.jar:axis.jar:XmlSchema-1.4.3.jar:xalan.jar:serializer.jar:commons-logging.jar:commons-httpclient-3.0.1.jar:stax-api-1.0.jar:jaxb-api-2.0.jar:geronimo-jta_1.0.1B_spec-1.0.1.jar:geronimo-jms_1.1_spec-1.1.1.jar:geronimo-j2ee-management_1.0_spec-1.0.jar:commons-logging-1.1.jar:activemq-jaas-5.2.0.jar:activemq-core-5.2.0.jar:activemq-all-5.13.2.jar:activation-1.1.jar:vision-api-2.5.3.0.jar:iControl.jar /tmp/a
6)Result:
[root@localhost inframgr]# cat /tmp/b.txt
Varaibale 123
Varaibale 123
gene.williams
Community Member
Wow, this is cool!  Thanks for revealing this, Orf.
