Orf Gelbrich
inShare
Task Name
Get temperature by zip code
Description
Prerequisites
vCenter
CategoryWorkflow
ComponentsUCSD 6.6
User Inputs
Output
  5. Click "Browse" and navigate to the location on your computer where the .WFDX file resides. Choose the .WFDX file and click "Open".
  8. Click "Submit".
The workflow and decission tree:
Temperature shows up in string of bubbles as well:
Workflow was running on a 1 hour schedule for Ft. Worth TX
Here are the resulting e-mails from the decision tree:
API task inputs:
     /data/2.5/weather?zip=@{Zip},us&APPID=@{APIKey}&units=imperial
Response
Task inputs:
Global variable update.  (make sure this variable is created by hand)
Workflow:
